Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 02-19-2008, 02:47 PM   #1
RallySport Direct
NASIOC Storefront Vendor
Member#: 33174
We are Open Late!
888-457-2559 Every day!
Default DIY: 2008 STi KartBoy Short Shifter
Shortly after getting our 2008 STi it was apparent that the stock shifter must go.
And this is KartBoy cames in
After taking the stock shifter out, it was apparent that Subaru did a slight change of design, and used a different sized barrel. After getting in contact with TIC we had some new STi 6speed pivot bushings.
The interior is a little bit more complicated to take apart over the previous GD, however its nothing that cant be done.
Parts You will need:
KartBoy 6 Speed Shifter
TIC 6spd Pivot Bushing
Lithium Grease
Tool you will need.
10mm Socket
12MM Open end wrench,
12mm socket
Flat head screw driver
3/32 Punch
Rubber hose(to hold the reverse lockout toggle under the car, in the up position)
Hammer
Rag
Pliers to cut zip ties.
Jack, and jack stands.
1) Remove the 2 bolts that are in the arm rest that are bolting down the arm rest to the chassis.
2) Pop up the Ebrake boot to gain access to a bolt under it. Be careful as not to damage the leather and the plastic.
3) On the under side of the center dash piece, between the seat and the carpet there are some hidden clips that you will need to pull over the tabs that are on the plastic. There are 2 of these clips. One if the front and one in the back part of the leather boot.
4) Remove the bolt that is under the Leather E brake boot, and pull the armrest portion BACK. DO NOT LIFT AS YOU WILL BREAK THIS LITTLE WHITE CLIP.
RallySport Direct is offline   Reply With Quote
Old 02-19-2008, 02:47 PM   #2
RallySport Direct
Member#: 33174
We are Open Late!
5)Then grab the tray and the shift boot portion and pull it straight back as well. However BE VERY CAREFUL, as there are small finger that hold the whole assembly to the lower part of the dash.
6) After you get it off this is what you will see. Just take out the 2 plastic white nuts that hold the rubber boot over the bottom of shifter.
7) Take off the Zip tie that is on top of the shifter holding the reverse lockout cable.
Then take out the bolt that holds the shifter barrel to the U shifter rod.
Then prosed remove the C clip.
8) Get under the car and have your friend pull on the Reverse lockout.
Jack up the car and put it on jack stands.
Clime under and follow the reverse lockout cable from the shifter all the way to the transmission. As your friend is pulling on the lockout you will notice that there is a little arm moving on the tranny. Put a rubber hose between the arm and the tranny to keep it in the pull up position.
9) After you get the lever arm on the tranny in the up position, proceed to knock the reverse lockout pin out of the shifter.
Careful as the reverse lever on the shifter is spring loaded. Its weak spring tension, however make sure you dont loose any of the parts.
10) After the pin is out and the C clip is pulled out, proceed to pull the shifter out of the cup. There will be 2 rubber O rings. Make sure you don't loose or damage them.
This is what the bottom of the shifter looks like after you get it out.
11) Take out these 2 little screws and the piece that they hold will slide off.
12) OEM next to a Kartboy
Your 1/2 Way there!
13) Transfer all the parts onto the KartBoy Shifter.
NOTE: YOU WILL NEED TO USE THE TIC 6spd Pivot Bushing. As the OEM ones will not fit into the KartBoy barrel(Thanks Subaru for the design Change).
Place a little grease back into the cup that holds the bottom of the shifter.
Then prosed to do everything backwards.
You will also need to use a second zip tie to tie up the Reverse lockout cable away from the drive shaft.
Now clean up and enjoy your new KartBoy Short Shifter.
Old 02-19-2008, 02:48 PM   #3
RallySport Direct
Member#: 33174
We are Open Late!
Kirill
RallySportDirect.com
Old 04-06-2009, 02:17 PM   #4
falling315
Member#: 175452
08 WRX STI
words of advice on this install:
-Buy a c-ring remover, I failed to do this and it ended up taking 20 minutes to get it out
-make sure with the 3/32 tap that you use is not tapered close to the tip. I used a tap that was tapered too close to the tip and ended up putting a hairline crack in my reverse lockout ring.
falling315 is offline   Reply With Quote
Old 04-14-2009, 01:04 AM   #5
manjambles
Member#: 205643
2005 forged goodness
great writeup
manjambles is offline   Reply With Quote
Old 04-15-2009, 10:17 PM   #6
Krondor
Member#: 187845
2008 STi
I would point out that in pic 12 of both shifters side by side, you can see the place you are to connect the Reverse lockout cable to the new short shifter from Kartboy is a bit lower than the OEM. That bit lower places the cable below the car closer to your drive shaft. I found out the hard way.
After install I was driving down the highway and noticed a horrible noise when in 5th or 6th. When I got home to investigate, I found the cable had been worn by the drive shaft. I ended up using a zip tie to bring the cable up further into the cabin. Just needed a bit of tension while the shifter was in 6th to ensure the cable didn't dangle lower and hit the drive shaft again.
Krondor is offline   Reply With Quote
Old 04-15-2009, 11:01 PM   #7
Member#: 67
1999 Outlasting
the competition.
This i correct. it is also why we include two zip ties with every shifter.
Tom
tom@kartboy is offline   Reply With Quote
Old 11-13-2009, 10:21 AM   #8
Peer2Peer
Member#: 229877
98 OBS
pretty well made, thx
Peer2Peer is offline   Reply With Quote
Old 11-13-2009, 02:13 PM   #9
Sperm
Member#: 25038
2002 PSM WRX sedan
Yeah, nice write up. I'll refer to this at a later date. (Hopefully soon! Looking for an 08 AW STI right now )
Sperm is offline   Reply With Quote
Old 11-13-2009, 02:32 PM   #10
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
PM sent
snowman4us is offline   Reply With Quote
Old 02-27-2010, 11:27 PM   #11
ILLESTs13
Member#: 239678
very nice write up
ILLESTs13 is offline   Reply With Quote
Old 06-05-2010, 07:12 AM   #12
08WRX_Infidel
Member#: 243740
2008 Stg 2 WRX Sedan
79 Vette
How much is this different from the 08 WRX? Just bought one and will be installing it on my mid-tour leave from Afghan in a couple weeks...
08WRX_Infidel is offline   Reply With Quote
Old 06-05-2010, 12:31 PM   #13
RallySport Direct
Member#: 33174
We are Open Late!
Its a noticeable difference no matter WRX, STi or even base model Impreza
Old 06-06-2010, 01:38 AM   #14
08WRX_Infidel
Member#: 243740
79 Vette
Im talking about the instal...I heard the kartboy shifter was a pain to instal on my buddy's 06 Sti, but i was wondering if your instructions are the same for the 08 WRX as the Sti you posted up?
Old 06-06-2010, 02:53 PM   #15
Member#: 67
1999 Outlasting
the competition.
the only thing you wont have to worry about is the reverse lockout cable setup. all the rest is pretty much the same for the 08+ 5 speeders.
tom
Old 06-06-2010, 11:45 PM   #16
08WRX_Infidel
Member#: 243740
79 Vette
Tom,
Thanks for the detailed instructions, I am looking forward to installing this on my car in a couple weeks when I get home for R&R from over here.
Old 08-26-2010, 09:01 AM   #17
4Lo
Member#: 251180
2008 sti
WR Blue Mica
Man am I glad I read this! I would have broken the little white clip for sure! Thanks for a great write up!
4Lo is offline   Reply With Quote
Old 04-29-2011, 08:17 AM   #18
ulyssis
Member#: 278629
Awesome write-up dude! I'm about to take the plunge and purchase this short shifter. I went on the KartBoy site and found this:
http://www2.kartboy.com/x4/product.p...cat=257&page=1
It looks like this package has more parts then you have stated in your list of parts required. But it does include the shifter and the bushings.
Am I looking at the right item? If so, are those extra parts required or should I just buy the shift and the bushings separately?
ulyssis is offline   Reply With Quote
Old 04-30-2011, 08:35 PM   #19
RallySport Direct
Member#: 33174
We are Open Late!
The items you are seeing in that link are the shifter along with the front and the rear shifter bushings.
Old 05-02-2011, 08:37 PM   #20
ulyssis
Member#: 278629
The bottom pic are the bushings correct? What is the top pic and where does it go in the install? I read through the install and don't see where this part was installed.
Old 05-02-2011, 08:45 PM   #21
ulyssis
Member#: 278629
found it. top pic is the rear bushing. is there a how-to as detailed as this for that part?
Old 08-29-2011, 02:04 AM   #22
AnthonyWang
Member#: 292823
Fuji Factory
Bugeye
niiiiiice
AnthonyWang is offline   Reply With Quote
2008 wrx kartboy Short shifter factoryflood Car Part Reviews 7 05-30-2008 11:02 AM
Sti Kartboy Short Shifter 150.00 wrxdoghouse Drivetrain 3 09-04-2007 01:42 PM
socal sti kartboy short shifter Twsti Private 'For Sale' Classifieds 1 12-29-2005 11:10 PM
STi Kartboy Short Shifter $100 apoji187 Private 'For Sale' Classifieds 3 04-01-2005 12:27 PM
