Old 08-31-2011, 09:14 PM   #251
smitty504
Member#: 290959
Originally Posted by nhat View Post
no rolling needed and i'd run 235 or 245/40/18s personally.
the bore doesn't matter unless it's smaller than 56.1.
Thank you very much! Thats what I wanted to hear
smitty504 is offline   Reply With Quote
Old 08-31-2011, 09:53 PM   #252
wutdadilyo
Member#: 53967
2011 WRX Premium
Originally Posted by Mach V Dan
Some pics of 18x9.5 +40 with 245/40R18.
--Dan
Mach V
FastWRX.com
With the white wrx on bc coilovers, is there any rubbing over bumps? I love the stance on that setup but unfortunately I have speed bumps in the parking deck at my work. Have you had anyone in the back seats and have an rubbing?
wutdadilyo is offline   Reply With Quote
Old 08-31-2011, 10:29 PM   #253
nhat
Member#: 140163
03 STi
hellaflunctional
there's no rubbing over bumps if you do what's necessary.
Old 09-01-2011, 10:57 AM   #254
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
On the 9.5" with a 38 offset, 255 wide, is there a little more room between tire and fender? My gf has an '11, and wants wheels that will be 2mm closer to the fender than the 9.5" et 38, and will not roll the rears, will 245's be needed?
colin1234567 is online now   Reply With Quote
Old 09-01-2011, 11:10 AM   #255
nhat
Member#: 140163
03 STi
hellaflunctional
there's zero chance of that setup not rubbing without rolling the fenders.
it makes no sense to me why people think they can get away without rolling their fenders while asking about a new wheel/tire setup that is wider and has a lower offset.
it's like expecting your gums to not bleed while you're in the dentist's chair without flossing.
Old 09-01-2011, 11:12 AM   #256
Mach V Dan
Member#: 12029
So...you're planning to run 9.5" +36? Yes, I'd think you'd need 245 if you don't want to do any fender rolling. Even then, it may rub.
Remember that this is NOT an exact science! Cars differ -- sometimes the subframes are shifted slightly left or right relative to the car, for example -- and tires differ. One 245 width tire will NOT be exactly the same width as another. When we're talking mere millimeters of clearance, be prepared to make adjustments as needed.
The other thing that I keep seeing here is "I don't want to roll my fenders, under any circumstances." Fender rolling is NOT that scary. Done properly, it's a minor modification that is harmless, invisible, and not very expensive.
--Dan
Mach V
FastWRX.com
Old 09-01-2011, 11:25 AM   #257
colin1234567
Member#: 212639
WRX= 13/SWP/SOLD
'10 NC2 Miata
Well, 9" with a 30 offset, but same difference I guess. I agree that fender rolling is a simple half hour mod, I've done it, I just was curious, I thought it was more of a science my apologies!
Old 09-01-2011, 02:57 PM   #258
Stu_Gotti
Member#: 270392
2011 WRX Limited
WR Blue
Dan - Do you guys do fender rolling at your shop in Sterling?
Stu_Gotti is offline   Reply With Quote
Old 09-01-2011, 03:53 PM   #259
Mach V Dan
Member#: 12029
Yes.
--Dan
Mach V
FastWRX.com
Old 09-01-2011, 04:45 PM   #260
Stu_Gotti
Member#: 270392
2011 WRX Limited
WR Blue
Excellent. I spoke with someone at the shop earlier with regards to wheels/tires and plan on making a trip up to hopefully leave with a set of wheels/tires for my ride... mine will likely require rolling the rear.
Old 09-02-2011, 07:17 AM   #261
DrDustin
Member#: 291410
Obsidian Black
Dan - I'm looking at winter tire sets. Have you fitted the black steelies on stock brakes? 16x6.5 with 42 offset is the size I have seen listed. Would those rims still work if brakes are upgraded in the future? Also, with that offset and 215/55/r16 tires is the scrub radius affected? I don't know how to calculate such things. Thanks.
DrDustin is offline   Reply With Quote
Old 09-02-2011, 09:19 AM   #262
b1aze
Member#: 284003
2010 Alpine 135i
--Dan
Mach V
FastWRX.com
Came a little with the blue one. Utterly perfect. Just need to find a wheel color I like on DGM. Did the bigger wheels and springs force you to use any upgraded camber plates or bolts?
b1aze is offline   Reply With Quote
Old 09-02-2011, 09:43 AM   #263
Mach V Dan
Member#: 12029
Is that an OEM Subaru steel wheel? I'd be surprised if the offset is that low.
There's no OEM steel wheel that I know of that fits over the STI Brembos. There is a steel SPARE that fits.
Any time you move the offset from stock, the scrub radius is affected, but +42 isn't enough of a different to worry about.
--Dan
Mach V
FastWRX.com
Old 09-02-2011, 02:37 PM   #264
sa4baru
Member#: 195354
slightly off topic, but related:
what are the options for TPMS sensors in aftermarket wheels? OEM or are there aftermarket?
sa4baru is offline   Reply With Quote
Old 09-02-2011, 02:53 PM   #265
nhat
Member#: 140163
03 STi
hellaflunctional
please search.
Old 09-02-2011, 10:17 PM   #266
GUIL-BOT
Member#: 270940
2011 WRX Sedan
Default New shoes :)
I know I need a drop :P
I noticed that something change since I got my camber, wheels and tires changes...
This is really weird:
When I brake my car pull to the left.
When I let my car go w/out brake or gas, it's pull to the left.
When I accelerate, the steering pull to the right ( makes the car go straight )
Current Setup:
Rota Grid 18x9.5
Fender Rolled
-3.8 Fron Camber
-2.5 Rear Camber
0 Toe
Tire 265/35/18
GUIL-BOT is offline   Reply With Quote
Old 09-03-2011, 01:26 AM   #267
DrDustin
Member#: 291410
Obsidian Black
Not OEM, found on belle tire site, local MI tire store, made by the wheel source?
Old 09-03-2011, 01:34 AM   #268
you got WAY too much camber and its too low already
and you are doing it exactly wrong....perfect
Old 09-03-2011, 09:29 AM   #269
ryebread929
Member#: 219194
2011 WRX Sedan
SWP 322WHP/360WTQ
Thank you for posting this thread. I read it over a few times and just had one question..
You said a 255/35-R18 will fit with no issues on a +40 to +48 offset wheel. Is that for a 18x9 or a 18x9.5?
I have a 2011 wrx sedan and just want to do what can be done without needing rolling. Thanks so much!
Ryan
ryebread929 is offline   Reply With Quote
Old 09-03-2011, 09:51 AM   #270
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
WHat he said.
FAshion has a price. What you are experience is too much rim and your car is too low. The camber specs are JACKED. If this is the look you want, get ready to live with the crappy performance you have inherited.
The question is, now much crap are you prepared to live with over fashion.
The fact that you think it needs more of a drop is insane. Lower is not better. If all you care about is looks then fine. Its your car do what you want...but if the car acting and driving like a new car means anything to you, then you need to find some happy place between modding your car like an educated person does, and modifying it like the hellaflush yahoos do around here. Do not get sucked into the moar low nonsense.
I would wager that getting your camber specs closer to normal will fix all your problems. If you cannot run more stock like camber specs then I guess you have a choice to make. Live with these issues, or sell your rims/tires and get something a little closer to OEM.
SCRAPPYDO is online now   Reply With Quote
Old 09-03-2011, 10:54 AM   #271
nhat
Member#: 140163
03 STi
hellaflunctional
i don't see anything wrong. it's definitely not too low already.
stock camber < his settings
Old 09-03-2011, 12:39 PM   #272
Stu_Gotti
Member#: 270392
2011 WRX Limited
WR Blue
Went to Mach V yesterday and bought a set of Rota D-Force 18x9.5 +40 5x100 in Gunmetal and went ahead and purchased some BF Goodrich g-Force T/A KDW NT 265/35R-18 93Y BSW tires for them. Plan on having Mach V roll my rear fenders and install once these tires get in.
Thanks, Dan and crew for the hospitality and look forward to having these things on.
Old 09-03-2011, 12:39 PM   #273
Mach V Dan
Member#: 12029
When I accelerate, the steering pull to the right ( makes the car go straight)
There are a lot of reasons this might happen. Out of curiosity, what offset are those wheels? Some things that might make the car pull as you describe include:
- Some kind of tire problem. One corner over- or under-inflated.
- Mis-matched front camber settings
- Bent front suspension part
- Mis-matched toe settings
I'd have the alignment re-checked first, then try to track down other causes. Assuming the alignment is good, swap front tires to see if that changes anything.
Subjective. It's pretty good front camber for a road race car. Too much for a street car. But if he has to do it to clear the tires, then he has to do it... The car doesn't look THAT low. Not to where it's going to destroy the handling by any means.
...and you are doing it exactly wrong....perfect
Please give more concrete suggestions.
I think we've already established in this thread that it's NOT too much WHEEL (I don't like the term "rim," because to me "rim" means the outer edge of a something). I suspect in this case the offset is too low to get the tires under the fenders, though.
Those camber numbers are not that crazy. For an all-out track car, that amount of static camber in front will make for great grip in the corners. It's unlikely he'll be able to load the car up enough on the street to take advantage of it, though.
I don't think the front camber by itself is causing the steering weirdness., although it certainly may be highlighting it. If the alignment is all symmetrical, it shouldn't tug in one direction all the time.
--Dan
Mach V
FastWRX.com
Old 09-06-2011, 07:03 PM   #274
speedbagger
Member#: 289736
2016 WRX Base
i agree in principle with scrappydo.....this hellaflush fad (i cringe at even typing that) is amusing.
no you don't NEED a drop. although it is your car...
and this surprises you? how much more do you new wheels and tires weigh? and you got that camber set-up with the stock bolts? i'd have a reputable raceshop recheck that....
no offense to machv's advice but take it with a grain of salt.....he's a vendor selling wheels and tires.
speedbagger is offline   Reply With Quote
Old 09-06-2011, 07:15 PM   #275
nhat
Member#: 140163
03 STi
hellaflunctional
attitudes like this are far more amusing than the hellaflush "fad".
offense taken to your mach v comment. he doesn't push people one way or another nor does he criticize others for their choices, all he does is offer help unlike many others.
bringing up weight for a daily driver is laughable.
please keep it to technical information and not opinion. if you want to voice your displeasure, go to member's car gallery. better yet, keep it to yourself.
Needed: Stock Impreza/WRX/Legacy wheels and tires to fit '01 Legacy L acetmi Private 'Wanted' Classifieds 0 06-14-2006 01:43 PM
need somewhere to get wheels and tires asap bubba03wrx Southern California Impreza Club Forum -- SCIC 22 04-02-2004 10:14 PM
Wider wheels and tires in the rear SilveRexy03 Tire & Wheel 14 11-04-2003 05:49 PM
WEre is a good place to buy wheels and tires MilfordSubaru Mid West Subaru Owners Club Forum -- MWSOC 4 05-25-2002 02:14 PM
Where to buy wheels and tires? wilddave1 Brakes, Steering & Suspension 4 03-21-2002 03:20 PM
