Old 09-08-2011, 09:49 AM   #851
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Originally Posted by scby rex View Post
Anyone know if the wrc ver 4 manifold will bolt to later year heads?
they're phase 1, so no. The bolts are in a straight line and not staggered.
Old 09-08-2011, 01:11 PM   #852
leoimpreza
Member#: 197989
2002 Impreza WRX STI
WR Blue
leoimpreza is offline   Reply With Quote
Old 09-08-2011, 08:55 PM   #853
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
how is that going to work with where the manifold inlet is and the cosworth oil pump?
Homemade do you have a pic of the difference of ver4 and ver7? Mine looks inline to me.
Old 09-09-2011, 01:53 AM   #854
Rising Sun Subaru
Member#: 265020
bolt hole's for the heads are different placing, 1994-1998 and in a stright line(4 bolts per-side)
1999-2012 are 2 out side bolts are back and 2 in the middle are center.
cut the bottom mount bracket of a 99-00 wrx/sti intake manifold and cut the bottom of the 1994-98 mounting bracket and weld the 99-00 on to the bottom(making sure it all lines up) and then just clean up the ports to suit the new mounting bracket.
Leo,I was going to buy 1 of them OBX copy(Tomei copy) just to have a play around with...any results on that set up so far?
Kris
Rising Sun Subaru is offline   Reply With Quote
Old 09-09-2011, 08:00 AM   #855
5lipstream
Member#: 124663
2003 AW WRX
2008 GG Evo X MR
Originally Posted by fobiawrx View Post
i thought that had a water to air intercooler in it? in between the runner section and the tb section? could be wrong though?
No intercooler inside. I have a gigantor front mount. It's possible that Fastech made one with an intercooler inside. The intake manifold on Fastech's drag car is bigger even than mine. Fastech is on here (PlatinumRex).
5lipstream is offline   Reply With Quote
Old 09-09-2011, 10:43 PM   #856
scby rex
Member#: 104878
02 wrxbastardchild
Thanks rising sun. Anyone know if there is a phase 2 wrc manifold available like the ver4?
Old 09-09-2011, 10:56 PM   #857
Rising Sun Subaru
Member#: 265020
http://www.subaruwrcspares.com/10.html
Kris
Old 09-10-2011, 01:23 PM   #858
leoimpreza
Member#: 197989
WR Blue
GC with Tomei intake manifold
Old 09-10-2011, 01:27 PM   #859
leoimpreza
Member#: 197989
WR Blue
Old 09-11-2011, 01:59 PM   #860
scby rex
Member#: 104878
02 wrxbastardchild
Heres what Ive got going so far. I still need need to make a throttle cable bracket and do a little more clean up then its off to the powder coaters.
Old 09-11-2011, 06:04 PM   #861
Thomas Ruble
Member#: 12694
02 WRX/JDM EJ207RA
Unabomber Eeee-thug
Looking good scby rex. What throttle body is that? Do you happen to know the inner diameter size of the back side (mating surface) of the throttle body?
Tom
Thomas Ruble is offline   Reply With Quote
Old 09-11-2011, 06:25 PM   #862
scby rex
Member#: 104878
02 wrxbastardchild
Thank you, its the AT power 72mm designed for rogerclark motorsports. They are using a DBW now though. It bolts up perfectly to the wrc manifolds. Im not understanding the "backside" but its 72mm front to back no taper.
www.atpower.co.uk
Old 09-11-2011, 06:38 PM   #863
Thomas Ruble
Member#: 12694
02 WRX/JDM EJ207RA
Unabomber Eeee-thug
Sorry for the confusion...
Back side meaning opposite end of inlet. You answered my question by stating 72mm diameter with "no taper". Looks like you have a very high quality throttle body for sure. I would like to know more about your build. Do you have a thread posted?
Tom
Old 09-11-2011, 06:41 PM   #864
scby rex
Member#: 104878
02 wrxbastardchild
Just on iwsti, my motor is std til she pops.
http://www.iwsti.com/forums/other-ve...ars-tuned.html
Old 03-08-2012, 01:12 AM   #865
simprezl25
Member#: 71647
2002 Bug iD
will the ej20g intake manifold bolt up to the usdm stock heads? i have on laying around and they dont have the tgv but just straight thru so just jw if anyone tried. thanks
simprezl25 is offline   Reply With Quote
Old 03-08-2012, 08:38 AM   #866
3MI Racing
Member#: 200987
Sorry have been swamped lately and not on here.
As far as I know the Ver 4 is a phase 1 style manifold where the 4 bolts will be in line and not staggered like most of us are use to seeing.
I however am not 100% on this. I never got much into the old school JDM parts.
Old 03-08-2012, 09:16 AM   #867
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
No the 20g will not, I think the bolt pattern may work but it is not wide enough, carl davy in the uk makes a set of spacers that you can cut your plenum and weld in to make the phase 1 manifolds work with phase 2 heads but by the time you buy them and and do the required work plud any rewiring to make the different sensors work you would probably be much better off just doing a tgv delete from what I havr read.
spackyscooby is offline   Reply With Quote
Old 03-08-2012, 09:08 PM   #868
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
I am hoping I can bolt up the stage .5 ported 2.5 NA big tube short runner from ASF Machine to my JDM TGV deletes and 2011 STI throttle body...I want to get everything gasket matched from the throttle body into the intake, the intake, to the TGV's, then the 8mm phenolic spacers and finally into the heads.....
Here is to hoping....
jdpsearcher is offline   Reply With Quote
Old 03-08-2012, 10:55 PM   #869
simprezl25
Member#: 71647
2002 Bug iD
you're the man thanks
Old 03-09-2012, 01:54 AM   #870
spackyscooby
Member#: 169257
00 rsti & 04 fxt
millenium jade
No problem, and when I posted that I was at work and didn't have time to look it up but as Homemade posted the bolt patterns between ph.1 and 2 are different, that is what the spacers made by Carl Davey addresses. Then you have to widen your phase 1 mani by 12-14mm as seen here, http://www.carldavey.co.uk/product.php?id=16.
Old 06-16-2012, 07:00 PM   #871
8thWonder
Member#: 230366
2005 STi
it's motor buildin' time!
Just another guy installing a 2.5i manifold...
Does anyone know off-hand what size NPT fittings are needed to plug these holes? Are they 1/8" NPT?
8thWonder is offline   Reply With Quote
Old 06-16-2012, 09:10 PM   #872
8thWonder
Member#: 230366
2005 STi
^^update, they're not 1/8" NPT
I'm thinking they're M10-1.0 bolt size... not 100% sure though, since the only parts store within walking distance didn't carry that size.
Old 06-19-2012, 08:37 AM   #873
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
They wouldn't be 1/8" NPT on a Subaru, if anything they'd be 1/8" PT (also known as 1/8" BPT). Slightly different than NPT.
There are a number of 10mm fasteners on the car, can't you just pull one out to use to check?
Old 06-19-2012, 09:44 AM   #874
8thWonder
Member#: 230366
2005 STi
You're exactly right - they're 1/8" BPT. Will be using a 1/8" NPT tap to make them compatible with some sensors.
Old 11-24-2012, 03:14 PM   #875
ISL33P
Member#: 220906
Thought I would bump this one along Dyno testing results coming very shortly
ISL33P is offline   Reply With Quote
WTB: Polished or Aftermarket intake manifold midnightsti Private 'Wanted' Classifieds 4 06-13-2006 06:39 PM
Aftermarket intake manifold west005 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 18 05-30-2006 09:03 PM
Aftermarket Intake Manifolds WRXRallyBlue Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 25 10-03-2005 08:11 PM
New/Aftermarket Intake manifold Twelvz Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 03-11-2005 12:32 PM
New Aftermarket Intake Manifold DonkeyPunch Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 01-15-2005 06:15 PM
