Old 09-06-2011, 11:13 AM   #151
nhat
Member#: 140163
03 STi
hellaflunctional
the drop alone will get you at least -1.7* in the rear so -2.5* will be easy with rear camber plates.
i prefer 255/35/18 for more meat and a far better tire selection.
nhat is offline   Reply With Quote
Old 09-06-2011, 01:59 PM   #152
samdust
Member#: 240975
2010 wrx
year: 2010
model: wrx sedan
wheel model: rota grid
wheel size/offset: 17x9 +42
tire brand/model: bfg kdw2
tire size: 225/45/17
suspension: stock
alignment:stock
fender mods: stock( needs to be rolled in the rear though)
spacers: yes/no? size? no
fits but if you bottom out they will rub. imho need to get the rears rolled and get a wider tire. like a 235 or 245
samdust is offline   Reply With Quote
Old 09-06-2011, 04:32 PM   #153
sc00by4life
Member#: 97135
Originally Posted by CaseD
Can I achieve that much camber on bc coils w/ rear plates? Where exactly is the limit? I am trying to learn a lot about this before I pull the trigger on a set of wheels, that way I know what I am getting myself into. Are you recommending 255/35s just because of the extra meat on the tire?
at first I was looking at these:
http://www.wheeldude.com/catalog/pro...oducts_id=6461
now I am considering these because of the slightly higher offset:
http://www.ngpracing.com/store/index...roduct_id=4096
I dont mind messing with the fenders, but running that the amount of camber you mentioned for the 18x9.5 just seems like a lot.
Yes the plates you have will be fine.
When you want to run aggressive wheels, plan on aggressive suspension setups which include more camber than is typically run on a normal car.
2.7 is not that bad. Keep up on your tire pressure and you shouldn't experience any uneven wear.
Old 09-08-2011, 12:12 AM   #154
eriks02wrx
Member#: 246683
hey guys this is my current set up
year:2002
model:WRX
wheel model: Rota Torque
wheel size/offset:18x9.5 +35
tire brand: Nankang NS-2
tire size: 225/40/18
suspension:BC BR series coilovers
alignment: -1 front, -3.5 rear
fender mods: roll and mild pull all 4 corners
going to try and fit some 255/35's soon with out going much higher than it is in the last pic
eriks02wrx is offline   Reply With Quote
Old 09-08-2011, 02:00 AM   #155
sc00by4life
Member#: 97135
year:2002
model:WRX
Have fun pulling at your height. Looks good though.
Old 09-08-2011, 02:49 AM   #156
eriks02wrx
Member#: 246683
Thanks! but i dont think it will be that hard dmoneys car isnt pulled that much and he is running 255's with a lower offset than me. the 255/35 actually has a smaller sidewall than my 225/40 so that will help out as well
Old 09-08-2011, 03:00 AM   #157
eriks02wrx
Member#: 246683
Old 09-08-2011, 12:04 PM   #158
nhat
Member#: 140163
03 STi
hellaflunctional
you'll need a lot more negative camber up front though. props for going with 255s.
Old 09-08-2011, 02:09 PM   #159
sc00by4life
Member#: 97135
There is a lot more work to dmoneys fenders than you even realize...
You'll also need to trim the rear bumper brackets, forgot about that one. With your wheels it shouldn't be that bad, but pulling fenders adds a whole nother "oh ****" factor. very very very easy to **** it up.
Old 09-09-2011, 03:45 AM   #160
eriks02wrx
Member#: 246683
yeah i understand..im not really worried about running alot of camber up front it comes with the trade. i should be fine with the pulling process, i have done a few that turned out really good just havent done mine since there was no need for it. as soon as i get home and get the tires on and everything dialed in i will post some pics and let you guys know how hard it really was haha. thanks for the input!
Old 09-11-2011, 03:21 PM   #161
Xzibit A
Member#: 288834
2005 STi
matte black
Hey guys im gonna start a new trend its called hellastock...
No srsly i have a fitment question, i plan on getting some XXR 521s, 18x8.5 +40 , Im pretty sure im going to have to run a 10mm spacer(similar to linea corse wheels) but im already sitting at -2*F and -1.6* rear, how much camber will i have to go to fit 245/35s or would 235/40 fit better. Minor stretch is ok but im not a huge fan, i can care less how much camber and fender work it takes
Xzibit A is offline   Reply With Quote
Old 09-12-2011, 03:30 PM   #162
nhat
Member#: 140163
03 STi
hellaflunctional
you'll find more tires in 235/40/18 than you will 245/35/18. if you dial in more negative camber up front, you can leave the front fenders untouched. for the rears, roll them flat. you can run either tire size with your current negative camber if you use no spacers. if you choose to use 10mm spacers on the rear too, you can either run the 235/40/18 with more negative camber or pull the rear fenders too.
Old 09-12-2011, 08:01 PM   #163
Xzibit A
Member#: 288834
2005 STi
matte black
awesome, so basically if i roll the front and rear fenders i can run 2-2.5* front and 2* in the rear, thats not too bad. thanks alot
Old 09-12-2011, 08:42 PM   #164
jnich69
Member#: 242484
2003 18g'ed wrx
sunset orange metallic
I'm looking at getting a set of Rota P1 18x8 +48 wheels for my 03 wrx. I'm currently lowered on S-techs (yes I know) and was planning on running a 235/40/18. Was just wondering if I'm going to need to roll the fenders.
jnich69 is offline   Reply With Quote
Old 09-12-2011, 10:15 PM   #165
Xzibit A
Member#: 288834
2005 STi
matte black
probibly not thats really close to the stock sti wheel spacing( 5 mm further out) in the picture above those wheels are 245/45r17 and my car is tucking tire (1/4") and it never hits the fenders
Old 09-13-2011, 02:47 PM   #166
jnich69
Member#: 242484
2003 18g'ed wrx
Thanks man!
Old 09-14-2011, 10:20 AM   #167
ahmetgurlek
Member#: 270606
2006 STİ
hi guys,
here is my current setup
year:2006
model:STİ
wheel model: stock
wheel size/offset:stock
tire brand: kumho ku 31
suspension:stock + prodrive springs
fender mods: nothing
considering to have work emotion cr kai. which one fits better to my car: 18x8.5 + 38 or 18x9.5 + 38?
any fitment problems with the 18x9.5?
any pics showing the difference between the semi concave face and deep concave face (face2 vs face3)?
ahmetgurlek is offline   Reply With Quote
Old 09-14-2011, 01:07 PM   #168
nhat
Member#: 140163
03 STi
hellaflunctional
no.
Originally Posted by ahmetgurlek
hi guys,
year:2006
model:STİ
wheel model: stock
you'll need to modify your rear fenders to fit any of the wheels you're looking at and those springs are too soft. i hope you have prodrive reds.
Old 09-14-2011, 09:12 PM   #169
DuppyDem
Member#: 293545
Originally Posted by under0athh51189 View Post
i like this thread already. only addition would be maybe wheel and tire brand and model.
year:2005
model:wrx
Wheel model: Miro Stp1
wheel size:18x10
wheel offset:+25
Wheel brand/model: falken ziex 912
tire size:225/40/18
suspension:megan street coilovers upgraded 135mm 10k fronts to go lower, 6k rear
fender mods:rolled and pulled front and rear, no fender liners, tucked harnesses, blow torch and hammer front fender tubs to not rub
Camber: -3.5f -4.5r
Spacers: no, but for brembos you need a 5mm spacers to clear.
whats the weight on those babies? I thought about buying these over the xxr 521s but I heard they are heavy.
DuppyDem is offline   Reply With Quote
Old 09-14-2011, 10:07 PM   #170
nhat
Member#: 140163
03 STi
hellaflunctional
xxr 521s aren't going to be any lighter. you're looking at cheap wheels, expect them to be heavy.
Old 09-14-2011, 11:25 PM   #171
DuppyDem
Member#: 293545
Xxr 521 isn't actually bad for its size width & lip size it weighs 23-24 lbs. I know quite a few more expensive rims what weigh in the same range or more like for example the ssr sp1. With that size lip & width is in that weight range & those are expensive rims 600-700 per rim. Same with the work vs-xx & Bbs lms alot more expensive then the ssr & xxr rims
Old 09-15-2011, 02:33 AM   #172
ahmetgurlek
Member#: 270606
2006 STİ
thank you for the information.
one more question: if i get a coilover kit, will i still need to modify the rear fenders?
Old 09-15-2011, 03:40 AM   #173
wadud
Member#: 258048
06 wrx
E.S.A.C
Did you have to cut a slit in the rear diffuser to make the tow hook work?
jim
wadud is offline   Reply With Quote
Old 09-15-2011, 08:29 AM   #174
daigledangle8
Member#: 253642
2008 Impreza 2.5i
SSM
year: 2008
model: 2.5i Sedan
wheel size: 17x8.25
wheel offset: +35
tire size: Undecided
suspension: None..eventually springs (H&R possibly)
fender mods: Hopefully none
I just wanted to get your guys opinion on this setup. What tire size would you recommend and would I need to be doing any fender mods? Finally getting ready to purchase a set and I want to make sure they will fit no problem. Thanks in advanced!
daigledangle8 is offline   Reply With Quote
Old 09-15-2011, 09:22 AM   #175
nhat
Member#: 140163
03 STi
hellaflunctional
Originally Posted by daigledangle8 View Post
year: 2008
model: 2.5i Sedan
wheel size: 17x8.25
wheel offset: +25
fit no problem? you're looking at an offset that's 25mm too low, +/-3.
the motorsport fitment thread: because race car! nhat Tire & Wheel 45 11-20-2011 03:21 PM
the official wheel/tire fitment thread: all fitment questions go here! nhat Tire & Wheel 1086 06-15-2011 01:02 AM
where did the wheel fitment chart go? PoopRSkupe Brakes, Steering & Suspension 0 01-26-2004 01:36 PM
A thread in the STi forum to keep it alive (because STi forum is closing) Eric SS Off-Topic 6 09-10-2003 03:54 PM
