Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 09-18-2011, 08:40 PM   #1
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Default xluben's 2011 WRX - Blouch 20G-XT-R + E85 Tune - Dyno Results
2011 WRX:
Blouch 20G-XT-R:
Event: 20G-XT-R Tune
Car: 2011 WRX 5 Door
Tuner: Nuke of NF Performance
Dyno Info: Virtual Dyno - Dynojet Setting
Transmission: 5 Speed
Gear: 3rd
Peak HP: 426WHP
Peak Torque: 438WTQ
Baseline hp/tq for a stock on same dyno: 250WHP
Target Boost: 24PSI
Fuel: E85
Engine/Power Modifications:
Blouch 20G-XT-R
Invidia TBE
FMS FMIC
Forge BPV
AEM CAI
GrimmSpeed EBCS
GrimmSpeed MBC
Walbro 255
1200cc Injectors
Build Thread: xluben's 2011 WRX 5 Door Build Thread
Dropped in the Blouch 20G-XT-R last week. I did partial air pump deletes (got rid of everything in the way of the compressor housing, but I didn't pull the intake manifold off to get the last few pieces out) and I ended up using the AVCS oil line kit from FP. It's pretty slick and looks to be very well put together.
Nuke and I went out to tune it and first did a pull on wastegate pressure only. The wastegate spring on this turbo is 19psi, and the car made around 390WHP! Big jump from the ~350WHP that I was at with the VF52. We turned it up to 24psi and made 426WHP/438WTQ
For comparison, here is a layover of the curves on top of a recent VF52 log that I had. Should be all the same parts besides the turbo (ie. same exhaust, both have FMIC, etc). This shows the difference in spool and powerband between the two turbo's.
The turbo does spool about 500rpm's slower than the VF52, but you can see that it's really never making less power, so it is still very driveable on the street. I am really enjoying it so far! The power is very linear and it just keeps pulling on the top end, where the VF52 fell off. It is very addicting!
Thanks to Nuke for tuning me and helping me out all along the way!
Old 09-18-2011, 08:59 PM   #2
Ragnarok_WRX
Member#: 257093
Wow, massive congrats man. That power curve is amazing, and I think this is the first 20G-XT-R dyno Ive seen, and that thing is holding boost like a champ. Gotta be a riot on the street.
Ragnarok_WRX is offline   Reply With Quote
Old 09-18-2011, 10:01 PM   #3
Dave D.
Member#: 130990
06 Red Ltd.Wagon
20g-xtr 427/427 JJtuned
With headers and TGV deletes you've got another 20hp easily. As it sits your beast should be good for 11's. Nice build!
Old 09-18-2011, 10:02 PM   #4
juanmedina
Member#: 133146
07 FPgreen 7.37@95
WRX VF39+E85 12.0, 121mph
look great congrats
2.4 or 3" inlet?
Old 09-18-2011, 10:04 PM   #5
ImprezivHokie
Member#: 256578
SSM - Agile Protuned
Factory bottom end?
ImprezivHokie is offline   Reply With Quote
Old 09-18-2011, 10:07 PM   #6
blazin09
Member#: 281938
2009 WRX
Very nice. Im considering this turbo for my spring 2012 upgrade but id really like to find a turbo that can spool as early or earlier than the vf52
blazin09 is offline   Reply With Quote
Old 09-18-2011, 10:38 PM   #7
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
I need to ride in one of these cars. While I can easily justify the $$$ in the parts. The time in labor (I DIY everything) is gonna be the pisser. Guess I'll slowly add supporting mods and then one day just slap on the killer turbo and get a protune done.
Amazing #s. Would you do it all over again if given the chance? My goto turbo for the moment was the Dom 1.5 but this might sway me. Hmm
Mike 01Hawk is offline   Reply With Quote
Old 09-18-2011, 10:55 PM   #8
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Yeah, I was thinking EWG would be the best next way to eek out more power. Not that I really am worried about adding power at the moment.
Originally Posted by juanmedina View Post
look great congrats
2.4 or 3" inlet?
OEM inlet (which is horrible to try and get back on, BTW).
Originally Posted by ImprezivHokie View Post
Factory bottom end?
Yes. Stock motor.
Then it probably won't make much more power? Seems like you're dreaming...
Old 09-18-2011, 10:59 PM   #9
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
very nice. car looks sick. must be a blast to drive.
Old 09-18-2011, 11:10 PM   #10
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
I have wrenched everything myself thus far. The turbo really doesn't take long. Easily a one day job.
Thanks! It's a lot of fun.
Old 09-18-2011, 11:13 PM   #11
blazin09
Member#: 281938
2009 WRX
yea. i am dreaming. im not realistic at all haha
Old 09-18-2011, 11:37 PM   #12
Moleness
Member#: 151183
Beautiful car, I want a ride!
Moleness is offline   Reply With Quote
Old 09-18-2011, 11:38 PM   #13
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Full bolt on's and E85 on the stock turbo is a lot of fun. I would definitely try that first
I still want a ride in your car! Lol.
Old 09-18-2011, 11:46 PM   #14
Nuke209
Member#: 108089
2003 WRX
NF Performance
This car's fast. After upping the boost from 19ish psi to 23-24psi, this thing pulls pretty damn hard.
I like this turbo
But I like the car even more
Nuke209 is offline   Reply With Quote
Old 09-18-2011, 11:52 PM   #15
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Thanks Nuke. It's all because of the tuner
Old 09-18-2011, 11:54 PM   #16
Mike 01Hawk
Member#: 219162
2011 WRX Sedan Base
Oh I know, I pulled/re-installed the engine in my '05 STi before I sold it.
I'm just lazy
Old 09-18-2011, 11:57 PM   #17
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Ha! You shouldn't have any problems with a stock location turbo then! Just be sure you have the air pump delete plates ready to go, or the compressor housing of most larger turbo's won't fit.
Old 09-19-2011, 07:53 AM   #18
2barsti
Member#: 210644
One clean car with #'s to back it up!
2barsti is offline   Reply With Quote
Old 09-19-2011, 12:13 PM   #19
THE_SMURF
Member#: 260624
2007 Z06/ZX10R
very similiar numbers to mine.... cars beast... have fun
THE_SMURF is offline   Reply With Quote
Old 09-19-2011, 12:42 PM   #20
ImprezivHokie
Member#: 256578
What's your injector duty cycle on the 1200cc injectors? How's the internal wastegate setup?
Old 09-19-2011, 02:27 PM   #21
xluben
Member#: 261612
2002 WRX - 800HP
9.5s @ 150mph
Thanks everyone.
I don't know the IDC's but we're guessing around 90 or so.
Old 09-19-2011, 02:31 PM   #22
THE_SMURF
Member#: 260624
2007 Z06/ZX10R
any plans to track it? just to see what it'll run....
Old 09-19-2011, 02:54 PM   #23
juanmedina
Member#: 133146
07 FPgreen 7.37@95
it will trap over 120mph for sure
Old 09-19-2011, 03:01 PM   #24
JoeTX
Member#: 83069
2007 STi 302/350
UGM Wingless
Damn nice numbers and the spool is really good too. Let us know how long that stock block and tranny hold out.
JoeTX is offline   Reply With Quote
Old 09-19-2011, 03:15 PM   #25
Nuke209
Member#: 108089
2003 WRX
NF Performance
We'll get together very soon Ben and log a few more things
2011 WRX - Stage 2 + E85 Tune - Dyno Results xluben Proven Power Bragging 71 04-07-2015 04:52 PM
xluben's 2011 WRX: Spec B 6 Speed and Rotated PTE 6266 xluben Member's Car Gallery 5716 08-29-2014 03:26 AM
2011 Old School Meet - Presented by COBB Tuning - June 17-19 Bankheist Texas Impreza Club Forum -- TXIC 177 07-01-2011 02:41 PM
FS : SOLD - 2011 WRX Tires (Dunlop SP Sport 01 - 235/45R17) Colonel Forbin Wheels/Tires 1 10-26-2010 05:09 PM
FS - Blouch Dom 3 Turbo - Brand New!! dcheyne55 SWIC Private Classifieds 5 06-02-2008 07:55 PM
