Old 09-10-2011, 01:03 PM   #1251
Wanarex
Member#: 173034
I may only be one of the many who found this thread late and after getting through all of it is simply amazed, but of all the times to find it, I think this is the best. It is pretty much done. I can't wait to see the finished product! Great Work!
Wanarex is offline   Reply With Quote
Old 09-10-2011, 02:40 PM   #1252
frayz
Member#: 106909
2002 V7 STi Prodrive
Edition... Black!
Thanks very much mate. Comments very much appreciated
frayz is offline   Reply With Quote
Old 09-11-2011, 11:07 AM   #1253
frayz
Member#: 106909
Edition... Black!
Turbos been welded and now fitted along with the downpipe and wastegate. Shortened the inlet hose slightly for better fit. Hopefully get header tank bracket back this week from the coaters and then that can also go on. Oil separator is currently being made. Will size up for the last boost pipe this week too.
My recent pics have been from my iPhone. Here are some new snaps with a real camera lol. So close now its getting frustrating. lol.
Old 09-11-2011, 11:27 AM   #1254
axleon2
Member#: 154117
2003 Forester
Wow! Looks awesome...
axleon2 is online now   Reply With Quote
Old 09-11-2011, 12:08 PM   #1255
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
Lookin great, how long do you think the oem radiator will holdup at the ring?
Old 09-11-2011, 12:18 PM   #1256
frayz
Member#: 106909
Edition... Black!
Forever mate, i dont honestly know why all the US guys get hooked up on swapping out the OEM rads.
The RCM Gobstopper runs an OEM rad with 850bhp and zero issues. My rad will fracture before it causes a temp issue on track.
Old 09-11-2011, 02:43 PM   #1257
CatfaceType-R
Member#: 81102
our temps here. Plus, Americans don't change fluids enough....
Old 09-11-2011, 03:11 PM   #1258
killarx
Member#: 72073
2002 wrx
wrb
Frays what clamps are you using on the intercooler hoses as I have heard the the normal metal ties used can come off when on high boost, happened on a friends GTIR running over 400 bhp
there are some Micalor clamps that are meant to be spot on.
killarx is offline   Reply With Quote
Old 09-11-2011, 03:22 PM   #1259
frayz
Member#: 106909
Edition... Black!
Ive been out at the ring in 30+ degree heat and still never had a coolant issue. Do you guys actually have a temp problem or is it just "cool" to run an ally rad?
Just using standard HiGrip stanless clamps mate. If the pipes are rolled properly and clamps fitted properly you shouldnt have a problem. Also use the old hairspray trick as well as having the powdercoat on my pipes textured which aids grip on the hoses.
Old 09-11-2011, 05:26 PM   #1260
scby rex
Member#: 104878
02 wrxbastardchild
ours ( bugeyes) usually crack, and out where it gets hot ( AZ and CA ) track subies are always over heating. Yet it doesnt get quite as hot there as the southern US states do.
Old 09-14-2011, 05:04 PM   #1261
frayz
Member#: 106909
Edition... Black!
Overall i think the bay is really starting to look a bit special now. Im quite pleased.
As of tonight, header tank is fitted and plumbed in, new PAS line made and fitted. Turbo fully plumbed for coolant and oil, VAC pipes for the wastgate have been run, turbo blanket has been wire locked in place.
Also my custom oil separator is done, this will have a bracket made and then off to the powdercoaters. The last boost pipe was measured up tonight too and that should also be made up asap.
She'll be getting the usual dose of satin black :thumb:
Old 09-14-2011, 05:06 PM   #1262
Paulie
Top Scoob 001
Member#: 16565
Looking real good frayz...real good.
- Paulie
Paulie is offline   Reply With Quote
Old 09-21-2011, 07:37 PM   #1263
frayz
Member#: 106909
Edition... Black!
Many thanks for all the superb comments guys.
Made up a little loom for the fuel pump relay tonight. Still requires the trigger wire but this can be done on the day. You'll notice the small red Deans plug with fly leads to the pump. This is so I can just unplug the pump and with just one bolt and 2 fuel fittings the whole pump/filter cradle can be removed to get super easy access for changing spark plugs.
Old 09-21-2011, 07:38 PM   #1264
frayz
Member#: 106909
Edition... Black!
Last parts back from coat
Old 09-21-2011, 07:38 PM   #1265
frayz
Member#: 106909
Edition... Black!
Well a little break between showers meant i could get some of this stuff fitted up.
Strut brace back on, oil separator in and final boost pipe in. I need to make up the -10 return line to the oil pan but i didnt fancy getting under the car in the rain. lol
So now the oil cooler and air inlet ducting can be done and the front end can go back on. Lets hope tomorrows weather lets me play
Huge thanks to the kind words and support from everyone. :thumb:
Have some pics
Old 09-21-2011, 11:10 PM   #1266
scby rex
Member#: 104878
02 wrxbastardchild
Looks awesome, you going to fire it up this weekend?
Old 09-22-2011, 04:23 AM   #1267
frayz
Member#: 106909
Edition... Black!
Will be a week or 2 mate as my new ECU is a "made to order" job lol.
Old 09-22-2011, 08:29 AM   #1268
frayz
Member#: 106909
Edition... Black!
Chipped, cracked, dented, swirled and in need of some serious paintwork attention. Shes in one piece again.
Old 09-22-2011, 08:46 AM   #1269
Nairb336
Member#: 144642
2006 6spd Wagon
SGM
Awesome build! Naughty for sure!
Nairb336 is offline   Reply With Quote
Old 09-22-2011, 09:19 AM   #1270
CatfaceType-R
Member#: 81102
*pants tighten* gulp
Old 09-22-2011, 03:58 PM   #1271
FATgc8
Member#: 98838
2005 STi
Hey frayz post up a vid when you fire it up!
FATgc8 is offline   Reply With Quote
Old 09-22-2011, 07:44 PM   #1272
And70
Member#: 171055
2001 STI Wagon
2nd Top Scoob #22
happy days mate !!!!!
And70 is offline   Reply With Quote
Old 09-22-2011, 07:49 PM   #1273
frayz
Member#: 106909
Edition... Black!
Will do guys, i'll get something of her up.
Glad you like it, cheers for the kind comments
Old 09-22-2011, 07:52 PM   #1274
MY EJ20TTTTTT
Member#: 275239
2002 Rallying WRX
Rock chipped MBP
Will be the fastest Subaru in Britain!
MY EJ20TTTTTT is offline   Reply With Quote
Old 09-22-2011, 08:10 PM   #1275
scby rex
Member#: 104878
02 wrxbastardchild
You have the ap 6 pistons right? Are they the cp5555-816s4 or the cp7040-2? Im trying to source rotors and brackets for mine but its very difficult here in the US.
The Making of the latest Subaru TV spots mark wisno General Community 3 09-15-2005 01:16 PM
Any specialists can confirm the difference of parts for JDM V7 / V8 and USDM STI? V6 Subaru Conversions 3 05-21-2005 11:49 AM
Who's catching the tail end the making of RE:Apocalypse? bobturismo Off-Topic 2 09-07-2004 11:22 PM
MTV: MA$E | The Making of The 'Welcome Back' Video Janq Off-Topic 11 07-01-2004 02:09 AM
2.5rs sti conversion - the making of the supercar rallyblues Subaru Conversions 56 02-25-2004 02:44 PM
