Old 10-09-2011, 01:13 PM   #51
Psychoreo
Member#: 79643
2015 WRX STI
Terminal black pearl
Honda =/= Subaru
Old 10-09-2011, 05:41 PM   #52
wrxtsteelo
Member#: 297274
2004 wrx
rally blue
if you properly disconnect and unistall the ap from your car the dearlership probably wont notice because if the car runs fine they are gonna by it and sell it. if you dont unhook it the dealership might know if they are smart because they can tell by the power if you were running stage 2 on it.
wrxtsteelo is offline   Reply With Quote
Old 10-09-2011, 09:54 PM   #53
RexWagonWA
Member#: 221945
Default Accessport Detection
I ran the v 1 AP on my 2002 Wagon from 2003 to 2010. (Now has OS with the hybrid build) It was in for warranty issues I admitted that a number of Cobb products were installed. There was never a problem!
What I have noticed if folks having engine problems it is frequently from not tuning or bad tunes because they were cutting corners.
You can purchase from Cobb with confidence. In 2003 the AP was revolutionary. When I look at the larger variety of AP versions, it is clear these folks know what they are doing.
If you blow your engine, build a new one.
I also have 161K on my "glass transmission". If you treat it right, it works fine.
RexWagonWA is offline   Reply With Quote
Old 10-09-2011, 11:11 PM   #54
DeRock25
Member#: 284715
2011 impreza WRX
Dark Gray Metallic
Originally Posted by Psychoreo View Post
Honda =/= Subaru
thats why i said... ".. but that's just my speculation.."
DeRock25 is offline   Reply With Quote
Old 10-11-2011, 11:23 PM   #55
damonhimself
Member#: 235835
2011 WRX 5DR
Originally Posted by Haelan View Post
I commented about this earlier, but I had one dealership provide me a printout of the year (2007) the vehicle's ECU was last flashed. They didn't have any corresponding paperwork from Subaru that a flash was performed by them so they refused to work on my car.
And this was just to have the rear struts replaced.
You are aware that the computer doesn't have a calendar/clock, right?
damonhimself is offline   Reply With Quote
Old 10-11-2011, 11:27 PM   #56
Haelan
Member#: 151045
2013 Subaru STI
CBP
Yeah, I am. Try reading the whole thread.
The service manager wouldn't have raised a fuss over the ECU if the previous owner used an AP and re-flashed the original stock ROM back in before selling it. I agree with Bill that he most likely used an updated stock map revision that only became available in 2007. That's most likely how he was able to come up with that year. Since there were no service records to correlate the update he started the finger pointing.
Haelan is offline   Reply With Quote
Old 10-17-2011, 04:51 PM   #57
GStriker
Member#: 298135
I have been looking into getting AP for my 2011 WRX but have been very worried about warranty work. I think this just helped me make the plunge!
GStriker is offline   Reply With Quote
Old 10-17-2011, 05:45 PM   #58
samus143
Member#: 270802
2006 wrx
Snow
Go for it you won't regret it!
samus143 is offline   Reply With Quote
Old 10-18-2011, 08:08 AM   #59
Mansour14
Member#: 279796
2004 Wrx
Good to know.
Mansour14 is offline   Reply With Quote
Old 10-18-2011, 11:33 AM   #60
GStriker
Member#: 298135
I am new to the world of Subaru's what are some of the good vendors to go through?
Old 10-19-2011, 03:33 PM   #61
Freedog
Member#: 293551
After reading the entirety of this thread, and just out of curiosity, does anyone have info on what information is stored in the Subaru ECUs (i.e. starts/stops, run time, revs, speeds, gear shifts, etc.), and how long that data is stored for?
I'm just curious about this info since it always seems to be up to debate. Forgive my ignorance here as well, but if the ECU is reset with a battery disconnect as some people suggest to periodically "refresh" the ECU to match a driving style/location, then wouldn't that appear in the ECU data as well with no ill affects down the road? Basically, it appears to me that someone could drive their car like a bat out of hell, reset the ECU by means of a battery disconnect, then drive again for a few days, and when the dealership looked at the data, there would be no record of the abusive driving except for the noted ECU reset. Presumably, most people do change their batteries without the help of a dealership anyway, so there would be no service record of an ECU reset from that...
Freedog is offline   Reply With Quote
Old 10-24-2011, 11:45 AM   #62
Bugeye115
Member#: 217771
2011 Stage 2 SWP WRX
1984 Subaru Brat
So, say i take my new wrx in for an oil change and I have the stage 1 AP tune, and they just so happen to be curious and hook up a scanner while im not present and they see that i have a tune on it, can they keep that info and if something happens use it against me? and if they do that is that voiding my privacy and i could take them to court, Correct?
SJ
Bugeye115 is offline   Reply With Quote
Old 10-24-2011, 05:42 PM   #63
SexySatinWhiteSTI
Member#: 286013
SJ
Of course they can keep that info and use it against you. You modified the car. They have a right to keep that on file so when you come and say "my ringlands blew and I don't know why" they can go "here you go let us help jot your memory. Oh that's right. The tune you installed" it's not an invasion of privacy when you brought the car into them for work.
SexySatinWhiteSTI is offline   Reply With Quote
Old 10-24-2011, 08:34 PM   #64
Bugeye115
Member#: 217771
1984 Subaru Brat
so your saying if you do go in you would need to flash back to stock?
SJ
Old 10-25-2011, 02:43 AM   #65
.KR3W.
Member#: 293951
2009 WRX
SJ
Pretty much what COBB has been saying throughout the entire thread, so...YES!
.KR3W. is offline   Reply With Quote
Old 10-25-2011, 07:59 AM   #66
wrxman02
Member#: 24162
2014 Legacy 2.5i
2012 Impreza 2.0i
warranties are for toasters. I would not worry about it on your Subaru.
wrxman02 is offline   Reply With Quote
Old 10-25-2011, 01:44 PM   #67
Bugeye115
Member#: 217771
1984 Subaru Brat
For an oil change?
SJ
Old 10-25-2011, 02:20 PM   #68
damonhimself
Member#: 235835
2011 WRX 5DR
For an oil change?
SJ
Yes...
Old 10-25-2011, 04:10 PM   #69
Bugeye115
Member#: 217771
1984 Subaru Brat
Alright
SJ
Old 11-15-2012, 02:23 AM   #70
datbacker59
Member#: 250117
2012 STi
Plasma Blue Pearl
its 2:22 am and i just read everyword of this old thread. might just have to get an ap v2 now...
datbacker59 is offline   Reply With Quote
Old 11-15-2012, 10:43 AM   #71
datbacker59
Member#: 250117
2012 STi
Plasma Blue Pearl
so has anyone unmrried and did all the steps with just stage 1 an has been denied coverage? might do it havnt heard barely anyone jave problems
Old 11-26-2012, 11:53 PM   #72
05_r6
Member#: 325895
Ill let you know above if it happens to me. PO unmarried the AP to my04 and im dropping it off tomorrow. Lets hope!
05_r6 is offline   Reply With Quote
Old 11-27-2012, 12:38 AM   #73
datbacker59
Member#: 250117
2012 STi
Plasma Blue Pearl
^wat happend?
Old 11-27-2012, 11:10 AM   #74
lordgrinz
Member#: 293423
2011 WRX Limited 5dr
WRB SPT/Stock
With all these Tuned cars, has COBB seen more than one OEM tune on say the 2011 WRX? I'd be interested in knowing if SOA is making adjustments to the stock tune themselves.
lordgrinz is offline   Reply With Quote
Old 11-28-2012, 09:45 AM   #75
Cobb Tuning
Member#: 4803
They don't generally touch the primary portions of the tune (i.e. boost/fuel/timing) with same year revisions (and even across different years that have essentially the same hardware). The only cases where they have is when there was a major problem with the original mapping (04 STi and 08/09 STi).
Bill
can the dealer tell if you have a tuner els.sti Newbies & FAQs 33 05-02-2008 02:42 PM
Can a Subaru dealer tell if an ECU has been EcuTek flashed? benw Commercial ECU Reflashes 6 01-15-2007 04:16 PM
So how can you tell if your post was deleted? jonny_boy Off-Topic 8 08-07-2003 09:42 AM
Lamo: Can't turn radio on once car is started if it was on when car was off MadManMike Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 01-02-2002 04:31 PM
how can you tell if your differential was damaged due to towing? yuzo Service & Maintenance 5 12-30-2001 02:53 AM
