Old 09-21-2011, 09:13 AM   #1
sean18337
Member#: 135588
2007 STI *SOLD*
Default 2011 STI Open Loop fueling maps Question
Hey guys:
For the 2011 STI MAIN Open Loop Fuel Maps...
Are the Primary Open Look Fueling KCA Additive B LOW & HIGH the same as the old Primary Open Look Fueling Map A & B..?
I know the 2011 STI definitions are still Experimental and just want to make sure I'm not missing anything here.
I posted examples below.
sean18337 is offline   Reply With Quote
Old 09-29-2011, 02:53 PM   #2
sean18337
Member#: 135588
2007 STI *SOLD*
I figured this out myself.. Just made some small changes to the Primary Open Loop Fueling KCA Additive B LOW map... Logged AFR with a wideband and saw the AFR change..
Hopefully this will help other CAUTIOUS folks.
Old 10-08-2011, 10:48 PM   #3
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
ideally you make larger adjustments using the MAF table and you can scale in percentage. the Open Loop table will make smaller changes at a less drastic rate
mxturboracer86 is offline   Reply With Quote
Old 10-13-2011, 12:05 AM   #4
D0nets
Member#: 129746
2007 stg3 WRX
WR Blue
MAF Sensor Scaling?
D0nets is offline   Reply With Quote
Old 10-13-2011, 02:05 AM   #5
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
Stuff like this makes me that my LGT only uses one set of tables.
Is there a parameter that you can log that will show you which set of tables the ECU is using?
Without a clear understanding of how the ECU alternates between the different sets of tables, it seems best to tune them all identically. Unless you are sure it uses one set 99% of the time, in which case you could just focus on that set, and leave the others set up very conservatively - like 0.5 richer, 4 degrees less timing, no WGDC, etc.
Old 10-17-2011, 05:50 PM   #6
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
^ you could log the final fueling target....or click the help tab and it should tell you
iirc the KCA High table = IAM of 1 and KCA Low = IAM <1 and the failsafe table is for limp mode
Old 07-25-2012, 07:36 AM   #7
JLHK
Member#: 322967
What about the KCA alternate table? Any one know please?
JLHK is offline   Reply With Quote
Old 08-02-2012, 09:26 AM   #8
endrswrd
Member#: 323908
2013 BRZ ltd
ISM
That table is probably still not fully figured out. Ususally with alternates they are just an alternate to the A map. So mode the alternate the same way you mod the A map. Best way to check this is to check out the stock tune. If the two are the same, then you know your answer.
endrswrd is offline   Reply With Quote
Open Loop Fueling Question windozer Open Source Reflashes 2 11-30-2009 03:52 PM
What exactly is closed loop vs. open loop fuel control? Neek Engine Management & Tuning 5 03-09-2005 12:50 AM
Need experts! Open loop fueling coming on too slow... big_adventure Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 11-30-2004 08:24 PM
Can someone take a look at this open loop fuel map... 03WRXMA Engine Management & Tuning 7 03-13-2004 03:33 PM
Open loop fueling? Bolster Engine Management & Tuning 7 03-06-2004 11:56 PM
