Old 10-09-2011, 08:29 PM   #26
Spin1200
Member#: 250286
09GR phatbottiPowrd
T.S.P.'s test mule
Seems like new car, yet same old problems..
Turbo Subarus need a tune as soon as soon as they roll out of the dealership, as well as frequent oil changes 5-30 should never be used. 93 octane at all times were applicable.
we are sitting on time bombs otherwise.
Spin1200 is offline   Reply With Quote
Old 10-09-2011, 09:26 PM   #27
slimfit
Member#: 90597
2011 WRX Premium
Did I miss something? How did they know you were using 5w40?
slimfit is offline   Reply With Quote
Old 10-09-2011, 10:55 PM   #28
furiouswrx
Member#: 283048
2011 WRX Ltd Hatch
He kept oil receipts religiously.
furiouswrx is offline   Reply With Quote
Old 10-09-2011, 11:43 PM   #29
Conor
Member#: 107677
1993 MR2 - V6 swap!
1986 MR2 - 4AGE!
Why the heck are you running 5w40 anyway?
Automakers are ALL like this. Toyota, Mitsubishi, Hyundai, Kia, Ford, GM.. doesn't matter. They all look for retarded excuses not to authorize repairs. And they all lean HARD on their dealership network to NOT do warranty work.
Conor is offline   Reply With Quote
Old 10-10-2011, 07:56 PM   #30
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
He's running 5w40 because like 12 guys on the internet blew up their heavily modified cars because the stock oil weight wasn't sufficient to protect from bearing failure.
I'd be looking for a leak - possibly secondary air injection or something of the sort.
We've got an 09 Forester (non-turbo) with an EGR valve that caused misfire codes on all 4 cyls, but no codes for the EGR system itself.
CosmoTheCat is offline   Reply With Quote
Old 10-10-2011, 10:06 PM   #31
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
d00000000000000d....you need to wake the **** up and read the blown motor threads
there are 12 a WEEK here.....and many are STOCK cars that spun bearings
this is NOT a fantasy that YOU want it to be....it is a fact
Old 10-10-2011, 10:12 PM   #32
n2oiroc
Member#: 141952
15 legacy 16 wrx
its threads like this and the fact that i work with an ex flat rate dealer tech that are going to have my resealing the oil pan on my 7,000 mile 2011 wrx by myself. i know the dealer will either claim its normal or the tech will just use an angle grinder with a scotch brite pad and toss silicone all over the bottom end and likely cause a spun bearing that they will later claim is from abuse. its pathetic and sickening how many dealers and soa handle these simple issues.
n2oiroc is online now   Reply With Quote
Old 10-10-2011, 10:13 PM   #33
n2oiroc
Member#: 141952
15 legacy 16 wrx
but the owners put the throttle to the floor! thats clearly abuse!
Old 10-10-2011, 10:13 PM   #34
aserr
Member#: 263792
I answered truthfully when they asked because I knew it would come up if they asked for maintenance records (and they did). Plus, if they were to find out that I was withholding that kind of information, it would only lead to speculation about other things I might not be telling them (but that's not the case).
Well, when I bought the car, 5w-40 was an acceptable weight and based on my research was a better choice than the 5w-30 oils that have a tendency to degrade.
aserr is offline   Reply With Quote
Old 10-11-2011, 09:26 PM   #35
CosmoTheCat
Member#: 3409
98 My FMIC
Clearly it happens ALL the time... yet there are no current threads about stock unmolested 2.5 turbos with spun bearings?
I think your definition of reality is different than mine. This must be just like all those water pumps failing left and right.
Old 10-19-2011, 08:45 PM   #36
aserr
Member#: 263792
Well, I have my car back again. The stated source of the problem is the valve clearance. Specifically:
Found several exhaust valves tight. Spec at .013, actual measurement is .012. Most valves at lower end of specs. Performed teardown and checked valve shims. Ordered as needed.
I'm a little skeptical given that the misfires were on all four cylinders, but I'm keeping my fingers crossed.
Old 10-19-2011, 09:38 PM   #37
2011WRX
Member#: 251807
[quote=aserr;35414973]Well, I have my car back again. The stated source of the problem is the valve clearance. Specifically:
Doesn't sound logical to me. Let's see if that fix the problem.
They already mess up saying it's due to oil the first time but obviously it's not. Don't think they know what they are doing.
2011WRX is offline   Reply With Quote
Old 10-19-2011, 10:04 PM   #38
slimfit
Member#: 90597
2011 WRX Premium
Old 10-19-2011, 10:08 PM   #39
n2oiroc
Member#: 141952
15 legacy 16 wrx
oh my god! so loosening the valve clearance on a couple cylinders .001" into spec is the solution? (assuming they actually measured correctly) wow! i think i have officially lost the last tiny bit of faith in dealers i had left.
Old 10-19-2011, 10:13 PM   #40
n2oiroc
Member#: 141952
15 legacy 16 wrx
are there any mods at all? intake, anything? do you happen to have a tick? timing belt off a tooth?
Old 10-20-2011, 12:00 AM   #41
paliknight
Member#: 285480
2016 F82
MWM
keep us posted OP. i hope your car is fixed, but i would be skeptical to think the codes would be claiming cylinder misfires and all they do is tighten valves 0.001" less lol
paliknight is offline   Reply With Quote
Old 10-20-2011, 12:43 AM   #42
Member#: 111556
2006 STI
this whole 'oil issue' is just ****ign ridiculous....bloody, bleeding ****ing out of their ****ing minds
ridiculous
if subaru is telling anybody that using a 5w40 oil will cause CEL's or ANY issue...they need to pull their heads outa their collective ass and FIND THE REAL PROBLEM and not blame the ****ing oil bing used
THAT is just bull****.
I just read this thread and the fact that it took 23 posts for someone to say this is quite disturbing. I would ignore all further advice from this thread.
xerox445@yahoo.com is offline   Reply With Quote
Old 10-20-2011, 05:38 PM   #43
bluesubie
Member#: 767
04 FXT
Look again.
-Dennis
Old 10-20-2011, 05:40 PM   #44
bluesubie
Member#: 767
04 FXT
So are you getting a $110 refund for the oil change? Did you ever contact SoA and open a case? I really would find another dealer.
-Dennis
Old 10-26-2011, 12:23 PM   #45
Chip90
Member#: 280093
2011 Stage 2 WRX 5Dr
Blue; 09' FZ6R
i would get a refund ASAP on the oil change. You should argue that THEIR oil change caused this problem..
And yes, contact SOA .
Chip90 is offline   Reply With Quote
Old 10-26-2011, 01:03 PM   #46
meebs
Member#: 3251
2009 WRX Hatch
Lightbulb
I recall an old misfire thread where a valve adjustment fixed the issue...
meebs is offline   Reply With Quote
Old 10-26-2011, 01:45 PM   #47
cartoonlife
Member#: 204291
07 UGM STi Ltd
2012 Prius
Good news is you'll know for sure what the problem was when they fix it, regardless of what we tell you on here.
I've used RT6 on two STis for 100k miles combined and no issues. Both turning excellent UOAs. Not sure how the oil would have caused misfires on all 4 cyl but ok :/
GL OP & keep us posted
cartoonlife is offline   Reply With Quote
Old 11-25-2011, 01:59 PM   #48
slimfit
Member#: 90597
2011 WRX Premium
Is there any update on this. Just curious.
Old 11-26-2011, 06:53 AM   #49
Dat8687
Member#: 243261
2004 WRX
Java black pearl
Complete BS.. I have never had a car throw a code because of the oil. Unless you ran out of oil..
Dat8687 is offline   Reply With Quote
Old 01-20-2012, 01:15 AM   #50
aserr
Member#: 263792
As a final update, after about 2000 miles and 3 months, the CEL has not returned and the car idles much more smoothly.
I don't know what else to say, the valve adjustment appears to have solved the problem and despite the cost, I will probably stick with the Subaru branded 5w-30 synthetic for all future oil changes.
With regard to the cost of the oil change charged by the dealer, I'm not going to bother hassling them about it. Not that 100 bucks is chump change, but I have better things to do with my life.
I hate to say it, but my cousin is the awesomest OriginalSin Off-Topic 40 12-12-2011 12:40 PM
My 2011 WRX And A Couple Other Subies Enjoying The Snow Paul_09Rex Member's Car Gallery 22 11-30-2010 01:08 PM
my stock map says my car is AT, is this an issue? MAtwal Engine Management & Tuning 5 01-19-2010 12:48 AM
Versus said my car is the least JDM looking Subaru, how can I make it look more JDM? JDM addict Member's Car Gallery 130 09-16-2005 08:08 PM
Rainy Subaru antics, why my car is the bomb! Bankheist General Forum Archive 3 10-27-2000 05:53 AM
