Old 08-06-2010, 11:16 AM   #76
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
Well, I could draw you a picture maybe... but I just sold my stock intake after I bought a SPT shortram.
2point0 is offline   Reply With Quote
Old 08-06-2010, 06:06 PM   #77
Evilchargerfan
Member#: 183529
i wanna help teh
haters ... love life ...
so i used teh "searcH" button last night
and i think i figured it out *crosses fingers*. will attempt this weekend
Evilchargerfan is offline   Reply With Quote
Old 08-06-2010, 10:00 PM   #78
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
I had to open up the hole in the airbox and shave some of the "fins" on the bottom to finesse the PCV pipe in there, but it worked. I also cut off most of the "female" portion so I could maneuver it easier.
http://smg.photobucket.com/albums/v64/taltos/for%20sale/
1st 3 pics kind of show what I'm talking about. The plastic ring in the 2nd pic with the white plastic screws...that has to come off. I put it back on to go with the snorkus when I sold it all. But you can see where I shaved the opening a bit.
I think I got the idea from a post on ScoobyMods, but it's been a while.
Old 10-21-2010, 09:33 PM   #79
aaron0386
Member#: 261449
2006 Wrx Wagon
this was perfect to come across getting rid of that sealt chime just made my night great and when the car warms up not such a pain to sit through that noise
aaron0386 is offline   Reply With Quote
Old 11-11-2010, 01:52 AM   #80
mdusek1576
Member#: 231660
2006 Cobb Stg 2 STi
sweet post man. the only thing needed was some pictures.
so there you are. now this is the perfect post. again. this is for off foad use only and is illegal for street driven cars (blaaa blahh blahhhh)
thanks man. and the chime for the seat belt had to be more annoying than my little sister. now its virtually gone. GREAT POST!!
mdusek1576 is offline   Reply With Quote
Old 11-11-2010, 11:53 AM   #81
ToxicCrucible
Member#: 254200
2008 WRX - 316hp
Rally Blue
dang, i wish the DRL fix was that easy on the 08s
ToxicCrucible is offline   Reply With Quote
Old 11-12-2010, 12:58 AM   #82
mdusek1576
Member#: 231660
2006 Cobb Stg 2 STi
yeah.
Old 11-12-2010, 09:50 AM   #83
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
Originally Posted by User Banned View Post
ALWAYS WEAR YOUR SEATBELT! - I do not condone operating a motor vehicle without proper seatbelt usage! DRL's are US government mandated on 2006 + MY vehicles. All infomation contained herein is meant for off-road use only! Author holds no responsibility for YOUR actions!
Canada: CMVSS 108, 1/1/1990, DRL's are mandatory.
United States: FMVSS 108, 1/1/1990, DRL's are permitted, but not mandatory.
As an aside, General Motors has been, and continues to push for the mandating of DRL's in the United States, and does offer them on every vehicle they sell. GM also offers retrofit kits (that you must purchase) for older GM models that do not have DRL's.
Big-E is offline   Reply With Quote
Old 11-18-2010, 02:15 AM   #84
04 WRXWAGON
Member#: 147124
04 wrx wagon stg 2
java black
Default ecu reset doesn't affect belt chime
I bought my wagon new and the seat belt chime delete was already done?!?!? BUT!!! I DO NOT have to repeat the steps after an ECU reset. I get the few beeps and light at start up but then no light or sound without the belt on.... I just thought that's how wrx's were.......until I recently rode in my buddy's 04 sedan and his chime was screaming the whole way to the store. hmmmmmmm, maybe my wagon is weird.....
04 WRXWAGON is offline   Reply With Quote
Old 11-29-2010, 03:22 AM   #85
CarpeDiem04
Member#: 204648
2004 WRX
Disabled my DRL today. Easy to do and it works. I did notice that I no longer get any reminder beeps/chimes if I leave the lights on, turn the car off, and open the door. Remember to turn them off or you'll have a dead battery. I'm sure I'll do that at some point.
CarpeDiem04 is offline   Reply With Quote
Old 11-29-2010, 01:17 PM   #86
my name is joe
Member#: 171412
Originally Posted by red_rex_rally View Post
If you are a new person to the wrx scene dont let anyone fool you into doing the silencer mod without the elbow that goes in place. If you take out the "silencer" the possibility of sucking water is almost certain. without the elbow dont even think about it.
what i did was chop it in half of what the snorkle delete would look like and i cut a a flat piece off whatever was remaining from the snorkle and just melted them together with a torch. problem solved.
my name is joe is offline   Reply With Quote
Old 11-29-2010, 01:19 PM   #87
my name is joe
Member#: 171412
the guy might have desodered the sound board or he just broke the speaker.
Old 01-22-2011, 05:37 PM   #88
endflag
Member#: 254127
2011 WRX 5-door
2007 H-D Sportster 1200R
SEATBELT CHIME ELIMINATION
DIFFICULTY: 0.5 out of 10.
1. Insert key into ignition. Turn to "Accessory On" position. This is the last click before you would turn the key to start the engine. Your radio and annoying seatbelt chime will be ON.
2. Within 5 seconds of turning your key to "ACC ON", take your seatbelt clip, and INSERT & RELEASE into the buckle 20 times repeatedly. Each time you INSERT the clip into the buckle, it must "click" into place. You must push the release button to remove it. Complete this 20 times within 30 seconds.
3. When you have completed the 20 clicks, turn your key off and remove it from the ignition.
4. Start your car as normal. You will notice that the seatbelt indicator chime will sound six (6) times, then go off. It will NOT come back on until the next time you start your car, and it will stay on this pattern indefinately.
5. To re-active your annoying seatbelt chime, simply unhook your positive (+) battery terminal for 30 seconds to reset the ECU.
This took me a couple of attempts but the third time wound up being the charm. The main issue seemed to be either that it actually takes more than 20 inserts and removals or I just can't count.
With that said, I can confirm that this still works on the 2011 WRX and when you get it right the seatbelt warning light(s) will go off, and stay off, after those initial six chimes. If they stay on you after the chimes then you need to try again.
Good luck!
endflag is offline   Reply With Quote
Old 02-19-2011, 08:59 PM   #89
DocCola
Member#: 193844
12 VW Golf .:R
12 CBR, 12 HD48
From personal experience the plugs on the 2011 WRX behind the glove box are different. Anyone got a picture of the plug that is supposed to be pulled and how. I couldn't for the life of me get mine loose.
DocCola is offline   Reply With Quote
Old 02-23-2011, 03:38 AM   #90
JonzFaSTi
Member#: 85575
2013 STi
Dark Gray Metallic
Good luck!
I first tried this in my 06 WRX about the time of the OP as well as a buddies 2.5i and my 05 Legacy GT and now again after a few extra attempts it worked for me again in my 2011 STi.
Like he said "the lights will turn off if you did it correctly"
Now if someone could just tell me how to do this in an Audi A4 and my GF would do great things for me
JonzFaSTi is offline   Reply With Quote
Old 10-20-2011, 12:38 PM   #91
tna2327
Member#: 296502
2012 WRX Premium
How do you do it in the 08+? Been looking everywhere. In my old tiburon, they just made a relay that took care if it...can't find anything here!
tna2327 is offline   Reply With Quote
Old 10-20-2011, 01:25 PM   #92
2point0
Member#: 150248
'13 BRZ Ltd WRB
'67 Mustang
^Front passenger side behind the bumper. There's a big heatsink. Unplug and remove that and done.
Old 10-20-2011, 01:52 PM   #93
tna2327
Member#: 296502
2012 WRX Premium
Thanks, I actually found a thread on another forums showing how to do it using the relay. Much easier
Old 10-21-2011, 04:00 PM   #94
snkp360
Member#: 276780
2016 STi Limited
Dark Grey Metallic
Just did the seatbelt warning on my 2011 WRX yesterday.....sooo much better now
snkp360 is offline   Reply With Quote
Old 10-21-2011, 09:19 PM   #95
Macfamous
Member#: 298047
2009 WRX Sedan
Originally Posted by Hank3 View Post
Because the plug in the engine bay is just a drop resistor, not the main control unit for the DRL, which is the unit/clip you unplug behind the glovebox. If you ever go HIDs, you need to disconnect the DRLs completely, not just from the engine bay. If not, you will shorten the life of your HID bulbs as they will come on or flicker with the DRL not being totally disconnected.
Is this also true when using a relay harness for the HID's that merely uses the stock wiring as a means of knowing when to turn on?
-Mac
Macfamous is offline   Reply With Quote
Old 03-11-2012, 08:22 PM   #96
Bob_A_Booie
Member#: 313213
Nice write up. I just tried it on my 2012 and the trick still works.
Additional info from another thread: 20 clicks of the belt gets you 6 dings when you start up. 30 clicks and there will be no noise at all!
Bob_A_Booie is offline   Reply With Quote
Old 03-16-2012, 05:55 AM   #97
StOcKaBoi
Member#: 236697
2006 Impreza 2.5i
Dark Blue
Thanks for the Chime trick, helped me and my friend out quite a bit. However i would never disconnect my DRL cause its so much easier to just pull the E-brake up one click. That shuts them off just fine for me, and I can turn them back on with ease as well. (I like to switch to my DRL at night so i can spot other drivers headlights [also helps for spotting cops ahead of time])
...my headlights are dangerously dim :/
StOcKaBoi is offline   Reply With Quote
Old 04-10-2012, 09:14 PM   #98
mrchyes
Member#: 294069
98 Forester
Green
im going to go out and attempt the seatbelt trick right now i was just watching topgear on BBC and they were reviewing a Caddy CTS, it was "bonging" as he was explaining that there was a large gap in the door that he just climbed out, thats how he knew that the door was open, not that the stupid Bong was blaring in his face. lol jeremy is funny.
Probably going to do the DRL shutoff as well, because lights are stupid. if i want them on ill turn them on
???'s on the snorkus delete. does this exist in a RS? because i would like to hear the intake sound a bit more, and im probably going to run some flexible piping up from the foglight (because i have none :/ ) and get more air up there BECAUSE RACECAR. But id like to get rid of the snorkus if my rs even has one lol. its 04
thanks for any help anyone has
EDIT: just deleted the DRLs , Worked great!!!
Got the chime off, i think, it may have already been done, because i dont remember it, but whatever. I tried doing it 30 times, and it wasnt successful in making all the chimes turn off... so idk
mrchyes is offline   Reply With Quote
Old 04-20-2012, 11:19 AM   #99
Ivanbarker
Member#: 314665
2006 Impreza 2.5i
Steel Grey
The seatbelt hack worked great, thanks.
Quick question though, why would you want to disable the daytime running lights?
Ivanbarker is offline   Reply With Quote
Old 04-20-2012, 06:15 PM   #100
Snoopy408
Member#: 271104
2006 WRX STi
my thoughts exactly.
Snoopy408 is offline   Reply With Quote
APS 65mm Intake TD04 wrx stock tmic GP MOTO intake silencer delete 02rex62 Engine/Power/Exhaust 18 03-04-2010 07:30 PM
Intake Silencer delete elbow SupraScooby Newbies & FAQs 20 08-25-2004 03:33 PM
Intake silencer delete fluttering noise heffergm Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-27-2004 06:18 PM
intake silencer deletes? chrislehr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 20 03-11-2004 12:22 AM
gpmoto Intake Silencer delete elbow Benjamin Tang Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 11-04-2003 05:10 AM
