![]() Brakes & Suspension Forum sponsored by The Tire Rack |
#276 |
Member#: 133267
Vehicle:2004 psm WRX mucho door dingo stg 2er |
read thru entire thread, still a little unsure of DD settings...
having this setup installed by Cobb Surgeline as we speak: d-specs with crucial racing springs (257/217) & group N tophats. what settings would be optimal for this spring rate? thanks in advance, will post whole setup (and revisions) going forward.
#277 |
Member#: 133267
Just a quick point- If people start posting their springs' rates with the type of springs being used, it will make all the postings in this thread much more meaningful and infinitely more useful....some have, but most omit this vital info.
Also, more explanation of why you have your D-specs set the way you do.... Chance? Experience? A little troll told you to? ![]() |
#278 |
Member#: 207118
Vehicle:2003 Wrx Wagon |
I have the dspecs with RCE wagon springs on my bugeye.
I did 'extensive' testing on my own, and could never quite get the balance right. There was always this bobble type, unbalanced feel to them. Another member helped me calculate settings based on the rce rates, and my bugeye weight. Here they are if they are helpful: these are settings with 58/42 weight distribution.. 90% - 3 3/16 front 4 13/16 rear 85% - 3 5/8 front 5 rear 80% - 4 1/16 front 5 7/16 rear 75% - 4 7/16 front 5 3/4 rear 50/50 is: 85% - 4 3/8 front 4 11/16 rear 80% - 4 3/4 front 5 rear 75% - 5 1/16 front 5 5/16 rear I know the car isn't 50/50, but for those that want to play around, useful to try out. Tends to flatten out the steering a bit. In any case - all of these settings tend to get rid of that annoying bobble between front and rear. I don't recall the RCE wagon rates off the top of my head though |
#279 |
Member#: 46135
Vehicle:02 WRX Powered by Sti V9 Spec C |
I don't know if anybody is going to read this posting burried in so many pages of settings, but it's not only about suspension:
If you have upgraded brakes, like I do, they are affected by weight transfer. If the d-specs provide flat braking, due to the front vs rear settings, like mines once did, the ABS system is affected by this. There's an article on Stoptech's page about upgraded brakes that deals with this. So I have Brembo GT front upgrade only, they were designed to work with the OEM rears. Not also with the modified weight transfer, due to the D-specs. At high speed strong braking, the rears don't lock up anymore and the fronts start locking early. Once I adjusted the d-specs to allow for some dive, the problem was alleviated. |
#280 |
Member#: 207561
South East
Vehicle:2005 WRB WRX WAGON PPG Trans |
That's very interesting. What type of settings on your dspecs did you go with to achieve the change in braking?
#281 |
Member#: 46135
5.5 front and rear.
#282 | |
Member#: 257490
Vehicle:2005 WRX Wagon CGM |
#283 |
Member#: 207561
South East
I think it's percent stiff
#284 |
Member#: 207561
South East
Well I finally got my Tokico's dialed in. I forget what I ended up with on turns, but I know I was doing quarter turns towards the end to dial it in.
2005 WAGON Tokico D-specs Wagon Take-off's Sedan Aluminum LCA's (the good ones) Whiteline Camber Plates Rolled Fenders Left Front: -1.8 Camber 5.0 Caster -0.05 Toe Right Front: -1.7 Camber 5.1 Caster -0.00 Toe Left Rear: -0.7 Camber 0.01 Toe Right Rear -0.8 Camber .11 Toe Thinking about camber bolts in the rear and pushing the front camber a little further but since its a DD I'm not sure at what point I should stop with the camber on the front. With the sedan LCA's should I be having the alignment tech put any of the settings in differently on the comp?? Last edited by bdj238; 10-30-2011 at 08:40 PM. Reason: question |
#285 | |
Member#: 133267
#286 |
Member#: 190502
International
Vehicle:2005 VF36 WRX |
2005 AUDM WRX sedan
2.5 turns front/ 3 turns rear STi Spec C RAR springs 340lbs/inch F, 285lbs/inch R Com-C front top hats, group N rear 24mm front swaybar, 22mm rear swaybar, TiC fender braces, loads of bushings, spaced lower control arm for caster, camber bolts in front, too many suspension mods to list and 125kg weight reduction. 17x7.5 +53 w/225/45/17 Kumho KU36 -3 deg camber f/0 toe f/6 deg caster -2 deg camber r/0 toe |
#287 |
Member#: 186129
Vehicle:2001 2.5RS STM |
2001 Impreza RS sedan
weighed in at 1765 lbs fr/1486 lbs r (54.3%/45.7%) (with driver) 5.5k fr/4.9k r Eibach springs (307 lbs/in, 273 lbs/in) on Ground Control perches 215/45/R17 Pilot Exalto PE2 on 17x7 FN01R-C wheels Whiteline 22-26mm rear sway on 22mm Stock top hats, stock front sway Solid end links, poly bushings. 4.75 fr/5.5 r (TFFF) I think I might be a bit underdamped... I run softer setting than many people with lower rate springs anyway. But if I try to go much more than another turn stiffer I have trouble with the rear end bounding up over bumps and skipping, and I also have trouble finding a good ratio between front and rear and I get a lot of pitching back and forth on wavey highways. I'm about to take it all apart and install Bakemono camber/caster plates all around. I had thought about going to softer springs, too, but they seem fine as long as I don't set the dampers too stiff. I didn't see many people in this thread running springs around 300 lbs/in, and the few that were seemed to have awfully stiff settings dialed in on the D-Specs. |
#288 |
Member#: 261832
Vehicle:06 WRX TR WRB |
06 WRX
Tanabe DF-210 springs Front - 5 turns from full stiff Rear - 6 turns from full stiff Camber -1* all around Had the D-Specs set poorly until I read this thread. Made me understand spring rates better when adjusting the D-Specs. Used to set them too stiff all over, and always stiffer in the back than the front. The difference is unbelievable now that I know what I am doing. |
#289 | |
Member#: 32459
Vehicle:02 WRX VF34 Junior Tuned 301whp |
02 WRX RCE yellow F/R = 5/5 (will try 4/4.5 next) Camber -2.5 front / -1 rear Caster: 3.6/4 Updated: what a difference 0.5 turn makes... went to 4.5/5 from 5/5 and it made noticeable difference. Last edited by txl146; 04-22-2012 at 06:23 PM. |
#290 |
Member#: 141991
Vehicle:08 STi AW 06 Saabaru 2.5i |
Current setup on my 05 saabaru wagon (same as a WRX):
Tokico D-Specs RCE Yellow Springs with 1/4" spacer in rear (spring rates: 295 lb/in front and 275 in/lb rear) DMS front Camber Plates and Group N rear top hats -3.0 deg camber in front -1.3 deg camber in rear +4.4 deg caster in front Current settings: 3 tffs in front 3.5 tffs in rear Seems pretty comfortable now, however I want the best setup for autox. I messed with a few settings at the last test n tune: 3 tffs front and 3.5 tffs rear (only one run) 2 front and 2.5 rear (only one run) 1 front and 1.5 rear (only one run) Went full stiff for the remaining ~5 runs ![]() I'm thinking that the 0 tffs was probably a bit too stiff ...anyone run theirs 0 tffs for autox? I'm curious to see how stiff people run them for autox. I think there is def a point that the springs are over dampened!Last edited by wrxsomeday; 06-07-2012 at 06:29 PM. |
#291 |
Member#: 207118
#292 | |
Member#: 207118
Those are all too stiff for the RCE's - see Tic's comment above - the range is 4 to 5 for the most part. Your wagon is probably pretty close to mine Try 4 3/8 front 4 11/16 rear Keep in mind there is really only 1 setting that is 'ideal', so changing for autox might 'feel' better, but your best gripping setup is going to feel softer than what you are using now and don't bother going stiffer than 4. Even a 1/8 or 1/16 turn can make big difference! |
#293 | |
Member#: 141991
However, it is worth mentioning that I am still on stock sway bars, and I'm probably seeing "gains" from stiffening because it is dialing out some of that body roll. It was discussed in here before somewhere that stiffening the struts to reduce body roll is NOT the correct mechanism for reducing body roll...sway bars are. I guess its also worth mentioning that I got some "funky" tire wear (ie shredding in the middle of the tire) from the first autox when I had the struts at 0 (probably had tire pressures a bit high too). Sure, I am seeing from gains from over-dampening, however I will probably see an even bigger gain in handling with bigger sway bars and the proper dampening. Ultimately, I'm going to need to upgrade my swaybars and keep the d-specs around the 4-5 range! Thanks all for the insight ![]() |
#294 |
Member#: 139289
Vehicle:2003 WRX Wagon PSM |
I've searched this thread and cannot find an answer if dspecs will work on my 2003 Wexford wagon with a set of aftermarket camber bolts? I'm assuming the fronts will be fine? I'll be running rce wagon specific springs if that matters at all
#295 | |
Member#: 141991
But YES the Tokico D-specs will work on your wagon (I have them installed on my wagon). The only thing to keep in mind is that you will lose about 0.7 degrees of negative camber in the front. The D-Specs are designed for WRX sedans, and since sedans have a slightly wider track in the front, you lose some negative camber when using a strut designed for a sedan (d-spec) on a wagon. You can regain some of this camber this by installing sedan control arms, using camber plates in the front (Whiteline also makes top hats called the Com C, which offers more camber and caster. They are not adjustable, yet they offer some comfort and are fairly reasonably priced), or even aftermarket camber bolts in the front (to be used in the bottom hole only! - and retain the stock camber bolts in the upper hole). Since you already have camber bolts, here is an excellent thread to answer any questions that you may have about camber bolts: http://forums.nasioc.com/forums/show....php?t=1590221 hope this info helps...and remember...search is your friend. |
#296 |
Member#: 27896
Vehicle:2003 WRX Wagon Silver |
I keep seeing people refer to a "break in period" here. I recently had a set of d-specs installed and couldnt find any mention of a break in period in the manual so I called Tokico. The tech there said there was no break in period necessary for these struts.
Just thought I'd throw that out there. |
#297 |
Member#: 229840
Vehicle:03 wrx MBP black |
2003 wrx with 97,000 miles
RCE yellows with group n tophats Whiteline 24 swaybar in front, rallytek 24 swaybar in back Upper strut bars front and rear Continental extreme contact DWS tires in "too heavy" enkei 17 inch EVO 6 wheels Steering, diff, outrigger bushing and botox bolts 4 1/2 f and 4 3/4 r seems best so far Started off at 5 all around for 100 miles. Rode awesome, started increasing stiffness too much (3ish range), then softened it up too much (6ish range)... As stated above "best" setting should be between 4-5 depending on mods, roads, weight, and driving style Further tinkering and fine tuning to come after alignment in a couple days and ill update settings Much thanks to Tony, Clint and the rest of the crew at TIC for the products, direction, and advice! Last edited by 03blackwrx02yellowsv; 09-09-2012 at 12:52 PM. |
#298 |
Member#: 97732
RMIC
Vehicle:2004 STi 65 Nova 9.46@142 |
Anyone have any insight into settings with a set of Prodrive red's?
Nearest I can tell the spring rates on the reds are 215 F / 195 R or close to 240 F / 220 R. If they're an actual 25% increase over stock like stated by Prodrive. Last edited by haberkorn; 10-04-2012 at 12:50 PM. |
#299 |
Member#: 46135
I looked into theose 1 year ago. I think there were two generations, one for the '04 Sti and one for 06+, in addition to the blues for WRX.
The later ones were said to be better. I could probably not dig again where I've read this, was burried somewhere. There were reds for V7 Sti as well, but the guy that was selling them on ebay.co.uk refused to answer my questions so I passed. |
#300 |
Member#: 97732
RMIC
I've got the 04 models, I bought them new so I could read the serial number on them clear as day. Prodrive seems to have never published their spring rate spec's just stated they were a "25% increase over stock".
I just want get them set up the first time instead of ripping the back seat out every other day to make a change heh. |
| Thread Tools | |
| Display Modes | |
| Gauging interest: Tokico D-spec + new Swift R-spec springs | Turn in Concepts | Vendor 'Group Buy' Classifieds | 45 | 03-09-2008 10:55 PM |
| ONE SET Tokico D Spec IN STOCK ON SALE. + Koni inserts & Crucial Springs in stock! | Crucial Racing | Suspension/Brakes/Handling | 7 | 10-26-2007 02:07 PM |
| what are your tokico d-spec settings? | ASpec818 | Brakes, Steering & Suspension | 7 | 07-30-2006 06:26 PM |
| Tokico D-Specs? | BAC5.2 | Brakes, Steering & Suspension | 2 | 11-02-2004 06:28 PM |
| Tokico d-spec struts | pyropretz | Brakes, Steering & Suspension | 12 | 09-22-2004 03:32 PM |
