Old 10-28-2011, 03:55 PM   #1
lolhonda
Member#: 280407
Default gc8 v7/v8 swap questions
I have a 1995 impreza L with a 1994jdm legacy swap in it but the swap is old and the motor has a ticking noise in it so I'm thinking about starting fresh and doing a v7 or v8 sti swap. . . If I got a usdm sti harness would it all be plug and play with the motor and ecu? And do you think this swap is a good choice? Any helps appreiciated.. . .
lolhonda is offline   Reply With Quote
Old 10-28-2011, 05:06 PM   #2
kaos200
Member#: 2692
If you mean you are looking to use a USDM STi engine, try not to use the "v7 or v8" etc labels. They will confuse you and people you ask for help.
Personally, if you live anywhere in the US with smog restrictions. Get yourself a USDM motor and wiring harness, swap it in and call it a day.
kaos200 is offline   Reply With Quote
Old 10-28-2011, 06:23 PM   #3
lolhonda
Member#: 280407
My bad. . I have yet to be able to find a usdm sti motor for under $5k
Old 10-28-2011, 07:02 PM   #4
kaos200
Member#: 2692
For just the engine?? Keep looking, that's way too much.
Old 10-30-2011, 10:10 AM   #5
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
also consider that your 95 transmission/rear diff won't last long with that sort of power
i have a set of chewed up spider gears from an open diff right here on my monitor
Old 10-31-2011, 07:36 PM   #6
181stLeader
Member#: 184183
1995 Impreza RSTi
Ver.8 EJ207 Bright Blue
An 02-05 wrx harness will run a version 7 or 8 motor perfectly. You will only need to add a few wires and switch a few pins in various connectors to enable AVCS(as well as a v7 or v8 ECU).
181stLeader is offline   Reply With Quote
Old 10-31-2011, 11:13 PM   #7
lolhonda
Member#: 280407
If I got a wrx harness and iaperformances avcs wiring kit how many more wires/ connections would I have to make?
Old 11-03-2011, 11:35 AM   #8
i2cou4u2
Member#: 246455
2004 WRX Wagon
That is all that is needed for the AVCS to function properly.
i2cou4u2 is offline   Reply With Quote
Old 11-03-2011, 12:16 PM   #9
kaos200
Member#: 2692
Using a USDM wrx harness, on a JDM drive by cable sti engine. Not on a USDM STi engine.
Just wanted to clarify again. It's not clear which he is really going after by reading his posts.
Old 11-04-2011, 01:20 AM   #10
i2cou4u2
Member#: 246455
2004 WRX Wagon
I have recently done this swap into a 2004 WRX, if you have any questions feel free to pm me.
V7 trans swap question 02mbp Transmission (AT/MT) & Driveline 1 09-06-2011 02:02 PM
FS:NY - 2002 WRX v7/v8 swapped 66k miles penusai Private Vehicle 'For Sale' Classifieds 7 04-14-2010 01:02 AM
V8 Swap Questions hexadec0079 Legacy Forum 25 11-27-2006 11:25 PM
WTB: JDM V7...V8 or USDM V8 complete engine swap killawhiterex Private 'Wanted' Classifieds 4 11-15-2005 12:38 PM
OBS v7 or v8 swap linux>windows Subaru Conversions 2 01-29-2004 05:09 PM
Message Board Statistics All times are GMT -4. The time now is 03:58 AM.
