Old 10-19-2011, 05:19 PM   #51
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
good deal man. i know what you mean by being down. mine has been down since jan of this year. i'm about 80% done with mine at this point. i'm running utec also but was thinking opensource...
spoolinred is offline   Reply With Quote
Old 10-21-2011, 06:45 PM   #52
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
You need Opensource even with the Utec to handle all of the idle and lower RPM management anyways. Car is going to run a bit rough with 1680CC Injectors without it.
TAPOUT is offline   Reply With Quote
Old 10-21-2011, 07:14 PM   #53
Matt_H
Member#: 107000
2008 STI <3 TXS and
2011 F150 Andrewtech
Ytdiamond05's car is still running just the stock ECU for now and it's idling pretty good. I don't think he's running 1600's though, I think 1200s.
Matt_H is offline   Reply With Quote
Old 10-29-2011, 12:11 PM   #54
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
Mine is fired up and running. I am going to have an AEM wideband put in, and then try to get tuned in the next week or so.
Old 10-29-2011, 05:19 PM   #55
modusvivendi
Member#: 214073
2008 Impreza WRX STi
Bsatin white pearl
subscribed
modusvivendi is offline   Reply With Quote
Old 10-31-2011, 12:44 PM   #56
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
good to hear, tune vids are nice...haha. who is doing the tuning?
Old 11-04-2011, 07:40 PM   #57
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
I drove it home tonight. I need to tweak some stuff over the weekend and change the front brakes. I am hoping to start basic adjustments tomorrow for the drive-ability and then we will get some dyno time after I get it through emissions and inspection. Drive first, fly later!
Old 11-04-2011, 07:45 PM   #58
Matt_H
Member#: 107000
2008 STI <3 TXS and
His car is finally street legal now as of today. Emissions done yesterday, inspection last week and new tags today. Should be done with break-in in no time.
Old 11-04-2011, 08:31 PM   #59
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
There it is!
Old 11-04-2011, 09:33 PM   #60
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
on e85@ 30psi--spinning
I would put something to shield that air filter from all the hot air coming from the radiator.No to be injesting hot air compressing it and making it hotter and then expecting the fmic to efficiently cool down the charge.Just a thought to help you out.Also the air intake may be a restriction being 3",may not be able to supply the turbo with the volume of air it will want.
john 1badSTI is offline   Reply With Quote
Old 11-05-2011, 01:28 AM   #61
maxpowr
Member#: 159243
sg3 Turbo Tek Tuned
Hakt Ecu e85 30r 6spd
subscrib'd for big powa.
Old 11-05-2011, 04:32 PM   #62
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
We reused the air intake tube since it was part of the last kit. I may have a 4" one built in the very near future. I figures it would be good enough to get the car back on the road and sorted out. I had a scoop from the stock air box made to send fresh air over to the side, but it is missing. I may make another.
Old 11-05-2011, 04:57 PM   #63
OVeRBOOSTn
Member#: 192514
04 STi PTE6765
10.1@138mph / JR Tuned
i have this turbo on my EVO the HTA88 gt37r love it!
OVeRBOOSTn is offline   Reply With Quote
Old 11-05-2011, 07:01 PM   #64
john 1badSTI
Member#: 77470
04 sti 10.51@138.5
cool at least you know what you need to do to make the setup as efficient as possible.Iam looking forward to your results and hope they are what you are expecting. good luck and keep us in the loop.
Old 11-05-2011, 08:31 PM   #65
Crystal_Imprezav
Member#: 84105
2005 Super Slow STi
Interested to see how the spool will be.
Crystal_Imprezav is offline   Reply With Quote
Old 11-05-2011, 10:25 PM   #66
Junior2JZ
Member#: 64908
10.8 XT+ Real stock
turbo record holder 11.4
Your hta88 is a little different on the hotside wheel.
I posted the spool up on this thing last Nov, honestly it sucked. I was very unamused with the turbo. In 4th gear it was in the low 5k range and the power output was not much better then an ht86, especially once you take into consideration the loss of rpm down low and TQ.
Old 11-06-2011, 09:22 AM   #67
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
If this thing doesn't do what I want on it's own, I will be adding nitrous.
I don't care if the power band is shifted to the right as long as I can still get the power band. I am willing to spin this thing to 9K if I have to. That will still give me a useable power band. Spool up doesn't matter if you are launching from 7500 RPM.
Old 11-06-2011, 05:05 PM   #68
spoolinred
Member#: 117017
03 2.0fpred wrx!!
blue
^^ classic!! played around with my buddy"s k swapped turboed hatch this weekend, i set his rev limit at 11k <<< yes 11 thousand and his launch at 8k. be nice for that kinda rev's..
cant wait to see the results.....
Old 12-14-2011, 11:16 PM   #69
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
Sorry about the sideways picture. We did our initial tuning to get things dialed in.
Waste gate pressure only, 93 octane, 21-22 psi. Notice that this is an HTA GT3794 and it is making full boost by 4200 RPM! Power band on this run is revving to 8500. Where is all of the lag everyone keeps speaking of?
Old 12-16-2011, 08:20 AM   #70
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
Did the initial tuning at Mach V. 28lbs tapering to 26. Still just pump gas. Very conservative tune.
Let me know what you think. I am picking up the car either this afternoon or tomorrow. It looks like it will be a blast to drive.
Old 12-16-2011, 09:26 AM   #71
stretchedk7
Member#: 170602
06 Wrx 6Spd TSBorg
Warner S400-Aem-2200s
wow. spool looks very good. jeeez im impressed. Sorta surprised it didint make more power though but I guess it wants more boost. Also the 93 might be some of it or the safe tune.
Let us know how it feels
Old 12-16-2011, 09:49 AM   #72
CatfaceType-R
Member#: 81102
If u are looking for sub 600whp, maps new turbo kills this for spool. Forgot the name of it, it's on map's site. Just saw an amazing test on a 2.4l evo and the spool/power potential is AMAZING, especially if we use it on a 2.5 I bet
Old 12-16-2011, 10:15 AM   #73
stretchedk7
Member#: 170602
06 Wrx 6Spd TSBorg
whats up carmi ^ and what turbo? its not the hta86 right?
Old 12-16-2011, 11:18 AM   #74
shano
Member#: 223839
2004 WRX
Java black
Interesting....
Pumped to see the meth and c16 tunes.
shano is offline   Reply With Quote
Old 12-22-2011, 08:11 AM   #75
TAPOUT
Member#: 127670
2007 HTA GT3794
Darton Sleeved
So I picked the car up on Tuesday, and this thing really spools fast on the street. It spools faster than the old GT35 did and it just keeps pulling! I have made a couple runs through 3rd and 4th which got scary when I went over just a tiny bump on the road and spun the tires at 90. I can get to full boost in 5th gear by 4K rpm. The way it passes on the highway by just steady tipping in with 5th gear is amazing. I am probably going to drive it as it is for the next couple of weeks and then take it back to work on the meth tunes and maybe get to the C16.
FP HTA gt3076r sburck Factory 2.5L Turbo Powertrain 54 07-10-2010 10:31 PM
FP HTA GT35 Turbo kato4276 Factory 2.5L Turbo Powertrain 18 06-30-2009 12:41 PM
FS: Feeler: PA , FP HTA Green 3" Anti-Surge 8cm^2 EWG Turbo < 500 miles Merp Engine/Power/Exhaust 26 05-13-2009 07:51 PM
FP HTA Green tested. AZScoobie Proven Power Bragging 216 11-10-2008 02:00 PM
FS: PA - FP HTA Green 3" inlet Mycues1982 Engine/Power/Exhaust 32 09-24-2008 03:41 PM
Message Board Statistics All times are GMT -4. The time now is 03:33 AM.
