Old 11-04-2011, 04:49 PM   #1
realplay
Member#: 295979
2004 wrx
blue
Default log check on 04 wrx jus went stage 2
Updated to stage 2 93 oct 310 log after 60 mile, 04 wrx dc sports DP stock intake.
https://docs.google.com/spreadsheet/...nVBUzB2TDVJeXc
realplay is offline   Reply With Quote
Old 11-05-2011, 08:59 AM   #2
Cobb Tuning
Member#: 4803
Log looks fine except that you are underboosting quite a bit. Are you at altitude at all? I would give the high wastegate HWG map a try, which you can download from our map repository:
http://www.cobbtuning.com/info/?ID=3061
Some of your long-term fuel trims (A/F Learning 1) are borderline (around 7%). Generally, these should be +/- 5% and anything outside of +/- 8% is likely a problem, so you are kind of in-between. I would consider getting a pressure (or smoke) test done of the intake to check for leaks and continue to keep an eye on A/F Learning 1. Another thing with these cars is a MAF sensor that degrades over time and progressively reads lower and lower, but your reported airflow is reasonable, so if this is an issue, it may be borderline as well.
Bill
Old 11-05-2011, 05:55 PM   #3
realplay
Member#: 295979
2004 wrx
blue
Thx u, would an exhaust leak cause me to under boost ?
Old 11-06-2011, 08:17 AM   #4
Cobb Tuning
Member#: 4803
No, but you do not want to be running around with an exhaust leak (i.e. carbon monoxide poisoning).
There is a lot of variation from the factory for these cars as far as hitting the boost target is concerned. I would give the HWG map a try and see if that improves things.
Bill
Old 11-07-2011, 03:13 PM   #5
realplay
Member#: 295979
2004 wrx
blue
Old 11-08-2011, 10:17 AM   #6
Cobb Tuning
Member#: 4803
Boost looks a little better, but you have some knock events during the WOT run. In your first log, the long-term fuel trims are still trending positive and some of them are borderline. I would do a pressure test of the intake to rule out any intake leaks. I would also switch to the ACN91 map for now until you get it figured out.
Bill
Old 11-08-2011, 11:04 AM   #7
realplay
Member#: 295979
2004 wrx
blue
So do I reflash it to that or run it realtime
Old 11-08-2011, 11:49 AM   #8
Cobb Tuning
Member#: 4803
I would go ahead and reflash it.
Bill
Log Check Please 2004 WRX 93 Octane on Stage 1 91 Tune jmikeumo AccessPort 21 11-06-2011 08:12 AM
FS : CA: 04 WRX 4EAT, cobb stage 2 jabba827 Private Vehicle 'For Sale' Classifieds 2 03-08-2011 08:14 PM
04 STI Turbo back OK for stage 2 on 04 WRX? Cryogenicstudios Newbies & FAQs 3 06-22-2007 08:15 PM
04 WRX w/ TXS stage 2 dyno results Jay04WRX New England Impreza Club Forum -- NESIC 27 07-07-2003 02:30 PM
04 WRX w/ TXS stage 2 dyno results Jay04WRX Proven Power Bragging 3 07-06-2003 08:39 PM
