Old 11-06-2011, 06:13 PM   #1
GC8WSI
Member#: 92857
2000 Swapped GC8 RS
BRP
Default 09 WRX into 05 LGT: Help Needed
Hey guys.
Long story short, I just swapped in an 09 WRX motor into an 05 LGT. I left the air pump disconnected. The front oxygen sensor was different, so I retained the LGT one because the other wouldn't plug in. There were a few other small differences like the AC compressor and bracket, serpentine belt, the evap fuel line, and other irrelevant things.
I just went to prime it (unplugged injectors, key on, engine off) and the fans are kicking on high. The temperature gauge Bee-lined it to the H, yet the car has been sitting for about two weeks and I haven't even started it yet, so I know it's not actually overheating.
Now it's not even starting. Turns over strong, all lights are on, cranking sounds great (fuel, air, compression confirmed), but it won't start.
My thoughts? There's some difference in the wiring harness of the intake manifold, or maybe some related sensors, that's not allowing the car to start.
Any ideas?
GC8WSI is offline   Reply With Quote
Old 11-07-2011, 03:14 PM   #2
kaos200
Member#: 2692
Any ideas?
So which engine harness are you running. You should be retaining all the LGT wiring.
kaos200 is offline   Reply With Quote
Old 11-11-2011, 08:30 AM   #3
GC8WSI
Member#: 92857
2000 Swapped GC8 RS
BRP
Got it by myself
06 STi Swap into 05 RS. Help me with my grey areas please. STIKindaGUY Subaru Conversions 21 06-19-2014 09:03 PM
09 WRX turboxs CBE.....anything else needed? TEK112 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 08-31-2009 12:58 PM
09 wrx or 05/06 sti milab21 General Community 16 10-24-2008 10:11 AM
09 WRX in Maine, Winter tires needed? UllSang Newbies & FAQs 6 09-25-2008 09:05 PM
Interior Swap Compatibility: 05 WRX into 05 STi ??? worksti Interior & Exterior Modification 3 08-06-2007 03:40 AM
