Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Old 11-02-2005, 09:42 PM   #1
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Question CEL code P0113 and P0102 together
Car : 2002 WRX
Codes thrown : P0102 - MAF Circuit Low Input
: P0113 - Intake Air Temp Circuit High Input
Car's been idleing rough and stalling intermittently - always stalls if air intake filter is blown on (seriously..at idle if I blow on filter {Like a birthday cake} it will die everytime)
Direct relation to CEL's, here?
I searched the "Big Code Thread", but found no P0113, and no solution to the P0102. Any ideas here? I've already swapped out the maf sensor...that wasn't it. Thanks.
kingtut12 is offline   Reply With Quote
Old 11-02-2005, 11:38 PM   #2
SonnyCrockett04
Member#: 48838
2008 Stage 2 STI
A.W.
I had a P0102 code not to long ago and all it was, was my MAF connector was loose. Not sure about your other code though.
SonnyCrockett04 is offline   Reply With Quote
Old 11-03-2005, 09:02 AM   #3
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
I believe the connector is fine, but I'll double check. Anyone else have ideas? Thanks.
Old 11-03-2005, 10:53 AM   #4
waktasz
Member#: 86356
2015 s1000r
wheelie monster
I don't know if it could be it or not, but someone is bound to post 'clean your MAF' sooner or later.
waktasz is offline   Reply With Quote
Old 11-03-2005, 07:27 PM   #5
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
Yeah, I looked at it and it appears brand new. But, I can clean it anyway. The Big Maf sensor has what appears to be a hardened bead of oil on the tip of the sensor, but I found out that this is normal. One of the codes mention Air Intake Temp. Where is the Intake temp. sensor or module? Is there one? Can it be replaced?
Old 11-03-2005, 07:43 PM   #6
kingtut12
Member#: 81123
2002 2.5 WRX BY
RIP 02' 2.5WRX PSM
According to the service manual, the air intake temp sensor and mass air flow sensor are the same thing. I've already swapped the Maf out, and it did not help, so plan B?
Old 04-08-2009, 02:15 PM   #7
jaysbluewrx
Member#: 197521
hads anyone figured this out yet i have the same problem and im stumped i bought a new MAF changed out the o2 sensor in the manifold checked for cracks in the stock manifold but i cant get the car to run smooth for anything and i cant get rid of the codes
jaysbluewrx is offline   Reply With Quote
Old 06-05-2011, 08:49 PM   #8
dblurx02
Member#: 113703
02 WRX
Midnight Blue Pearl
Bumping this to the top, only because my car is doing this now too. Same year and same issues. I have tried cleaning the MAF and the filter w/o oil. Im so lost.
dblurx02 is offline   Reply With Quote
Old 06-29-2011, 03:04 AM   #9
shultz2
Member#: 213772
2013 BRZ
i just got these codes same year, but mine only came on after i installed a new turbo inlet
shultz2 is offline   Reply With Quote
Old 06-29-2011, 12:07 PM   #10
Haelan
Member#: 151045
2013 Subaru STI
CBP
Check the harness plug for the MAF. If it was jammed onto the sensor at a weird angle one or more of the connector pins can be pushed out of the harness.
Haelan is offline   Reply With Quote
Old 07-02-2011, 10:22 PM   #11
scooter11
Member#: 177147
2008 wrx
dgm
Dang, I just got my built motor running and I have these codes. Car runs like dog crap.
scooter11 is offline   Reply With Quote
Old 08-12-2011, 01:14 PM   #12
kariusvega
Member#: 269611
2005 WRX STi
anyone figured this one out?? i have my 05 at the dealership currently with these two very codes and the same issue. they are stumped at the moment.. once they or i figure it out i will be sure to post.
kariusvega is offline   Reply With Quote
Old 08-14-2011, 09:38 PM   #13
future_subaru_owner
Member#: 172939
2011 Dodge Ram 3500
2003 Subaru Legacy L..ame
Please do i just droppped in my hybrid build, and i have these 2 codes. I'm assuming that's why it won't start.
future_subaru_owner is offline   Reply With Quote
Old 11-20-2011, 01:17 PM   #14
rotheee
Member#: 291964
2003 WRX
I am running into the same codes! anyone get their fixed? I'm also not able to reach full boost, maybe 15psi. Car is tuned at 22psi. Don't know if this is a syptom of the CEL codes. Tried doing a boost leak test, didn't find anything.
rotheee is offline   Reply With Quote
Old 11-20-2011, 03:26 PM   #15
666stars
Member#: 221364
2002 Wrx EJ207 Ver 8
Wrb Dccd 5 speed now!
Check main connection near battery for loose wires. The wire that's green with a black stripe is the ground for all those sensors on the intake manifold. Also if it won't start make sure all the connectors to the ecu are fully plugged in
666stars is offline   Reply With Quote
Old 11-20-2011, 10:20 PM   #16
vtrex2009
Member#: 301577
Check your IACV. The gasket may be broken. Or you may need to clean it. Make sure that you have a spare IACV gasket handy though. I threw a similar code in the summer. Cleaned my IACV and it went away.
Any recent mods?
If you ran a scan with a Cobb Accessport make sure your connections were correct with the Accessport.
Also, when you clean your MAF, clean the two little wires inside too.
Good Luck
vtrex2009 is offline   Reply With Quote
Old 11-20-2011, 11:24 PM   #17
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
Any recent mods?
Good Luck
dont think these guys have anything wrong with their iacv
Old 03-31-2012, 12:07 AM   #18
aggie113
Member#: 146311
Saab '05 HTA68 Built
2.5L E85 6MT > STI :)
Well I am now throwing these codes as well. I just got back from a 4 hour drive, stopped home (turned off for a minute) then ran back out to town and just driving normally the car started to stutter and I could not get it to run for more than a few seconds afterwards. Currently sitting in my garage after having it towed back home
Going to take the front bumper off tomorrow to check all the connections for the FMIC as it behaved like this when one of the hoses popped off in the past.
Edit: Ok, freaking out a bit less now. The car idled fine with the MAF unplugged and when I went to disconnect the top pipe of the FMIC setup to get to the MAF to check it I realized the hose going down to the FMIC is loose (as in off) and flopping around. So tomorrow I was planning to take my front bumper off anyway to check the wiring for my fog lights which stopped working a few months back anyway Glad it happened close to home and not earlier in the the day when I was 100 miles away.
aggie113 is offline   Reply With Quote
Old 03-31-2012, 05:58 PM   #19
aggie113
Member#: 146311
Issue fixed, cleared the codes, put everything back together and it's running fine. Ordered some T clamps to replace the ones that APS provided with the kit, don't need this happening a third time!
Old 11-12-2012, 09:48 PM   #20
Dailoh
Member#: 310149
2012 WRX base Sedan
I have a 2012 WRX. I replaced the air box filter today with another OEM one. After start up I blew a CEL and the cruise control light started blinking. Luckily I was at my friend's shop and we scanned the code. Same thing as here, P0102 and P0113. We checked the MAF and it was plugged in correctly. We took the air box and all others that are connected to it apart and put it all back together. We cleared the code with the scanner and the CEL never came back on. But the scanner is showing a soft code for it still. I did 2 pulls (to target boost PSI) when the road was clear and the PSI was fine and the car did not studder or anything. I am kinda of disheartened since this is still less than a year old. Please help, thanks in advance.
Dailoh is offline   Reply With Quote
Old 11-12-2012, 09:52 PM   #21
Haelan
Member#: 151045
2013 Subaru STI
CBP
Originally Posted by Dailoh View Post
I have a 2012 WRX. I replaced the air box filter today with another OEM one. After start up I blew a CEL and the cruise control light started blinking. Luckily I was at my friend's shop and we scanned the code. Same thing as here, P0102 and P0113. We checked the MAF and it was plugged in correctly. We took the air box and all others that are connected to it apart and put it all back together. We cleared the code with the scanner and the CEL never came back on. But the scanner is showing a soft code for it still. I am kinda of disheartened since this is still less than a year old. Please help, thanks in advance.
Check the electrical connection to the MAF. The sensor isn't getting power. Could be a bent pin.
Old 06-27-2013, 07:20 AM   #22
Krisxcore
Member#: 351693
any one have any more info on fixing this? I'm getting the same two codes and I'm not sure what to do.
Krisxcore is offline   Reply With Quote
Old 10-11-2013, 08:50 PM   #23
edward_02
Member#: 370717
Chapter/Region: PRSIC
2002 Wrx
Sedona red
same codes and same issues , anyone came up with an answer to this ?
edward_02 is offline   Reply With Quote
Old 10-20-2013, 03:48 PM   #24
urabuster
Member#: 266578
2003 WRX Sportwagon
I'd like to bump this one up for an answer too!
urabuster is offline   Reply With Quote
Old 12-03-2013, 03:27 PM   #25
larkenyceWRX
Member#: 373835
This exactly where I'm at. I was getting a crank no start issue. I was trouble shooting and so now I have the maf low input and the air intake temp. With with smoke. I'm stumped. Anyone with any solid input please shed light.
larkenyceWRX is offline   Reply With Quote
Need help with CEL codes 170 and 141 Rich L Normally Aspirated with bolt-on Forced Induction Powertrain 4 12-02-2008 08:16 PM
P0113 and P0102 after MAF clean speedin Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 05-28-2008 11:05 PM
swapped to modified deatschwerk injectors - now CEL codes p0103 and p0113? anthonyrb98 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 11-23-2006 04:07 PM
Cel codes p0122 and p0442 turbocolin Tri-State Area Forum 3 03-22-2005 09:00 PM
Causes of CEL codes P0122 and P1133 nytoy Normally Aspirated Powertrain 5 12-27-2004 02:12 PM
