Welcome to the North American Subaru Impreza Owners Club Wednesday December 7, 2016
Old 11-23-2011, 12:43 AM   #1
1hotsubaru
Member#: 244748
2002 WRB Impreza WRX
"aka" NGRY REX
Default ej20g motor with USDM WRX transmission??
Hey guys, got a quick question. I know that I can fit the older EJ20G motor into my transmission, but what would I need to make it work properly?? Since I will be using my transmission, I wouldn't need a new clutch assembly, rear differential, master slave cylinder, etc. right? Glad if someone could give me some insight.
1hotsubaru is offline   Reply With Quote
Old 11-23-2011, 02:16 AM   #2
DHRDAN
Member#: 204358
01 2.5RS W/ EJ257
....sigh... tranny always follows the rear.
If you're just changing the engine.... the rest will fit.
Subaru didn't change clutch types till the v8. ... so you're fine.
DHRDAN is offline   Reply With Quote
Old 11-23-2011, 09:34 AM   #3
1hotsubaru
Member#: 244748
"aka" NGRY REX
Really? That's probably the route I'll go then. I know some people say that the long block won't fit because the 02 wrx intake manifold doesnt work with the ej20g, but that's why I just want to get a motor with the wiring harness. Anyone else got some insight?
Old 11-23-2011, 01:12 PM   #4
RallyColtTurbo
Member#: 16819
There will be a missing bolt hole on the motor for the second starter bolt.
Early tranmissions had stud on the trans and no hole on the motor.
Later transmissions used a long bolt through the bellhousing and a matching threaded hole on the block. So some fabrication will be involved....a search should turn up what others have done.
Not quite sure of your plan, but USDM WRX wiring and ECU will not control an early EJ20G. You should be able swap the cylinder heads and intake manifold and the crank sensor to the older motor. Basically just use the shortblock, but double check compression ratios and head gasket thickness to be sure.
RallyColtTurbo is offline   Reply With Quote
Old 11-24-2011, 05:13 PM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
you do know that a 02 ecu will NOT run an ej20G right?
Old 11-28-2011, 11:17 AM   #6
1hotsubaru
Member#: 244748
"aka" NGRY REX
Ok, that blows... I won't be able to fabricate anything for now, so I won't be able to go that route. I do like the idea of just using the ej20g block, but we'll see. Thanks!
Yes I'm aware of this. The engine I was looking at did come with an ECU. I think I'm just going to stay USDM for now.
3500rpm cut out - EJ20G with USDM WRX Ignition Coils BoostAddictPL Pre-2002 Factory Turbo Powertrain 17 11-24-2010 04:18 PM
FS: USDM WRX Transmission LegendaryHarry Private 'For Sale' Classifieds 43 07-17-2006 10:41 PM
Feeler- EJ20G motor with complete harness imprezdgc8 MAIC Private Classifieds 10 04-20-2006 12:42 AM
WRX with STi side splitter or STi with USDM WRX fogs subUrbanAuthority Member's Car Gallery 13 02-19-2005 03:53 AM
Can I run V7 motor with USDM WRX ecu? PRODRIVEN Subaru Conversions 30 11-14-2004 04:33 PM
