Old 12-06-2011, 01:02 PM   #1976
Benhart21
Member#: 149617
Whitford's LJ really makes me want to build an expedition style rig. If I could afford to, I'd do it to a 24v Ram diesel quad cab short bed, but since that's way too expensive, I think it'll be a Jeep WJ.
Benhart21 is online now   Reply With Quote
Old 12-07-2011, 11:58 PM   #1977
Whitford
Has never had a cavity
Member#: 97875
I don't know if I mentioned before but my car's blower motor was broken when I purchased it. The PO seemed to think it was a $500 job so he deducted that from the purchase price; he said it hadn't worked in about a year and never had the scratch to fix it.
So today, I took it to this mechanic I know here in the city. He's one of those 'best kept secret' types and resembles Yoda in more ways than one.
Anyway, he took a look at it and had the thing working within 5 minutes. The ****ing fan power switch was broken and was simply not turning the dial behind the climate controls.
I'm going to a dealership tomorrow to have the knob replaced. It will probably cost me $3.
I also stopped into Dirty Parts which is a 4X4 shopped recommended to me by a bartender friend as well as on JeepForum. After having already stopped into the local 4WheelParts retailer, Dirty Parts was like a breath of fresh air. Tiny place but stocked to the brim with cool, quality parts. Very knowledgeable staff as well.
I will definitely be doing a lot of work there.
Whitford is offline   Reply With Quote
Old 12-08-2011, 12:00 AM   #1978
Whitford
Member#: 97875
Hell yeah, man! I really like the WJ's.
Old 12-08-2011, 12:07 AM   #1979
2.5 SUBY
Member#: 78802
Anyone else bummed about Jamboree for the north east?! I was a few days late looking to register and they are all sold out. Not to mention Killington is level 6+ because of the hurricane.
2.5 SUBY is online now   Reply With Quote
Old 12-08-2011, 01:21 AM   #1980
Displaced
Member#: 142459
Blue plasticky
two door.
If 4x4 shops were medical conditions, 4WheelParts would be AIDS. So terrible.
Displaced is offline   Reply With Quote
Old 12-08-2011, 01:23 AM   #1981
Whitford
Member#: 97875
Tell us how you really feel.
Old 12-08-2011, 04:28 PM   #1982
mAdatee
Member#: 87922
2002 Impreza WRX
Jasper Greeeeeeen
After 270k miles a pitman arm essentially becomes part of the steering box... Ugh
Yup... Just broke a Matco pitman arm puller trying to get that bitch off.
Ih8mud.
mAdatee is offline   Reply With Quote
Old 12-08-2011, 04:42 PM   #1983
sorbee711
Member#: 14259
OT, we're a-holes
b/c we are bored at work
Originally Posted by Whitford View Post
I'm going to a dealership tomorrow to have the knob replaced. It will probably cost me $35.
Fixed for accuracy.
sorbee711 is offline   Reply With Quote
Old 12-08-2011, 06:08 PM   #1984
Whitford
Member#: 97875
Originally Posted by sorbee711 View Post
Fixed for accuracy.
It was $14.
Old 12-08-2011, 08:54 PM   #1985
Whitford
Member#: 97875
A noise developed today (or I just noticed it for the first time) from what seems to be my transmission.
At very low speeds I'm sometimes encountering a slight whine and then each time I come to a stop, there's a sort of decelerating whine/howl that's fairly quiet. Any ideas as to what this could be? Planetary gears?
Thanks.
Old 12-08-2011, 08:56 PM   #1986
PGT
Member#: 57283
2012 300C SRT8 &
Unlimited Rubicon MW3
diffs?
did you get a manual? if so, does the noise continue if you put the clutch in?
PGT is offline   Reply With Quote
Old 12-08-2011, 08:57 PM   #1987
Whitford
Member#: 97875
Originally Posted by PGT View Post
diffs?
It's an automatic.
Old 12-08-2011, 09:02 PM   #1988
Joe Boxer
Member#: 63119
** Memoirs of a
Serial Bachelor**
Any idea where the noise is coming from? If it sounds like it's coming from the center of the vehicle, you may be right. Given how you described it, I want to side with Dan... diff/axle-related.
Joe Boxer is offline   Reply With Quote
Old 12-08-2011, 09:07 PM   #1989
Whitford
Member#: 97875
It sounds like it's coming from the center of the Jeep, right under and a little in front of the shift lever.
Thanks, guys. I'm hoping it's not a sign of the transmission being on the way out. When I had it looked at before buying it the mechanic said the tranny looked fine.
Old 12-08-2011, 10:52 PM   #1990
Whitford
Member#: 97875
Just took it out for a drive so I could record the sound and it wasn't happening anymore. Weird, maybe it was a fluke?
Old 12-09-2011, 11:55 PM   #1991
Whitford
Member#: 97875
I encountered the noise again so I recorded it:
Any ideas? It happens whether I am in gear or not, and only when the car is moving forward.
Old 12-09-2011, 11:59 PM   #1992
mAdatee
Member#: 87922
2002 Impreza WRX
Jasper Greeeeeeen
It's a jeep, turn the radio up.
Old 12-10-2011, 12:01 AM   #1993
Whitford
Member#: 97875
Oh it doesn't bother me, I just want to make sure my transmission is not in trouble.
Old 12-10-2011, 12:05 AM   #1994
mAdatee
Member#: 87922
2002 Impreza WRX
Jasper Greeeeeeen
I had a U-joint fail on my old Toyota pick up that sounded similar to that.
Old 12-10-2011, 12:09 AM   #1995
Whitford
Member#: 97875
Oh yeah? Did it happen when you were coming to a stop?
Old 12-10-2011, 08:30 AM   #1996
mAdatee
Member#: 87922
2002 Impreza WRX
Jasper Greeeeeeen
Meeeeh, it was more of a constant noise exaggerated by breaking.
Easy way to check is to get under there and start yanking on things with U-joints to see if there's any play... But I think I'm wrong now that I've reconsidered it without alcohol.
Old 12-10-2011, 10:10 AM   #1997
mAdatee
Member#: 87922
2002 Impreza WRX
Jasper Greeeeeeen
Maybe weight transfer caused by decel is making something that's loose rub. Like the body on the frame or a worn out suspension part. I'll run it by some of the guys at work and see what they think.
Old 12-10-2011, 01:36 PM   #1998
eg33GC
Member#: 206851
99 V4
EJ20K RS
So I've been wanting to do the 3" Rusty front coils and shocks w/ AAL on my XJ, someone deter me from doing so.
Old 12-10-2011, 03:22 PM   #1999
Whitford
Member#: 97875
Thanks, man. I really appreciate it.
Old 12-10-2011, 03:47 PM   #2000
Shavenyak
Member#: 7156
1999 Jeep Cherokee
It was $14.
I've gone through 3 of those.
Shavenyak is offline   Reply With Quote
with all the gay and straight threads [27] Off-Topic 27 05-08-2013 06:31 PM
the Official Rally/Off-Road thread? Longitude Member's Car Gallery 178 09-05-2006 05:39 PM
Why all the bestiality and dehydration threads today??? Grap Off-Topic 15 01-11-2006 03:55 PM
this site is dwindling (aka: The piss and moan thread v.2) stevedood Bay Area Impreza Club Forum -- BAIC 59 04-01-2004 12:38 AM
A lazy monday thread...A continuation of the saturday and sunday thread DoctorNick Mid West Subaru Owners Club Forum -- MWSOC 9 09-10-2002 08:17 AM
Message Board Statistics All times are GMT -4. The time now is 02:05 AM.
