Old 12-06-2011, 08:27 AM   #26
WRXKurt
Member#: 215114
09 WRX Sedan
Pearl White
Now that is impressive. Keep up the great work.
WRXKurt is offline   Reply With Quote
Old 12-07-2011, 03:53 PM   #27
207STi
Member#: 197062
1998 Swapped Impreza
black
The is about 900000000000x cooler than any LS series motor swap could ever dream about.
207STi is online now   Reply With Quote
Old 12-07-2011, 04:08 PM   #28
emsalex
Member#: 296665
97 leg OB wagon
black/purp
twin ls motors with twin turbos, one in back one in front? 2400 awhp
emsalex is offline   Reply With Quote
Old 12-07-2011, 11:48 PM   #29
godfather2112
Kate Upton Fan Club
Member#: 53794
.... Your only
topless moderator.
So uh, what is the stock hp?
godfather2112 is offline   Reply With Quote
Old 12-08-2011, 05:51 AM   #30
jzk25
Member#: 179120
No wiki in the US?
jzk25 is offline   Reply With Quote
Old 12-08-2011, 10:31 AM   #31
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Old 12-08-2011, 02:27 PM   #32
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Damn, 300 ft./lb. from 1200 rpm........ouch, my neck.
~Josh~
ballitch is offline   Reply With Quote
Old 12-08-2011, 03:07 PM   #33
meifert
Member#: 301676
2009 Forester XT
~Josh~
makes me want to fap.....nothing feels better than a boatload of torque.
Horsepower sells cars.....torque wins races. -Enzo Ferrarri
meifert is offline   Reply With Quote
Old 12-08-2011, 03:09 PM   #34
V8Slayer
Member#: 111565
1999 Legacy 2.5GT
Boosted & meth injection!
Definitely a nice build, what does the owner plan to do with it?
V8Slayer is offline   Reply With Quote
Old 12-08-2011, 03:28 PM   #35
BLITZKRG-RS
Member#: 1332
2004 STi
holyf*ck! this is some sick stuff!! mad props!!
*subscribed*
can't wait to see when everything is completed and fire up!
BLITZKRG-RS is offline   Reply With Quote
Old 12-08-2011, 03:47 PM   #36
REX8
Member#: 24038
You got the wrong quote wrong!
Double failure.
REX8 is offline   Reply With Quote
Old 12-08-2011, 03:56 PM   #37
meifert
Member#: 301676
2009 Forester XT
Double failure.
the quote is right.
although the exact wording has been requoted as "horsepower sells, torque wins"
and Carrol Shelby also said it.
Old 12-08-2011, 04:32 PM   #38
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Enzo Ferrari didn't give a damn about selling cars, and I can't imagine (based on the typical Ferrari engine) that he ever said that torque wins races.
But that's neither here nor there when it comes to this thread.
Old 12-08-2011, 06:20 PM   #39
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I love when people think Ferraris and Hondas don't make great tq. Yes, it's a lower value because it's flat from 3500-8000 RPM...do the math.
Any jackass can make a lump of tq down low but best of luck keeping it up through race revs.
Old 12-08-2011, 06:36 PM   #40
CALIBAN
Member#: 188527
WOW is all I have to say!
CALIBAN is offline   Reply With Quote
Old 12-09-2011, 03:12 PM   #41
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
Which takes us back to the age-old argument about the legitimacy of that "quote," which is most commonly attributed to Enzo Ferrari or Carroll Shelby and was probably never uttered by either of them.
With that said, it doesn't sound like your idea of "great torque" is the same as mine. But that's neither here nor there when it comes to this thread.
Old 12-09-2011, 08:58 PM   #42
jzk25
Member#: 179120
Fairly confident that this V12 plus twin TDO620G's will make great torque.
Old 12-09-2011, 09:29 PM   #43
Mach V Dan
Member#: 12029
jzk25, this project is CRAZY! You are a nut. I love it.
Originally Posted by scby rex
TopSecret Japan twin turboed one of those engines and put it in a MKIV supra before.
--Dan
Mach V
FastWRX.com
Mach V Dan is online now   Reply With Quote
Old 12-09-2011, 09:37 PM   #44
meifert
Member#: 301676
2009 Forester XT
--Dan
Mach V
FastWRX.com
that is all sorts of badass
Old 12-10-2011, 10:32 PM   #45
jzk25
Member#: 179120
Collected a few more parts this weekend.
Turbo 400 with adaptor plate for A340, That's a 2JZ bellhousing, haven't got the 1GZ yet. Just been rebuilt with a new drum, extra clutches and larger sprag. Needs a custom converter once I get the bellhousing and some dimensions.
Cracka(car owner) did some work cutting off the plenums in preparation for some tapered custom jobs.
He also delivered the TDO6SL2 20G's and tial 38's.
Here's a shot showing the current effect of engine weight on the car. With the subaru drivetrain it sat level. Still the T400 and turbos etc to go but it gives a bit of perspective on engine weight.
Old 12-11-2011, 12:54 AM   #46
Marnix
Member#: 51480
1984 AM5, 1994 BC4,
2010 BR5
Very impressive. Do you need to modifiy the engine internals for forced induction?
Marnix is offline   Reply With Quote
Old 12-11-2011, 02:16 AM   #47
jzk25
Member#: 179120
No, we are just going to limit power to around 500hp atw. The rods in late toyota engines are very light and small which limits your power output. 1UZ's post 96 break rods at ~450hp atw and the rods in the 1GZ are similiar(powdered metal with a break line). Fortunately there is 4 more of them to share the load so 500 atw should be ok. the compression ratio is not really a problem as we are only running 10 psi or so.
Old 12-12-2011, 12:36 PM   #48
USMC3782
Member#: 292585
96 OBS and 00 OB
Green/Blue
any reason you went with the th400? I know they can be build very strong but the 700r4/4l60 can be built as well and give you more gears to work with and control of lockup etc with the electronic version.
USMC3782 is offline   Reply With Quote
Old 12-12-2011, 03:38 PM   #49
jzk25
Member#: 179120
I would use the std Aisin A341 before a TH700. Overdrive is not an issue, it's just a toy for events like Powercruise http://www.powercruise.com/ and drags. Diff ratio will ease the pain there.
I already had the TH400 available with adaptor and built ready to go.
Old 12-19-2011, 02:48 PM   #50
UK-Wagon
Member#: 232430
555 I haz 5 Subarus
GC8/GF/SG/GD sedan & wag
ummmmm Subscribed.
UK-Wagon is offline   Reply With Quote
FT : Feeler: 99 Legacy Sedan for Wagons subiman2005 NWIC Private Classifieds 9 07-08-2011 12:13 AM
WTB : Roof Rack for 99 legacy Sedan BD blackheat68 Private 'Wanted' Classifieds 0 08-30-2010 11:34 AM
(PGH, PA) 99 Legacy Sedan Part Out dmg Legacy Specific Parts 5 07-27-2009 01:04 AM
99 Legacy Sedan with STI Rear Spoiler 4WDFun Interior & Exterior Modification 8 06-07-2009 02:55 PM
anyone know any body kits for a 99 legacy sedan?? blazinlaser4g63 Interior & Exterior Modification 4 01-16-2003 09:28 AM
Message Board Statistics All times are GMT -4. The time now is 10:55 AM.
