Old 12-06-2011, 11:47 PM   #1
kronizer
Member#: 184325
2005 WRX
Default knocking on cold start
I have a 05 wrx, catless up and dp, 2.5 exhaust. ECU has been retuned to accommodate the changes. I notice in winter, when the weather is just above freezing, I get knocking upon a cold start. You can hear the popping for about 10-15 seconds then it goes away. Is this something I should worry about, I don't have enough expertise to mess with the 'warm-up enrichment' tables. Any advice would be appreciated.
Thank you
Cameron
kronizer is offline   Reply With Quote
Old 12-07-2011, 11:17 AM   #2
quazimoto
Member#: 70395
That probably has to due more with the oil your using than an ECU issue. At start up the car is in openloop and running close to a 12:1- 11.1 AFR.
Old 12-10-2011, 06:00 PM   #3
kronizer
Member#: 184325
2005 WRX
I'm running synthetic 5w30 as per recommended? I'm sure Dom at Maxwell didn't manipulate start up AR?
Any suggestions, is this of concern. I'm currently living on the coast and am about to head back into the interior and up a ski hill where temperatures are much lower. I'm due for an oil change when I get back, should I swap to something lighter?
Rod knock on cold start? mjyeams Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 09-28-2011 07:10 AM
Rod knock on cold start blitzmr2 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 06-19-2008 10:38 AM
Knock at cold start shm777 Normally Aspirated Powertrain 13 03-19-2005 06:41 PM
Brake / Clutch Knock Noise on Cold Start -AliasMunky3- Brakes, Steering & Suspension 1 01-25-2005 02:00 PM
Knock with cold start jetsiphon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 09-26-2003 12:53 AM
