Old 12-11-2011, 12:04 PM   #1
scoops04wrx
Member#: 150966
04 WRX
Default Current Log with problem
I recently removed my EWG setup which reached my target boost. After taking it off and putting back the stock up and the IWG, my boost gauge indicates me only hitting .04 bars instead of the .13 bars I was hitting with the EWG. My car feels a little "slower" in pick up now. Below are the list of mods
3" bellmouth down pipe
3" catback
Snorkel delete
Stage 2 Map
FP E3 16g
Here is my log I took today. Any input on why my gauge reads otherwise would be greatly appreciated.
https://docs.google.com/spreadsheet/...hl=en_US#gid=0
scoops04wrx is offline   Reply With Quote
Old 12-11-2011, 12:42 PM   #2
eminehart
Member#: 11205
2009 WRX
Dom3-e85-ewg
What kind of Boost controler are you running? And what restrictor pill? Generally the stock system has trouble making boost without going to a smaller restrictor pill but a 3port is ideal. It looks like you are only making about wastegate boost. maybe there is no restrictor pill on your car using the stock boost control system?
eminehart is offline   Reply With Quote
Old 12-11-2011, 12:46 PM   #3
scoops04wrx
Member#: 150966
04 WRX
I am using the stock BC. There isnt a pill.
Old 12-11-2011, 01:18 PM   #4
eminehart
Member#: 11205
2009 WRX
Dom3-e85-ewg
Thats why. It should have a pill. You should probably ditch the stock BC for a 3 port and retune boost. Or throw a Hallman MBC on there.
Old 12-11-2011, 01:38 PM   #5
scoops04wrx
Member#: 150966
04 WRX
ok. I was thinking about gettin the Grimmspeed EBCS with my EWG setup but since I went to IWG, I decided not too. I guess Ill get it and retune it. Thanks
Current log after new install scoops04wrx Open Source Reflashes 5 09-29-2011 12:25 PM
Problems logging with rev.785 biz77 Open Source Reflashes 4 03-27-2008 10:18 PM
My first UTEC log, with problem! AspenGC8 UTEC 6 11-11-2006 11:09 PM
Logging on problems? Freeskier Newbies & FAQs 2 06-01-2001 03:20 PM
Logging in..ne1 else with problems SilverSuby General Forum Archive 0 10-06-2000 08:07 AM
Message Board Statistics All times are GMT -4. The time now is 04:36 AM.
