Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 02-22-2011, 11:57 PM   #101
robtmc
Member#: 23659
Chapter/Region: HIIC
2002 WRX Sport Wagon
Platinum Silver
Originally Posted by MattPersman View Post
I am using a 9 dollar and some change shipped to me from china cable off ebay and was able do learning view, and flash using an older version of ECUFLASH. this thing looks the same as the cable that busted finger is selling. I am sure i will be told its completely customized and not a 10 dollar cable
Wait and get a true Tactrix cable, or build your own. Just posted my somewhat amateur findings and future goals in another thread with a Vag-com cable, which is really all the BFM is. Special drivers will not overcome circuit incompatibility issues.
What it boils down to, is that Colby Boles of Tactrix figured out how to communicate with the 02/03 (04/05?) ECU and his design is patented. You will not find an equivalent unless you build your own copy, which is allowed with the open source idea.
robtmc is offline   Reply With Quote
Old 03-02-2011, 07:21 PM   #102
V8Slayer
Member#: 111565
2007 Legacy Spec.B
324hp/313tq EVOIII 16G
I ordered one of these cables for my car, now I am being told that it will not work for my year ecu.
I was just planning on using ecuexplorer to data log as I am unable to flash my ecu. Does anyone know if this cable/software will work on the older single plug, 96 pin ecu's? Anybody have any experience data logging these older ecu or can point me in a direction.
Thank you,
Robert
V8Slayer is offline   Reply With Quote
Old 03-03-2011, 02:52 AM   #103
ojala
Member#: 255441
05 Saabaru
Thank you,
Robert
ECUexplorer and the other tools we use wont work on your 99 Legacy. As you have now discovered it has a JECS ecu and all of these tools are designed around the Denso ECU. You might look into the EVOscan software for your application. I know nothing about it but some have said that it will work with a JECS ecu.
ojala is offline   Reply With Quote
Old 03-03-2011, 09:27 AM   #104
V8Slayer
Member#: 111565
2007 Legacy Spec.B
Ok thank you, I'll look into that.
Old 03-11-2011, 02:24 PM   #105
MattPersman
Member#: 139385
I have a true Tactrix cable, in fact I have bought 3 of them. 1 ver 1.3 and 2 of the newer ones. the first 2 failed, the second one is very unreliable you have to have the cable wiggled just right for it to work and if you were to slightly brush against it, it might lose COM.
so for non 02-03s, really 100+ dollars for a cable that you can get same results for 10 bucks, just doesn't make any sense.
I am not trying to flame tactrix or anything, but really they can pull up my name and see I bought 3 of them, I am not exactly happy about the build quality for the money, for that money it should be at least a couple year no fault warranty to the original purchaser, most of us are not going to use it once and put it in our sock drawer.
MattPersman is offline   Reply With Quote
Old 03-11-2011, 05:04 PM   #106
Subian
Member#: 202804
2002 PSM Sedan
The 2.0L that could
I just received a BFM cable in the mail, i'm going to test it for my car when I get home.
Edit, I'm able to pull a learning view and run the rom raider logger with no extra software support needed. Waiting to test it on ECU flash.
Subian is offline   Reply With Quote
Old 04-05-2011, 12:59 PM   #107
bryan_johnson
Member#: 78987
Any luck flashing the 2002?
bryan_johnson is offline   Reply With Quote
Old 05-11-2011, 11:30 PM   #108
Beauch
Member#: 224241
2004 Impreza wrx
platinum silver
hi, just got the vagcom cable in the mail today. I have a 16 bit ecu(04 wrx) I'm trying to find the drivers for it but @ the FTDI (i think) site for the drivers they only offer the 32bit and a 64 bit... can i get some clarification on this please.
thanks
Beauch is offline   Reply With Quote
Old 05-12-2011, 12:23 AM   #109
bryan_johnson
Member#: 78987
Click on the Microsoft start button at the lower left corner. Right click "Computer" and select "Properties" from the context menu that pops up. You should get a form that shows what kind of operating system you have and whether you have a 32 or 64bit computer.
Old 05-12-2011, 10:02 AM   #110
V8Slayer
Member#: 111565
2007 Legacy Spec.B
I have some drivers that might work for you, pm me your email and I'll send them to you.
Old 05-12-2011, 01:51 PM   #111
bryan_johnson
Member#: 78987
I didn't read your post quite right. The 32/64bit drivers are refering to the type of cpu in your PC/laptop. The car ecu 16bit/32bit difference does not impact your choice of drivers. Once you get your computer set up, you'll be able to talk to both types of ecu.
Old 05-13-2011, 09:50 PM   #112
Beauch
Member#: 224241
2004 Impreza wrx
platinum silver
Thanks for the clarification. Yeah i'll have to check....im pretty sure its a 64 bit.
Old 05-14-2011, 03:00 PM   #113
no1v2
Member#: 263771
Beauch, let us know if you're able to read and reflash the ECU image. I know it's not possible with the VAG-COM cable on a 2002-2003 WRX (also 16-bit ECU).
Logging should work for you, just be aware that you may need to get a real Tactrix cable/adapter to read and flash the ECU image.
no1v2 is offline   Reply With Quote
Old 05-25-2011, 01:22 AM   #114
Beauch
Member#: 224241
2004 Impreza wrx
platinum silver
okay so i have the cable setup with the laptop, now my question is does anyone have the part number to that flashing block?? thanks again, i'm looking; I just can't find it.
Old 06-21-2011, 12:02 PM   #115
kpotzmann
Member#: 215454
2005 9-2x Aero
VagCom and Linux
Has anyone gotten this to work?
Im having trouble finding the USB port that the cable is hooked into.
Any Linux experts?
I am Running Linux Mint 11 on a dell mini 9
I am under the impression that the kernal that it is using has the FDTI drivers already in it. Am I wrong? Thanks
kpotzmann is offline   Reply With Quote
Old 09-06-2011, 07:58 PM   #116
turbojoe
Member#: 293004
2006 WRX Ltd Wagon
Default Vag-Com for checking CEL in an 06?
Bumping an old thread here.
I've done plenty of searching, but can't find a conclusive answer. Is it possible to use a Vag-Com cable to pull trouble codes in a 2006 WRX? I'm guessing no, because ecuExplorer doesn't support anything past 2005, but figured it's worth asking.
Thanks.
turbojoe is offline   Reply With Quote
Old 09-07-2011, 05:14 PM   #117
turbojoe
Member#: 293004
2006 WRX Ltd Wagon
After some experimentation I found the answer to my own question. In case anyone else is wondering, here it is...
It is possible to use a vagcom cable to pull trouble codes off of a 2006/2007 WRX. To do so perform the following.
1. Ensure that you have setup the vagcom properly and it has a COM port assigned to it
2. Download Learning view
3. Plug vagcom into ODBII port
4. Open Learning View
5. Ensure "Enable DTC Reader" is checked
6. Select the correct COM port and click "Connect"
7. Trouble codes will be displayed under "Memorized DTC(s)"
Old 09-10-2011, 10:07 PM   #118
gurusan
Member#: 258165
2006 WRX Wagon
Got my vag-com on ebay from some china seller for 8 bucks. Finally got around to trying it today and was expecting to encounter at least some problems but I didn't!
Plugged it in, flashed gabedude's stage 1 rom, logged a bit. No errors and no faffing about with problems. Plug and play! Best 8 bucks ever!
gurusan is offline   Reply With Quote
Old 12-03-2011, 08:54 PM   #119
valheru
Member#: 159326
just wanted to add my info
05 2.5RS
ebay vag com cable
Windows 7 - 64 bit
ecu flash v1.29 run as XP
no problems to date
valheru is offline   Reply With Quote
Old 12-10-2011, 10:53 AM   #120
Madjax
Member#: 299271
2002 Forester 2.0 XT
If the PCB of the VAG cable look like the BFM one, you should mod it to read flash WRX02 with ecuflash:
http://forums.nasioc.com/forums/show...&postcount=149
Madjax is offline   Reply With Quote
Old 12-10-2011, 04:56 PM   #121
martinels
Member#: 238124
2002 wrx
my ebay vag-com cable opened: link to picasa album
looks like i will have to buy BFM
martinels is offline   Reply With Quote
Old 12-11-2011, 12:52 PM   #122
Madjax
Member#: 299271
I've got this VAG cable too, i'll try to make it work like my BFM cable in the coming days (it may be harder..)
Old 12-11-2011, 02:36 PM   #123
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
So to make sure I understand....if I have a JDM v8 (2003 vintage) "581" ecu in a 2002 USDM WRX that I want to image and reflash, the cable I need is.....
I'm not terribly crazy about paying $$$ for a cable, either. I'd be more likely to build one like our friend Madjax
Thanks for the help, folks!
n2xlr8n is offline   Reply With Quote
Old 12-11-2011, 04:04 PM   #124
Madjax
Member#: 299271
The cable you need is .... openport 1.3U... for $150 , or the BFM at $40.99 and made the MadMod, or maybe the fake VAG one at $12.00 if I can modify it .
My Ecu is the AG580 , the 581 might be the same.
I think for all the Subaru with the four pins white connector under the dashboard, the BFM cable need to be moded.
What bothers me is that guys like me will pay for a cable from BFM and give them money for a product that did not work on WRX02 (and also on some other sub from this around year).
BFM knows that cable did not work for this car on the pretext that it is a timing issue, then it is wrong and it's a hardware problem ...
Originally Posted by From BFM site
This cable has some limited functions on 2001-2003 Subaru ECU's namely a glitch that creates a very critical timing procedure in order to use ECUflash. The cable will perform all other functions properly using LearningView and Romraider for those year models.
Old 12-12-2011, 07:17 PM   #125
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Thank you, kind sir. Will the newest openport "2.0" version work? AFAIK, the 1.3 is no longer sold.
That would bother me as well...thanks again.
I Got VAG-COM cable and I need help!!!!! subi-bartimioli02 Open Source Reflashes 148 06-24-2015 09:36 PM
WTB Service: Get my Vag Com cable to work el dude MAIC Private Classifieds 3 10-04-2009 09:25 PM
Anyone in Phila. willing to share their Tactrix or vag-com cable? eek1 Tri-State Area Forum 4 09-12-2009 05:32 PM
Cant get Vag-com cable to flash my 04 FXT andy87t2 Open Source Reflashes 6 06-13-2009 01:35 AM
VAG-COM cable btlegacy Open Source Reflashes 4 05-31-2009 08:10 PM
