Welcome to the North American Subaru Impreza Owners Club Thursday April 17, 2014
Old 12-01-2011, 06:49 PM   #551
Layvon
Member#: 195711
STi 04/05/06/07
JBP / OBP for now
The above post has me jealous. I'm eager to see your results. I've had mine on order for about 5 weeks. Cannot wait!
I'm hoping for the best for you Bariga!
Old 12-01-2011, 06:57 PM   #552
MrLith
Member#: 274895
Originally Posted by Bariga View Post
yeah ill be first one to do it! I am making full write up soon on a blog site!
While thats the case on this forum, this is not necessarily true fullstop. Unfortunately there are quite a few EFRs off the radar at the moment as I am sure will sooner or later become more obvious.
Glad you are sharing progress, looking forward to seeing how this pans out - good luck
MrLith is offline   Reply With Quote
Old 12-05-2011, 06:38 PM   #553
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Tino is going to be 2nd person!
he has 8374 installed....
My wheels getting re-powder coated and rear suspension parts on order, should be back on the road sometime next week
this is the blog page
www.ofps.net
Bariga is offline   Reply With Quote
Old 12-05-2011, 06:49 PM   #554
rxw
Member#: 43669
2006 STi
Tino's car is crazy good... can't wait to see your results and his!
rxw is offline   Reply With Quote
Old 12-05-2011, 11:24 PM   #555
monkiboy
Member#: 202958
2008 wrx
anton, in your blog, throughout the entire thing, you never mention which turbo you went with. it is only in the video description where it says it is the 7670. just an fyi.
monkiboy is offline   Reply With Quote
Old 12-06-2011, 01:28 AM   #556
unclemat
Member#: 114530
2005 LGT 6MT wagon
unclemat is offline   Reply With Quote
Old 12-06-2011, 12:12 PM   #557
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Originally Posted by unclemat View Post
this ****s didn't and wont release anything about that
so delete this **** off my thread
Old 12-06-2011, 02:19 PM   #558
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
corrected, thanks
Old 12-10-2011, 01:42 PM   #559
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
AEM ecu is back, they fixed 3 none working EGT channels.
It should back on the road sometime late next week!
Old 12-11-2011, 10:34 PM   #560
GA scooby
Member#: 229518
2011 STi
Awesome build. Did you not go EWG for a particular reason?
Your build gives me ideas for my eventual Full-Race EFR twinscroll build one day.
GA scooby is offline   Reply With Quote
Old 12-11-2011, 10:41 PM   #561
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
no reason to get ewg with properly designed internal gate!
more space, less piping, simple install -thats my key
Old 12-11-2011, 10:47 PM   #562
GA scooby
Member#: 229518
2011 STi
That makes sense. I always just wanted a noise maker
Anyway resume on. Great build!
Old 12-11-2011, 10:59 PM   #563
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
for noise maker its cheaper to install exhaust cutout
Old 12-12-2011, 03:55 AM   #564
Maxwell Power
Member#: 190729
The turbo is shorter in EWG version which means more room for the downpipe....
venting EWG to atmosphere will always make more power than internal gate. I don't care what anyone "thinks" they know. Removing the excess gasses from your exhaust lowers exhaust pressure post turbo, increases turbine work and turbo efficiency. Not to mention the smoother linear flow leaving the turbine without two air streams traveling at a different rate coming together creating turbulence. The typical gain is 30whp on a 400whp car when you go atmospheric.
If you are using EWG for boost control, then it isn't worth it on the EFR because the internal gate works so well. If you want the extra power, you have to go to atmosphere, recirc won't help and therefor is again useless on the EFR.
Maxwell Power is offline   Reply With Quote
Old 12-12-2011, 08:24 AM   #565
thefoos
Member#: 144751
02 WRX BW EFR E85
7064 TS WRB
Agreed. That is why I went with the IWG as well.
You're points are valid. I'm not going to argue about this from a performance perspective. Going with the IWG TS does make for a very clean install, saves money, less parts, higher reliability, and you get very close to the same performance. I personally think its worth the potential loss of 20whp. I'd like to see the loss validated though. I think on these EFR's we are going to see a much smaller gap in performance.
thefoos is offline   Reply With Quote
Old 12-12-2011, 01:33 PM   #566
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
dom i always had my EWG's plumbed to downpipe, so the extra 20 whp not worth extra ticket
But even with IWG EFR when internal gate opens I can hear exhaust getting 20% louder
Old 12-12-2011, 04:16 PM   #567
Maxwell Power
Member#: 190729
I always ran mine with long tubes and a muffler if necessary
Old 12-12-2011, 05:31 PM   #568
killichnakropf
Member#: 244879
2006 STI stage 2
Needs a 20g
To the op. You've got the 07 limited and it's got a 35r on it. You win sir congrats.
killichnakropf is offline   Reply With Quote
Old 12-12-2011, 10:33 PM   #569
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
35R is replaced with Borgwarner EFR 7670
Old 12-14-2011, 02:39 PM   #570
reid-o
Member#: 103631
2004 STI
Man...making you wait all that time for the turbo was a bad thing. Now you're the most patient person in the world. Post some charts !!! lol
Old 12-14-2011, 06:54 PM   #571
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
TSSFAB.US toys came in today!
Very Quality stuff!
Keep it up bro!
Old 12-14-2011, 07:12 PM   #572
rxw
Member#: 43669
2006 STi
Similar to this gear!
Old 12-14-2011, 07:52 PM   #573
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
overpriced!
Old 12-15-2011, 07:05 PM   #574
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Links installed
Wheels got repaired and sand blasted, looks sick!
Old 12-15-2011, 07:23 PM   #575
R & H Garage
Member#: 139767
Very Quality stuff!
Keep it up bro!
Drool! He makes great quality parts for the price! Really looking forward to seeing final results
R & H Garage is offline   Reply With Quote
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 563 05-16-2012 08:28 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
