Old 12-16-2011, 01:01 AM   #1
Strider327
Member#: 131280
2004 Impreza WRX
Default Subaru OEM Sub Woofer Modification 04 WRX
Hey Nasioc:
I was wondering, is it possible to take apart the small subwoofer inside the sub box under the seat and install a better woofer that's the same size?
Strider327 is offline   Reply With Quote
Old 12-16-2011, 06:38 AM   #2
infinite012
Member#: 74392
2015 Forester
Sure.
infinite012 is offline   Reply With Quote
Old 12-16-2011, 08:21 AM   #3
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Not worth the trouble IMO given the small size of the enclosure and limited amp power. Changing the driver isn't going to make a stellar difference in how it sounds. If you're not happy with it just buy something better.
Mulder is offline   Reply With Quote
Old 12-16-2011, 11:03 AM   #4
Strider327
Member#: 131280
2004 Impreza WRX
So what other options are there that will fit in that same location? I already have an aftermarket head unit, just want a clean install that has something that comes with a built in amp and sub. Similar to the stock but obviously a lot better.
Old 12-16-2011, 11:13 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
There are some aftermarket under-seat amplified subs that will fit. I don't have specifics handy but I'm sure someone will post them, you can also search in here as this has been discussed previously.
Old 12-16-2011, 11:15 AM   #6
Strider327
Member#: 131280
2004 Impreza WRX
I have been looking. I think I came across maybe a Boss and a Kenwood.
Old 12-16-2011, 01:28 PM   #7
C o l i n
Member#: 101384
2004 TS
Platinum Silver Metallic
Last time I checked that was pretty much all that was available. There may also be a Pioneer that is very similar to the Kenwood. The best solution IMO is the RAAM Audio underseat box but they're nearly impossible to find. I had my eye on them since I first got my car in 2007, couple years later found one for sale so I picked it up. Couldn't be happier with it paired with my old Image Dynamics IDQ10v2.
C o l i n is offline   Reply With Quote
Old 12-17-2011, 12:04 AM   #8
Strider327
Member#: 131280
2004 Impreza WRX
So after alot of research and looking at different models and price differences. Looks like the Kenwood KSC-SW10 is probably what I would use for my purpose of mounting it under the passenger seat where the stock one is. My only question is what do I need to get this wired correctly? Just RCA cables to my aftermarket head unit?
Old 12-17-2011, 12:27 AM   #9
jegomes
Member#: 303039
2006 WRX
Linky to the product manual...
http://www.kenwoodusa.com/UserFiles/...ls/kscsw10.pdf
it has a few different ways to connect it, you could just use the wires that are there from the factory unit as it supplies speaker signal power and ground, but if your looking for control from your aftermarket deck theny your best off running RCA's you will also need a 10amp supply of constant (battery) power as well as a switched 12v turn on, which you should find as a blue/white on the back of your aftermarket deck..
jegomes is offline   Reply With Quote
Old 12-17-2011, 01:26 AM   #10
Strider327
Member#: 131280
2004 Impreza WRX
Looks simple enough. Thanks everyone! Found one at a pretty good deal.
Old 12-17-2011, 09:41 AM   #11
Strider327
Member#: 131280
2004 Impreza WRX
Just for clarification, I can safely remove the sub, ground, and wiring harness completely of the OEM sub as I would not need it anymore correct?
Old 12-17-2011, 04:05 PM   #12
jegomes
Member#: 303039
2006 WRX
Absolutely
Old 12-27-2011, 05:03 PM   #13
Strider327
Member#: 131280
2004 Impreza WRX
Installed..this thing is awesome! Thanks everyone! It fits snugged right under the seat, the seat slides back and forth with no problem. I used Radioshack Superlock Velcro to mount the sub
Old 04-18-2012, 05:43 PM   #14
Strider327
Member#: 131280
2004 Impreza WRX
Question for those who also have done this. Where did you guys install dynomat to stop the rattling?
Old 04-18-2012, 06:15 PM   #15
jegomes
Member#: 303039
2006 WRX
well where is the rattling coming from ... turn up the music and try to pinpoint the noise maker... use your hand to feel the suspect and put pressure to stop it from rattling... honestly all cars have their own trouble spots, so you will have to do a bit of hands on to locate your specific issue
Old 04-18-2012, 06:31 PM   #16
Strider327
Member#: 131280
2004 Impreza WRX
Guess that's what I'll have to do. Thanks!
Old 04-29-2012, 09:32 PM   #17
Strider327
Member#: 131280
2004 Impreza WRX
So it turns out it was the actual sub vibrating on the actual car chassis! So what I did was I used my old WRX rear carpet and place it under the sub vertically (I have all weather floor mats now). That solved all my rattling issues I was having the sound/bass is now much more clearer. Cheers!
Old 05-01-2012, 12:48 AM   #18
RadioRaccoon
Member#: 295384
Hey Nasioc:
Yes you can take the subwoofer apart, but i wouldnt reccomend replacing the original woofer that is in the enclosure. I cracked mine open to repair a broken tinsel lead ( this causes the sub to be inermittent) and noticed that the amp was well built but gutless. the woofer itself has a heavy steel plate for a cone and the cone backing is a paper pulp. also the maximum wattage rating for the woofer was 120 watts a .5 ohms. so if you put a normal 4ohm woofer in its place you'd be getting like 35 watts or so out of the tiny amp (not exact wattage, too lazy to do the maths ). That and the woofer is pretty much flat and anything larger would cause the enclosure not to close.
Hope this helps!
RadioRaccoon is offline   Reply With Quote
Old 01-25-2013, 12:36 AM   #19
Handsdown
Member#: 29355
bump... if it sounds blown, is it easy to source a replacement speaker cone or would the money be better invested elsewhere?
Handsdown is offline   Reply With Quote
WTB : Under car seat sub woofer for 04 STI azn_fire_fly Private 'Wanted' Classifieds 1 09-19-2010 02:15 AM
WA: 2 OEM Sub woofers with wiring harness black&whiteday&night Interior/Dressup/Audio & Security 1 06-10-2009 08:28 AM
WTB: 05- Legacy OEM Sub Woofer harness. Leonardo Private 'Wanted' Classifieds 1 08-06-2007 11:46 PM
FS OEM SUB and Harness 04 wrx kreddogwrx Interior/Dressup/Audio & Security 5 08-06-2007 03:22 PM
Subaru OEM sub woofer Silver_04_WRX_SC Interior/Dressup/Audio & Security 19 01-02-2007 04:33 PM
