Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 07-31-2011, 09:19 PM   #1
TheShadowWRX
Member#: 11654
2002 WRX Sedan
WR Blue
Default Tons of Corrosion, Rusty Bolts - Need to Clean Somehow
Hey Guys,
As you may have seen in some of my other threads, I'm trying to recondition my whole 02 WRX and one big area of concern for me is under the hood. The car sat for the last 8 months and before that for two summers in a garage but we live in a very damp area so there is a lot of corrosion, rusty bolts, etc all over the engine bay that I need to clean up.
I figure there most be some process to clean these bits up, somehow... I took a few pictures with my iPhone to try to show you what I mean...
Thx!
TheShadowWRX is offline   Reply With Quote
Old 08-01-2011, 10:49 AM   #2
prokaw875
Member#: 143318
GG Outback Sport
Version 8 EJ207
I would think honestly replacing as many bolts as you can is your best bet. Other than that I would have them chemical stripped and maybe there is some type of clear rust free coating you can put on the heads without changing the treads size/depth.
Honestly though by looking at your motor(no offense) you should worry about other stuff before the bolts. I.E. Powdercoat your intake mani. Have your alt. cage polished/powdercoated. Take a buffing wheel/polish your radiator. Repaint your coolant overflow tray. And a alternator cover would clean up the bay alot. I think once you did that stuff they start to focus on replcing/finishing the bolts
prokaw875 is offline   Reply With Quote
Old 08-01-2011, 03:01 PM   #3
SubieDugie
Member#: 119219
2005 STi
WR Blue
You are dealing with more aluminum oxide than iron oxide(rust). I would cleaning the engine bay in sections and removing as much as possible to avoid having cleaners and water in areas you don't want them, i.e. the alternator. Also, just moving lines out of the way to make it easier to get to everything will help. I say work in section because you only have about a twenty minute window for removing and treating corrosion. The aluminum parts would benefit from Flitz Aluminum Pre-Clean and mild agitation with scouring pads/brushes. This engine bay is not a one day project if you want it looking new again. So get a game plan together and research how to remove stuff that will benefit from cleaning/polishing out of the engine bay. I would invest in some good masking tape/duck tape to cover things that you don't want sprayed with water and cleaner, like painted surfaces. Removing hardware and cleaning it and removing rust/corrosion would be the best method if you are wanting to replace every nut/bolt/washer that has corrosion on it. DupliColor Rust Fix is a great product for sealing hardware/metal after you have removed the rust as much as possible. [If you don't remove rust it will come back and continue to spread under whatever you spray over it.] DC Rust Fix requires 24 hours curing time before applying a top coat/color coat. You will need plenty of prep solvent and lint free cloths to prep any surfaces that are going to be painted. Prep work is always the most important step to creating any well finished project. To polish and seal any surfaces that are not going to be painted I recommend Flitz Polish which will seal for 6 months in fresh water environments and up to 3 month in salt water. It works on everything from polish metals like chrome, aluminum, and copper, to plastics, fiberglass, and headlights.
Have fun and keep us updated.
SubieDugie is offline   Reply With Quote
Old 08-04-2011, 02:30 AM   #4
TheShadowWRX
Member#: 11654
2002 WRX Sedan
WR Blue
Wow thanks for the great advice!
I'll look into the products you recommended and put together a game plan...
You have given me hope that it is possible to restore the luster to the engine bay!
Thx,
Mike
Old 12-15-2011, 06:41 AM   #5
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
i have alot of rust too. im noticing that when i try to take them off, they either froze or the break off. how do i take these broken bolts off?
Daddy_Digital is offline   Reply With Quote
Old 12-15-2011, 09:10 AM   #6
9vapors
Member#: 92582
I'm in the same boat and mine is a 2008. The previous owner didnt take care of the car at all...
9vapors is offline   Reply With Quote
Old 12-15-2011, 09:01 PM   #7
lunchmeat79
Member#: 303140
2008 Impreza 2.5i
Satin Pearl white
have you tried the green scotch bright pads and a copper gun cleaning brush, they will clean up the aluminum stuff really well
lunchmeat79 is offline   Reply With Quote
Old 12-15-2011, 09:08 PM   #8
SubieDugie
Member#: 119219
2005 STi
WR Blue
Look into CorrosionX on Autogeek. It is supposed to be like WD-40 and PB Blaster combined on crack.lol No really, it gets great reviews. I haven't used it as CorrosionX, but I did use it when I was in the Navy.
Old 12-16-2011, 11:35 PM   #9
Bikelok
Member#: 254851
2002 WRX wagon 5mt
Don't just cover up the oxidation with new covers and crap. Take the time (lots of it) and scrub, polish, protect as much as you can. The longer you leave it the harder to remove. If it starts to pit then forget about it ever looking new. Lots and lots of elbow grease. You can do it, just be patient and methodical. Look up threads on how to clean an engine compartment. You don't have to cover up much and you just use a regular hose (no high pressure). Yes you can pour water over most of your engine compartment. Look it up.
Bikelok is online now   Reply With Quote
Old 12-17-2011, 02:26 AM   #10
Daddy_Digital
Member#: 274205
Bikelok - http://www.corrosionx.com/rust-remover.html check it out and read it. need proof? as SubieDugie how well that stuff worked while in the navy. metal out at sea would rust so fast if it werent for stuff like this. i do agree with you. dont just cover it up. i got some rust on my rear quater panels that i want to remove the rust and have repainted so it doesnt occur again.
FS : Wii Bundle - Tons of extras & games - $315 shipped yo14jman Non-Subaru Stuff 1 04-30-2011 04:18 PM
FS : A Ton Of 2011 Rome Snowboards Gear! Need To Get It Out Of My Garage mattesonb SCIC Private Classifieds 16 11-16-2010 05:48 PM
What is this thing? And why is it infront of a bolt I need to get to? Soulofdarkness Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-10-2010 01:01 AM
FS;NM.Need to clean up the garage a little. Lots of parts. Mustang Raper Suspension/Brakes/Handling 3 12-27-2008 05:05 PM
FS: Tons of JDM/STI stuff - returning to stock gordy Engine/Power/Exhaust 48 05-14-2007 12:48 AM
