Old 12-10-2011, 01:19 PM   #1
Bill in Mtl
Member#: 188357
2016 WRX 6MT
Default Phantom knocking - updated 12/17
Is it possible for the ecu to be picking up phantom knock ? I flashed an updated rom about a month ago, after revising the timing to address a knock issue. I have been running the car for about a month, and the knock is still there, in the exact same fields as previously
I first reduced the timing by one degree in those ranges, the knock remained - reduced the timing by another degree, and as seen on the latest learning view - knock is still there in the exact same two fields - everything else seems to be pretty good
Has anyone either seen this before, or had a similar issue ? Any feedback greatly appreciated. Sorry for the size of the image - I cannot get it any larger on my netbook ?
Thanks for looking
Regards,
Bill in Mtl is offline   Reply With Quote
Old 12-10-2011, 03:33 PM   #2
Airboy
Member#: 72829
2006 WRX
2015 WRX
Which map are you using?
Airboy is offline   Reply With Quote
Old 12-10-2011, 03:57 PM   #3
Bill in Mtl
Member#: 188357
2016 WRX 6MT
Bullwinkle 06-07 5MT GMBCS-GrmSpBCS Map
Downloaded it from Romraider
Old 12-10-2011, 04:32 PM   #4
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
1.5-5 is a very wide load range. Consider changing the FLKC range boundaries to 1, 1.3, 1.6, 1.9, 2.2+ or something like that. That will help Learning View give you a little bit better idea of where the knock is happening.
But I don't think Learning View is the right tool for this job anyway. We need logs to show what's going on here. Is it happening in the middle of a WOT pull? Right when you stab the throttle? While spooling up? After spooling up? Right when you left off the throttle?
Old 12-10-2011, 04:51 PM   #5
Bill in Mtl
Member#: 188357
2016 WRX 6MT
Thanks for the reply - I will put some more time into this and get some logs together to be in a better position to reply
Appreciate your time
Regards,
Old 12-17-2011, 01:48 PM   #6
Bill in Mtl
Member#: 188357
2016 WRX 6MT
I revised the FLKC ranges as mentioned above, and got in a pretty good run with log. Unfortunately did not get to WOT on this log, but do have enough info to try and tune the knocking out. Much smaller range makes it easier to see - and hopefully deal with
Thanks again - appreciate the help
Here is the latest learning view after my run / log - and the log makes it very easy to see where the knock is happening. As soon as I sign up to a site that hosts files - I'll add the log as well
Regards,
Grimmspeed BCS install - learning view question Bill in Mtl Open Source Reflashes 2 07-12-2011 11:34 AM
AF way off - updated with learning view - resolved Bill in Mtl Open Source Reflashes 12 03-16-2011 05:01 PM
Help pulling learning view/flashing in Vail - - please Keats_16G_Rex Rocky Mountains Impreza Club Forum -- RMIC 0 12-30-2010 12:26 AM
Learning view, please look, some knock. OUScooby Open Source Reflashes 19 06-15-2010 04:26 AM
Learning view - scan - FB if you could Kastley85891 Open Source Reflashes 16 03-24-2008 10:42 PM
