Old 12-15-2011, 07:44 PM   #576
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
yeah and the subframe and front diff mount man i wish my pockets were deeper
Old 12-15-2011, 09:55 PM   #577
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
Originally Posted by Bariga View Post
overpriced!
for sure and that msi subframe doesnt fit ****. you have to beat the **** out of your gas tank and the spare tire well to make it fit. and the msi subframe cost as much as tss fabs whole rear set.
NW2TONE is offline   Reply With Quote
Old 12-16-2011, 02:46 AM   #578
project_skyline
Member#: 153880
03 Evo VIII
2011 STI
Why is this even in PBB? I don't see a dyno sheet or results for the 7670. This looks more like a build thread.
If your going to title it 7670 at least have some results.
project_skyline is offline   Reply With Quote
Old 12-16-2011, 08:07 AM   #579
stretchedk7
Member#: 170602
06 Wrx RWD Auto
76MM-AEM-2200's
^! spoken like someone who wanted to see some powa.
Old 12-16-2011, 12:04 PM   #580
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
very soon!
Old 12-17-2011, 03:23 PM   #581
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
30 years ago this thread started off as a 35r with moore(I think?) TS manifold. Now 30 years after BW released the EFRs he finally got his and then wanted to fix the suspension. His numbers will come waaay before more EFRs get shipped out anyway.
Old 12-17-2011, 09:46 PM   #582
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
My wheel bearing was ****ed up, I didn’t want to risk it.
The rear suspension was just excuse: D
Will be picking up the car on Monday, wheel color will be surprice i let Kelly @ Speedware pick the color ::hope it wont be pink or green
Old 12-19-2011, 03:28 AM   #583
TSSFAB
Member#: 199829
89 Xr4ti
depends
Cant wait to hear about your first ride! Thanks for the props!
TSSFAB is offline   Reply With Quote
Old 12-19-2011, 12:15 PM   #584
reid-o
Member#: 103631
2004 STI
Did you get the ones with heim joints? Your blog has pics of arms with bushings but some look like they're heim.
Also I read your blog and have a question about the valves. I know DOM blueprints everything so I dont question the workmanship, but did you learn anything about why the valves warped? Was there insufficient lash (not that it was done wrong but that more lash would have been better)?
I'm sort of leaning toward your old head piston package for my car and just wanted tips.
Old 12-19-2011, 02:00 PM   #585
Maxwell Power
Member#: 190729
he was on a tighter budget before and used POS BC Valves and springs. By POS, I mean COMPLETE PIECE OF ****. Those parts are so substandard that it blows my mind that anyone even uses them. I didn't know how bad they were when we first started using them, but after more experience with them... yuck. Plus, regular stainless exhaust vales is a bad idea anyway on a car making this much power. I'll only run Ferrea Stainless exhaust valves and even then I won't run them on anything more than 30R.
Old 12-19-2011, 02:03 PM   #586
reid-o
Member#: 103631
2004 STI
I've been making trips down to the machine shop and was told that the spring pressure (BCs) also doesn't always match advertised spec. Good to know.
Old 12-21-2011, 03:20 AM   #587
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
just wired up aem egt amp and everything works, aem fixed the ecu!
i plan on getting it on dyno right after new years!
Old 12-21-2011, 12:38 PM   #588
sense of nature
Member#: 112759
2018 STi Mikey Tuned
SexyRP
Been waiting for someone to chime in w/ that~!
Old 12-21-2011, 02:44 PM   #589
MartinSTi05
Member#: 145145
2006 wrx STi
The original thread was titled something like twin scroll 35R....
Results were posted from that setup. He has since changed his setup and renamed the thread accordingly. In the meant time if you wanted results that bad I suggest you build a 7670 car in the next few days and test it, I would love to see the results!
MartinSTi05 is offline   Reply With Quote
Old 12-22-2011, 12:08 AM   #590
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Need help!
Just installed DW300 pump, took walbro out and slap dw pump in there with all original hardware from Walbro.
Problem: Its not building pressure! i can hear its working but nothing on the guage!
Old 12-22-2011, 12:14 AM   #591
NW2TONE
Member#: 212509
your **** go faster
did you prime the system a couple times by turning the key off and on a couple times letting it build pressure that you bleed out when you took the pump out.
Old 12-22-2011, 12:18 AM   #592
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
did that like 10 times, you can see in video im doing it
Old 12-22-2011, 01:03 AM   #593
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
lol, before i was about to take everything apart again, i decided to play with it. turn key on and off very quickly many times and it primed! maybe aem is not leting it prime for longer!
Old 12-22-2011, 01:09 AM   #594
B.R.E.D
Member#: 289606
06 WRX
white
You can change the pump prime time in the AEM
B.R.E.D is offline   Reply With Quote
Old 12-22-2011, 02:14 AM   #595
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
i though about it, but didn't want to spend 2 hours looking for that setting
im surprised how quiet the pump is!
Old 12-22-2011, 02:35 AM   #596
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
Under AEMPro (native Series 1 software), it's under Engine Start -> Advanced Start -> Options. Under AEMTuner, clicking the Start tab should pull it up as one of the windows.
Cheers
Lance
lancelucas is offline   Reply With Quote
Old 12-22-2011, 02:37 AM   #597
lancelucas
Member#: 124282
04 WRX Wagon PSM
13 STI Sedan SWP
And yes, it can be a PITA to get DW300's to prime, for whatever reason. I had to pull my feed line in the engine bay and put it to free air (IE, no FPR demanding pressure) before I could get the pump to prime. Once the feed line between the tank and engine bay were filled, I was A-OK.
Old 12-22-2011, 12:54 PM   #598
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
Pics
Old 12-22-2011, 01:05 PM   #599
yeos
Member#: 133855
2009 STi SparkSilver
Dom Tuned @ MPS
Powdercoated bbs re! How about some bigger brakes?
yeos is offline   Reply With Quote
Old 12-22-2011, 01:15 PM   #600
Bariga
Member#: 179846
07 STi Limited
EFR 7670 TS
im not spending any more money on this box with 4 wheels
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 607 10-11-2015 08:50 PM
Maxwell Power Services aka GetaDomTune AwaySooner Vendor Reviews 7 03-11-2010 03:54 PM
+1 for Dom/Maxwell Power Jeff54 Vancouver Impreza Club Forum -- VIC 22 09-02-2009 02:22 PM
My new Maxwell Power Services engine is almost in !!! leonbmx North West Impreza Club Forum -- NWIC 13 03-23-2009 10:28 AM
