Welcome to the North American Subaru Impreza Owners Club Sunday May 24, 2015
Old 12-16-2011, 03:36 PM   #1
chriskarel
Member#: 287176
Default fuel leak in 05 STi - HELP!!
chriskarel is offline   Reply With Quote
Old 12-16-2011, 03:39 PM   #2
chriskarel
Member#: 287176
Old 12-16-2011, 05:34 PM   #3
mcorrales
Member#: 248282
323 whp
I dealt with that, same location... ended up with parallel fuel rails...
mcorrales is offline   Reply With Quote
Old 12-16-2011, 07:10 PM   #4
chriskarel
Member#: 287176
Old 12-17-2011, 02:36 PM   #5
mcorrales
Member#: 248282
323 whp
like $300 maybe... keep in mind that intake manifold has to be removed if not is a pain...
Old 12-17-2011, 03:25 PM   #6
chriskarel
Member#: 287176
Old 12-18-2011, 07:34 PM   #7
chriskarel
Member#: 287176
Old 12-20-2011, 03:23 PM   #8
chriskarel
Member#: 287176
Old 12-20-2011, 03:45 PM   #9
mcorrales
Member#: 248282
323 whp
$300 for the rails, try to get new manifold gaskets... if you want to go further do the tgv delete and get 4 manifold gaskets, if not just 2 gaskets...
Old 12-20-2011, 04:40 PM   #10
Kentmx25
Member#: 224544
2013 Impreza WRX
I had the same problem and I just fixed it this past weekend. It was that the hose clamps under the turbo inlet were at least 3 turns loose. I then tightened them up and went away for a bit then the other side started to leak. The only way to fix it is to pull the the intake and replace all the rubber hose for the fuel line and double up the fuel line clamps. Plus while you are in there; there is no reason not to do the TGV delete and maybe put on a aftermarket turbo inlet. It is just an extremely poor design on Subarus part.
Kentmx25 is online now   Reply With Quote
Old 12-20-2011, 05:08 PM   #11
chriskarel
Member#: 287176
Old 12-21-2011, 07:41 AM   #12
oguitar
Member#: 206720
2002 WRX Wagon
This is just like the bugeye fuel line leaks that are getting fixed by Subaru. I would call SOA and tell them what you are seeing. I have to fix my leak soon. You must be losing a lot of gas if you have to fill up every day. This might be dangerous so get it looked at soon.
oguitar is offline   Reply With Quote
Old 12-21-2011, 11:04 AM   #13
mcorrales
Member#: 248282
323 whp
Have fun! post some pics!
Old 12-21-2011, 02:05 PM   #14
chriskarel
Member#: 287176
Old 12-22-2011, 04:29 AM   #15
oguitar
Member#: 206720
2002 WRX Wagon
Dude that is a major leak. Better not drive till this is fixed.
Old 12-22-2011, 09:37 AM   #16
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Originally Posted by chriskarel View Post
not gonna lie, I think pulling the intake manny off is way above my level. I would do more harm than good probably. So off to Subaru to pay $94/hr. for labor. :'(
Generally speaking, the hourly rate at the dealer is usually pretty close to the going rate for local mechanics - the price difference comes from the dealer charging the book rate (in terms of time) for a job, vs. what it actually took for time. If they are willing to do it, the service department at the dealership are probably the ones you want taking things apart, as they live and breathe subaru.
an eighth of a tank every 10 miles is a very bad leak - I'd try not to drive if at all possible (an engine fire is a tad more expensive to deal with than replacing fuel rails) - did you try to get a screwdriver on the hose clamps and tighten them up?
DrD is offline   Reply With Quote
Old 12-22-2011, 01:04 PM   #17
Cannibal
Member#: 133023
2005 WRX STi
I had this same problem in my '05 STi. I called up Subaru, explained the problem, told them that there were some NHTSA cases opened about this same problem, and Subaru took care of fixing the problem. I would recommend calling SOA.
Cannibal is offline   Reply With Quote
Old 01-16-2012, 06:31 PM   #18
jackee
Member#: 246146
2005 WRX
jackee is offline   Reply With Quote
05 wrx fuel leak in cold weather? skirex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 02-14-2014 11:54 AM
08 sti motor in 05 sti need help! sleepysubie Subaru Conversions 19 09-29-2008 09:49 AM
05 STI - COBB uppipe install - I can't stop the leaking AnorexicSTI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 10-04-2006 10:14 AM
aftermarket exhaust for my 05 STI - help me decide nkkilla Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 60 01-10-2005 02:04 AM
asking for advice - fuel leak in engine! daWagon Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 10-19-2004 11:26 AM
