Old 06-24-2011, 01:11 AM   #51
wittmer25
Member#: 102970
2004 STi gt30r
we need a dyno graph of that monster...
wittmer25 is offline   Reply With Quote
Old 06-26-2011, 02:28 PM   #52
kheff46
Member#: 66739
2002 WRX wagon
Talking
Originally Posted by AlexD View Post
Pictures - if that would be interesting to see i could post a whole pictorial of the build, apart from the pictures of the latest updates, that's still being done (twin dual-chamber intakes, A2W IC, etc....)
i would be most interested in seeing more, much much more!
im sure not the only one!
--keith
kheff46 is offline   Reply With Quote
Old 06-28-2011, 10:44 AM   #53
wittmer25
Member#: 102970
2004 STi gt30r
I would like more eye candy too.
Old 06-30-2011, 07:15 PM   #54
Seraphinwolf
Member#: 150922
97 OBS EZ30R
94SVX LSi Bourduex Pearl
Ncie nice update!
Seraphinwolf is offline   Reply With Quote
Old 08-26-2011, 01:19 PM   #55
AlexD
Member#: 270986
Right, an update. A lot of updates, actually.
After sorting out the troubles i initially had with an engine and transmission, ran the car for a few trial runs. Got pretty decent times for shakedown passes, but again, a few issues were discovered.
Transmission was not shifting as it should. Partly down to the fact that one of the gaskets was leaking oil out of the box, and mostly because the shifter mechanism is VERY imprecise, coupled to the rachet shifter. Now a Mastershift paddleshifter is in charge of gearchanges.
Got the PPG front diff fitted as well, so FWD traction shouldn't be an issue anymore.
Dry sump has also been fitted as i want to avoid any more issues with oil starvation. Ever.
Most importantly, i was never really satisfied with the inlet manifold. Wasn't really up to scratch with the rest of the engine, so i decided to redo the whole thing, in order to prevent unequal cylinder charges and excessive intake temp. Most importantly, decided to go from FMIC to an A/W setup. Intercooler now sits...well, see picture. Each bank has its own double chamber plenum now, and the intake runners from the turbos are significantly shorter. Nitrous installation now doubles up as a methanol injection system too. The whole A/W setup is heavier (with water tank filled with ice, whole setup weighs some 7kg more than the comparable FMIC setup), but given the advantages it offers over the FMIC i think i can live with it.
We'll see what sort of official times it will produce now.
AlexD is offline   Reply With Quote
Old 10-26-2011, 05:54 AM   #56
10MTN-bugeye
Member#: 288093
2002 Bugeye
PSM and parking lot scars
Subaru Stars
Wow! Nice. That's got my interest. Is it update time, yet?
10MTN-bugeye is offline   Reply With Quote
Old 11-13-2011, 08:33 AM   #57
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Much nicer manifold! Looks great dude!
Old 11-13-2011, 12:01 PM   #58
vtboost
Member#: 155580
2002 w/ 04 front end
& STi drivetrain
Interesting... subscribed
vtboost is offline   Reply With Quote
Old 12-07-2011, 06:19 AM   #59
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Alex, you gonna reply to my PMs?
Old 12-22-2011, 08:16 AM   #60
AlexD
Member#: 270986
PMd! Sorry
Old 12-22-2011, 08:23 AM   #61
AlexD
Member#: 270986
Btw, the engine and the rest of the car is complete, except for the gearbox - it seems it has developed a glitch with the valvebody, because as soon as it heats up a bit it starts misshifting and missing gears...sent back to AUS to have it checked. We got some preliminary runs on the dyno, but due to the gearbox problem couldn't fully wind the boost and timing up - so we're still sitting and waiting for the box to arrive. And that's taking FOREVER!
Old 12-22-2011, 11:32 AM   #62
atvracer111
Member#: 112179
2015 0RS,15STI,16wrx
Red, Black, Black
Did you do any mods to add support to the front where you cut the radiator support out? This is one awesome build, good luck and keep the post coming.
atvracer111 is offline   Reply With Quote
Old 12-22-2011, 12:17 PM   #63
AlexD
Member#: 270986
No, just cut it out. It's not some heavy load bearing part or crucially significant for the body rigidity, just holds the radiator, so i don't think that anything will fall apart
Old 12-23-2011, 09:58 AM   #64
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Thanks for the reply Alex!
Old 12-26-2011, 11:21 PM   #65
speedyHAM
Member#: 48377
1996 Gutted, built
XP class Impreza L
So- where is the radiator in this car?
Build looks awesome. Post a dyno graph when you have one.
Old 03-15-2012, 06:15 PM   #66
h6turbo
Member#: 223498
hi
i need race bearings part number for ez3r please
h6turbo is offline   Reply With Quote
Old 03-15-2012, 06:24 PM   #67
Seraphinwolf
Member#: 150922
97 OBS EZ30R
There isn't a set bearing part number for the EZ30R. Rod bearings are easy but the main I need to measure when I open my block to make sure I have right clearances to get the right bearings. I had started emailing ACL last year but I'm not ire what happened to the guy I was working with...
Old 03-15-2012, 06:49 PM   #68
h6turbo
Member#: 223498
ok
do you have any part number for Rod bearings please
Old 03-15-2012, 06:59 PM   #69
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Yeah they are standard 52mm rod bearings. You'll just need to order two sets. I have a feeling the mains will be simular in the fact that they will match some other Subaru bearing but will just need to order two sets to make one set and some spares. I'll have to pull up the part number on the rod bearings in a second. I need to either look it up or grab my notebook I know i have it writen in on a STi build's part list.
Old 03-15-2012, 07:12 PM   #70
h6turbo
Member#: 223498
Old 05-15-2012, 06:02 PM   #71
Seraphinwolf
Member#: 150922
97 OBS EZ30R
Any updates Alex?
Old 05-16-2012, 05:33 AM   #72
Spec C
Member#: 77737
2003 spec C
Sorry just seen this
I dont think the main shells from anything else will be of any use, the mains on the EZ30 are rather narrow, happy to be corrected though as i t look like we are stuck with subaru main shells
Spec C is offline   Reply With Quote
Old 05-16-2012, 05:48 AM   #73
Seraphinwolf
Member#: 150922
97 OBS EZ30R
No problem dude. I've been dragging my ass on cracking my block open to measure cause I keep spending money on other parts of the car so I don't have motivation to split the block at the moment...
Old 05-16-2012, 10:32 PM   #74
jzk25
Member#: 179120
You can use the EJ bearings if you get rods made to accomodate them. That is what was done for the EZ30 in the blue GC8. It has argo rods.
jzk25 is offline   Reply With Quote
Old 05-17-2012, 01:45 AM   #75
Seraphinwolf
Member#: 150922
97 OBS EZ30R
We already knew that. We are talking main bearings, not the rod bearings.
H6 Twin Turbo Wrx Sti natefrank General Community 204 03-03-2015 11:12 PM
H6 Twin Turbo Build Legacy_H6TT Built Motor Discussion 185 05-07-2014 04:49 PM
Another twin turboed EG33 Impreza JEEENKINNNS Subaru Conversions 14 04-30-2013 09:24 PM
Twin Turbo GC8 Impreza! No Reserve! Davidss Private Vehicle 'For Sale' Classifieds 20 01-09-2006 03:14 PM
H6 Twin Turbo Diabolical1 CC Subaru Conversions 27 12-28-2004 05:01 PM
