Old 10-08-2011, 03:44 PM   #1
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
Question romraider logger wont connect/cuts out
i have done some much reading and posting and testing and this problem is only getting worse, i put in my new motor and wired up my avcs and everything as working great untill about 300 miles in had finished my second oil change and my friends convenced me to go to Big even # at gillman subaru, so i unplugged my tactrix, ( normaly leave it plugged in and just take out the computer ) and ever since then the logger wants to cut out under 100% throttle. i have posted over on romraider and tried pretty much everything possible, and the only thing happening is that its getting worse, i have tried two other tactrix cables, one being a 2.0 and 2 others are 1.3, also tried two laptops, nothing worked, i tried my tactrix and computer in my friends and it worked just fine so i know its my car this is the thread i have over on romraider,
http://www.romraider.com/forum/viewt...t=7686&start=0
im about to or put in my usdm wrx ecu and see if maybe by some chance its the ecu, hope its not, but im really running out of issues, the car runs great, i just cant log anything, and now im a little worried about even flashing the car but i dont have much of an issue at this point.
seanathanq83 is offline   Reply With Quote
Old 10-09-2011, 01:22 PM   #2
dux10
Member#: 235338
2002 Faggin Wagon
srp
http://forums.nasioc.com/forums/show...ighlight=choke
have had this problem before as well on some cars. I use 3 chokes and it works like a charm everytime!
dux10 is offline   Reply With Quote
Old 10-09-2011, 01:25 PM   #3
seanathanq83
Member#: 173241
I have 2 on there and its not even attempting to help lol
Old 10-11-2011, 02:25 AM   #4
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
If it usually cuts out at the same RPM/load, then you're probably knocking at that RPM/load combo. Try pulling a couple degrees of timing and see if that helps.
Old 12-19-2011, 06:45 PM   #5
WRteXan
Member#: 223894
Did you get this sorted out? I just 'upgraded' from the 1.3 to the 2.0 cable and am having logging issues too. Half the time it doesn't log when I press the defrost button, the other half, I only get a WOT run up to 4k RPM. I had no issues until I went to the new cable and updated all the software.
WRteXan is offline   Reply With Quote
Old 12-19-2011, 08:47 PM   #6
alottaboost
Member#: 158029
2005 STi
Did you add chokes too? I had similar issues until I added 3 chokes.
alottaboost is offline   Reply With Quote
Old 12-20-2011, 10:59 AM   #7
WRteXan
Member#: 223894
Not yet. I picked them up last night. Why is it that noise wasn't an issue with the 1.3 but suddenly is with the 2.0. Or is there a glitch in the lastest rom raider release. I'm going to try logging with my 1.3 to narrow it down.
Old 12-21-2011, 02:27 AM   #8
seanathanq83
Member#: 173241
Actually I had two issues, one I believe to be a wire that ended up breaking, it was actually the ground for the tps, and that I didn't have A ground from the battery to the chassis. The other, well I can only assume, but for some reason the version of Java I had, and the new rom raider dont seem to work well with my computer, so i have actually gone back to 5.3RC10 and all seems well and dandy now.
So like I have seen mentioned try different com ports and make sure you have the correct one selected
Old 12-21-2011, 04:00 PM   #9
WRteXan
Member#: 223894
The 1.3 cable is rock solid on logging. The 2.0 is finicky. I have the 2.0 logging now, but I have to run it over my steering wheel, in front of the shifter, and then hold my mouth just right. I never got around to installing the chokes. I have a 2008 2.5i that requires the 2.0, but I think I'm going to stick with the 1.3 for the rest of my fleet.
Old 12-24-2011, 10:39 PM   #10
punchjamesarnol
Member#: 284835
2014 Hyundai Equus
White Pearl Mica
I had trouble with my USB cable... Have an extra one on standby.
PLX m300 with Romraider Logger? cthor Open Source Reflashes 5 05-20-2014 11:40 PM
Logger cuts out under 100% Throttle MConte05 Open Source Reflashes 9 08-20-2009 07:15 AM
Romraider Logger awwsheet Open Source Reflashes 0 07-15-2009 11:07 PM
Romraider logger, boost reading Serkan Open Source Reflashes 1 06-11-2009 12:39 PM
RomRaider logger issues...I think zavier Open Source Reflashes 4 06-16-2008 01:51 PM
