Old 12-27-2011, 12:15 PM   #1
Dailyworks
Member#: 265130
2004 WRX
Default Ecuflash won't recognize def file
2004 Wrx MT
I've been communicating with tactrix for a lengthy while and can't figure out what the problem is. Romraider logs but can't upload my rom image. I have a lengthy talk in a text file but can't upload it for some reason. Can email it. I suspect a locked or modified ecu? But i'm very unsure
I have
-good voltage
-the right connectors connected(Car goes into test mode)
-Can log in RR
-ecuflash reconizes it and pulls the rom.
I'm very frustrated and tactrix has been very helpful but cannot get me through this problem
-My laptop is a Asus with windows 7
Dailyworks is offline   Reply With Quote
Old 12-27-2011, 10:01 PM   #2
quazimoto
Member#: 70395
If you can pull the ROM then your waiting to long to initiate ECU flash. You need to initiate the flash before the car goes into test mode. Or maybe a pin got pushed back in your OBDII connector.
Old 12-28-2011, 05:15 PM   #3
Dailyworks
Member#: 265130
2004 WRX
I've tried waiting and tried initiating right when keying the car on. no change. If i pin was pushed back it wouldn't log in RR right?
Old 12-28-2011, 07:35 PM   #4
quazimoto
Member#: 70395
Not necessarily.
Old 12-28-2011, 08:44 PM   #5
Paul H
Member#: 21842
2004 WRX Wagon
Black with Dents
I am no expert but I regularly flash my 04wx 5MT this way:
Key out of ignition
White block plugged in
green connectors connected
Cable plugged in and turn on fully charged laptop without any programs running
Turn ignition key - you hear the fans cycle on and off
Start Ecuflash and open map you want to load
Test Write to ECU-once complete then Write to Ecu
Once write is complete shut down Ecuflash, remove key from ignition, disconnect green connectors, remove white block. At this point I run "Learning View" to check that IAM is changed.
Start car and log with Romraider
Hope this helps,
Paul
Paul H is offline   Reply With Quote
Old 03-28-2014, 09:11 PM   #6
misfitsfreak81
Member#: 346751
im having the same problem as the OP, i can pull the rom but it says that its not recognized by ecuflash. ive tried everything i can think of or have read on nasioc and rr site. i even sourced the ecu deffs from xpt tuning for both rr and ecuflash. any other suggestions or help is awesome. thanks.
mike
misfitsfreak81 is offline   Reply With Quote
Old 03-29-2014, 08:34 AM   #7
quazimoto
Member#: 70395
it helps if you state what vehicle you have. You also need to have the lateest definitions for all programs (located on Romraider's website) and tell the programs where the definitions are. Read all of this:
http://www.romraider.com/Documentation/RomRaiderFAQ
http://www.romraider.com/Documentation/TuningFAQ
Old 03-29-2014, 12:49 PM   #8
misfitsfreak81
Member#: 346751
It's for a 2004 wrx wagon 5spd, stage 2 xpt tune with all supporting mods. Yes, thanks, I've read all that numerous times to be sure I wasn't missing a step. All the definitions are the latest one and in the correct places as far as I can tell. Any other suggestions?
Old 03-30-2014, 06:50 AM   #9
quazimoto
Member#: 70395
You need to include the XPT definition file with the other definitions.
Old 03-30-2014, 04:33 PM   #10
misfitsfreak81
Member#: 346751
quazimoto, ive also done that as well. still wont recognize it. im running out of ideas here.
location of the deff file is as follows for ecuflash C:\Program Files (x86)\OpenECU\EcuFlash\rommetadata\subaru\Impreza WRX
in romraider its in the the same location as the rest of the ecu deffs in the deff manager file
Old 03-30-2014, 04:45 PM   #11
Beauch
Member#: 224241
2004 Impreza wrx
platinum silver
make sure you got it as a bin file or hex. I had similar issues for some reason it wasn't saving it as the proper file type. make sure to type it in when saving. doesn't happen often but give it a try.
I'm referring the the map image, of course.
also much easier to edit with ecu flash and for flashing
Beauch is offline   Reply With Quote
Can't Unzip ecu def. file into the ecuflash directory 1BadP71 Open Source Reflashes 4 12-26-2011 07:21 PM
Keyhole won't recognize my key and won't unlock! Bet On Grey Interior & Exterior Modification 10 03-28-2010 01:10 PM
2010 WRX - Def Files elevenpoint7five Open Source Reflashes 0 01-08-2010 06:52 AM
Liteon LTC-4816H Won't Recognize DVDs Driveway Off-Topic 6 04-04-2004 05:45 PM
clutch problems- car won't recognize gears leeny79 Transmission (AT/MT) & Driveline 2 10-11-2002 01:04 AM
