Old 12-10-2011, 05:50 PM   #1
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
Default Would a boost leak cause knock correction?
I recently changed out my uppipe with an identical uppipe (welds broke) and since then the car has been running a little funny .. I logged it today and I'm getting some knock correction. I haven't messed with the map in about 5 years and nothing else has changed either. I'm not sure how to check for boost leaks though besides listening for them and I don't hear anything
Here is the run
https://docs.google.com/spreadsheet/...hl=en_US#gid=0
Thanks for any help
Chris
criscross79 is offline   Reply With Quote
Old 12-28-2011, 09:53 PM   #2
criscross79
Member#: 12263
'02 WRX SRP 4EAT
XPT Stg II
So, I checked the vacume hoses and lo and behold, I found one that was completely disconnected!! I hooked it back up and took the car out again to do some more logs. Unfortunately the car still has a lot of knock correction. At one point (Run 2) it hit -12 although it happened right after I let off. It looks like the timing is ok right up to about 5100 rpm. After that, it starts dipping down into the negatives. Any new ideas? On a good note, I didn't notice any stuttering on mid-throttle acceleration, so I think fixing the vacume hose helped something :-)
Chris
Run 1 - https://docs.google.com/spreadsheet/...1pIWmJoem1HbEE
Run 2 - https://docs.google.com/spreadsheet/...mxWTGFJVlFERHc
Run 3 - https://docs.google.com/spreadsheet/...nBYRjZEZEVvMlE
Run 4 - https://docs.google.com/spreadsheet/...HBrZkUxSkloc2c
Run 5 - (Long) https://docs.google.com/spreadsheet/...lIwdnFKSzNOUXc
Old 12-28-2011, 11:07 PM   #3
Airboy
Member#: 72829
2006 WRX
2015 WRX
Check for leak after MAF and before turbo.
Check/clean MAF.
What are your fuel trims?
Use LearningView to get a snapshot of the learned data.
http://www.romraider.com/forum/viewt...hp?f=32&t=7397
I suspect you are running lean in boost. Do not do full throttle runs anymore until you get it sorted out.
Airboy is offline   Reply With Quote
Leak causing knock? dlh1999 Open Source Reflashes 2 11-16-2009 07:20 PM
Can a boost leak cause a knock? Deserted1 Engine Management & Tuning 2 04-18-2009 01:02 PM
would a uppipe leak cause a performace loss tsubaru02 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-18-2005 12:41 PM
boost leak causing lag? HubbieScooby Normally Aspirated with bolt-on Forced Induction Powertrain 2 04-15-2004 03:23 PM
can a boost leak cause high egts? WRxednEffect Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-06-2002 11:22 AM
