Welcome to the North American Subaru Impreza Owners Club Thursday June 20, 2013
Old 12-20-2011, 05:13 PM   #26
NOFTCHX
Member#: 304507
2006 wrx
black/white
Default brembo to wheel clearance
im new so dont murder me lol
just did sti tranny and brembo swap but front brembos dont clear my rims in the front. jw what offset do you need to clear the brembos. currently im running a 17 by 9 rim with plus 44 offset....thank you
NOFTCHX is offline   Reply With Quote
Old 12-20-2011, 08:14 PM   #27
sc00by4life
Member#: 97135
offset doesn't determine brake clearance, wheel design does….what wheels do you have?
sc00by4life is online now   Reply With Quote
Old 12-20-2011, 08:15 PM   #28
NOFTCHX
Member#: 304507
2006 wrx
black/white
Work emotions cr-kia or whatever
Old 12-26-2011, 01:00 PM   #29
sababa1
Member#: 301296
2008 wrx
SS
Looking into getting the 2011 WRX rims for my 2008 WRX. Does anybody know if I will have any fitment issues?
sababa1 is offline   Reply With Quote
Old 12-26-2011, 07:19 PM   #30
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
They will fit fine.
dbrier is offline   Reply With Quote
Old 12-30-2011, 11:52 AM   #31
DrDanimalSize
Member#: 254097
2010 WRX Hatch
This is my car. Plenty of others have done the same, I really like the look
DrDanimalSize is offline   Reply With Quote
Old 12-30-2011, 06:11 PM   #32
sababa1
Member#: 301296
2008 wrx
SS
awesome! looks good.
Old 12-30-2011, 08:45 PM   #33
Big-E
Member#: 123843
2006 SGM WRX S2
Let LED's light your way!
Excellent list!
Originally Posted by Mach V Dan View Post
2006-07 WRX
Offset: +53
Bolt pattern: 5x100
Wheel Weight: 21.0 lbs (Mach V shipping scale)
OEM-equipped tire size: 215/45R17
I have a 2006 WRX sedan that came with these wheels and on one of the inside spokes on each wheel is: 17x7JJ55, which should mean these have a +55 offset? Yes?
Old 12-31-2011, 12:14 AM   #34
Mach V Dan
Member#: 12029
Originally Posted by Omega_2nr View Post
What....no UK wrx 17's?
Fixed.
Yes.
--Dan
Mach V
FastWRX.com
Mach V Dan is offline   Reply With Quote
Old 01-10-2012, 06:08 PM   #35
Jubert39
Member#: 155598
2004 AW Subaru WRX
JDM v7 STI spec-C
Im kinda confused. According to the first post, its states 04 STI bbs 17x7.5 weighs in at 15.7 lbs each. The 05-07 STI bbs 17x8 weighs in at 19lbs each. Does the 0.5 inch really add 3.3lbs to the wheel? DAMN!
Jubert39 is offline   Reply With Quote
Old 01-11-2012, 02:41 PM   #36
Mach V Dan
Member#: 12029
Those weights are correct. It's not just the wheel width -- the later wheel has a 14.3mm larger bolt circle, which means the center pad is significantly wider, and therefore it weighs more.
--Dan
Mach V
FastWRX.com
Old 01-12-2012, 11:20 AM   #37
pRiMe DiReCtIvE
Member#: 301387
2012 Impreza HB
Black/Dark Grey
How about the 2012 Impreza Sport Premiums? What stock rims can it use?
pRiMe DiReCtIvE is offline   Reply With Quote
Old 01-12-2012, 05:26 PM   #38
07 STI UGM
Member#: 172044
2007 STI
URBAN GRAY
I second this question what is the bolt pattern and offset on a 2012 impreza sport
07 STI UGM is offline   Reply With Quote
Old 01-12-2012, 09:41 PM   #39
Mach V Dan
Member#: 12029
They're still 5x100 bolt pattern, and the Premium and Sport wheels are 17x7. I don't yet know the offset or weight, but have asked over on the 2012 Impreza mega-thread.
--Dan
Mach V
FastWRX.com
Old 01-13-2012, 12:06 AM   #40
NineBreaker
Member#: 237756
2011 2.5i Sedan
What about the OBS/LGT wheels?
NineBreaker is offline   Reply With Quote
Old 01-15-2012, 03:04 PM   #41
SubaDre7
Member#: 242645
Very helpful, thank you!
SubaDre7 is offline   Reply With Quote
Old 01-17-2012, 10:24 PM   #42
Superdude
Member#: 88741
2005 Impreza WRX
I'm having a hard time finding this info. Will a 245w fit on the 2004 STi wheel? I have an 05 WRX and I run STX in the ATL autox. I need to go upto the max width which is 245.
Thanks for the write-up best one on this interwebz!
Superdude is offline   Reply With Quote
Old 01-18-2012, 09:11 AM   #43
Mach V Dan
Member#: 12029
This question should be asked somewhere else. This thread is intended to give factory Subaru wheel specifications. Start a new thread (or find an existing one) asking about specific non-stock tire fitment.
Thank you.
--Dan
Mach V
FastWRX.com
Old 01-18-2012, 09:49 AM   #44
Mach V Dan
Member#: 12029
Added. Can someone get me a weight on this one?
--Dan
Mach V
FastWRX.com
Old 01-18-2012, 10:40 AM   #45
flat4LGT
Member#: 237565
I haz 06
WRB Wagon
The OBS and 2007-2009 LGT do not have the same wheels
LGT 07-09
Offset: +55
Bolt Pattern: 5x100
Weight: not sure
OEM tire size: 215/45R17
flat4LGT is online now   Reply With Quote
Old 01-23-2012, 04:22 PM   #46
Mach V Dan
Member#: 12029
Hey, you're right! Thanks. I'll update the list when I have a chance.
--Dan
Mach V
FastWRX.com
Old 01-31-2012, 11:48 AM   #47
iceyinferno
Member#: 255696
2004 STi
Okay. I've done a lot of research for the information shown here, but I'm not some kind of all-seeing, all-knowing wise man. Most of the information above, I FOUND ON THE INTERNET. Got a wheel that is not listed here, that you want to know the weight and other information? Use Google, and track down the answers to your question. Report back here, and tell us what you found. I'll update the thread accordingly.
Or, you can call me and pay me to do research for you. I'd be okay with that.
--Dan
Mach V
FastWRX.com
The Dan from Mach V that I know is an all-seeing, all-knowing wise man. What have you done with him?!? I'm going to call the authorities!!
Great post. Tons of valuable information in one spot! Thanks again 'imposter' Dan
iceyinferno is offline   Reply With Quote
Old 02-01-2012, 12:47 AM   #48
I3eXa
Member#: 30732
2002 Legacy GT, 2004
Impreza OBS
quick question. I have a 2004 OBS, it should of had 16s but it came with 15s steel wheels. Got a line of some cheap 2006 wrx wheels/tires - 215/45R17. They should fit right?
I3eXa is offline   Reply With Quote
Old 02-01-2012, 12:54 AM   #49
S53089
Member#: 172942
1992 Mazda B2600i
Drift Slut
Yesss
S53089 is offline   Reply With Quote
Old 02-01-2012, 02:21 AM   #50
I3eXa
Member#: 30732
Impreza OBS
I assumed so but wanted to make sure.
Thanks. and kudos on a good thread!
WTB : Alloy WHEELS or nicer oem subaru wheels to replace my ugly steel wheels MR2fanatic Tri-State Area Private Classifieds 7 04-03-2011 09:24 PM
WTT: OEM subaru wheels/tires for Gold 17" wheels veselik3 NWIC Private Classifieds 2 05-16-2006 03:24 PM
gauging interest: rs 16x7 gold wheels 5 spoke oem subaru wheels anthonyrb98 Private 'For Sale' Classifieds 53 04-27-2006 12:43 PM
Anyone have a set of OEM WRX wheels they want to get rid of? Skibum4444 North West Impreza Club Forum -- NWIC 2 01-31-2003 12:48 AM
Subaru Wheel Specs Snowrider Brakes, Steering & Suspension 3 10-07-2001 09:20 PM
Message Board Statistics All times are GMT -4. The time now is 12:59 AM.
