Old 01-02-2012, 07:34 AM   #1
mike the pipe
Member#: 297236
2003 wrx edm
blue
Angry open source help
i am currently trying to connect my ecu to open source tuning. i am new to the scene but seems pretty straight forward, i thought. i tried romraider ecuexplorer and ecu flash on vista with tactrix 2.0 and evoscan 1.3, none like my ecu. rr says car def not found. with latest download, ecuexplorer doesnt bring up my ecu id #. and ecu flash not sure if i should connect test mode connectors or not. my03 edm wrx has vortec tbe and catless uppipe and air filter. please help! my next shot will be with xp and 7. ????
mike the pipe is offline   Reply With Quote
Old 01-02-2012, 09:05 AM   #2
dux10
Member#: 235338
2002 Faggin Wagon
srp
u must A)see download the latest ecu definitions for RR and then ECU flash since theyre different. B) u must connect the test mode connectors.
dux10 is offline   Reply With Quote
Old 01-02-2012, 09:59 AM   #3
quazimoto
Member#: 70395
Read......the.............FAQ's. Both here and the complete one on Romraider. 90% of the problem comes from people not reading the FAQ's before hand and just jumping into it. Ecuflash is the program that actually reflashes the ECU. Romraider is just an editor/logger.
quazimoto is online now   Reply With Quote
Old 01-02-2012, 10:26 AM   #4
jnmarshall
Member#: 40500
16 Forester XT
Check out the forums at RomRaider. Did you set your definitions directory for ecuflash and romraider? The defaults do not point to them. If you have win7 you have to set the properties for each shortcut to run as administrator. How to do all this is explained in the RomRaider forums. For '03 to just read and datalog I don't remember having to plug test connectors. Only when flashing do you need the flash plug AND the test connectors plugged together. The forums over there are extremely helpful and user friendly so don't be afraid to ask.
jnmarshall is offline   Reply With Quote
Open Source Help chatch82 New England Impreza Club Forum -- NESIC 3 06-17-2011 01:35 PM
open source help around Hartford/Manchester/bristol/winsor jaxx4k New England Impreza Club Forum -- NESIC 1 01-12-2011 07:04 PM
open source help password:ej20 Open Source Reflashes 1 09-14-2009 12:53 AM
open source help DAV3_02 New England Impreza Club Forum -- NESIC 7 04-06-2009 09:54 AM
Open source help Zspectrum Texas Impreza Club Forum -- TXIC 10 11-09-2007 11:05 AM
