#1 |
Member#: 301431
AKIC
Vehicle:2010 Subaru WRX OBP Hatch |
For the 02-07 WRX guys & gals ...
I am having a hard time finding/ deciding on lowering springs for my car. My main intention for getting lowering springs is for the look. Less wheel gap while still maintaining a comfy ride. Ive been hearing mixed reviews on many different springs, i.e. S-Techs are trash because they blow your shocks. Best way to find out is to ask you guys who have had experience with springs and how they ride on our Alaskan roads. What springs are you guys running? How are they holding up in Alaska's roads? Springs you guys would recommend? Post pics if you have them. Any help is appreciated.
#2 |
Member#: 290953
Vehicle:'12 STi Ltd. |
why not shoot for coilovers? just curious.
#3 |
Member#: 129089
AKIC
Vehicle:06 Impreza2.5Bug-i OBP |
Stock '04 STI springs on the stock '06 2.5i struts. So far, so good. Not too low, no blood in my urine from bruised kidneys.
#4 |
Member#: 226059
AKIC
Vehicle:low and slow forester |
ISC N1 coilovers here. I wanted the ability to lower the car to my taste and not be limited to the height of springs. Overall very pleased with them. However, I have debated putting stock springs/struts back on for the winter, as the coilovers are very stiff and I didn't want them rusting up. However, I have kept them on so far, and get around just fine.
When you lower the vehicle, you WILL be plowing more snow in the winter (obviously). Whether you care about that or not is up to. I'm not sure any other problems you would run into with lowering springs just because it's winter time in Alaska..? More prone to high centering if you're not careful? |
#5 |
Member#: 6214
AKIC
Vehicle:92 Corrado SLC 01.5 S4 |
Personally, I'd recommend splurging and going with a set of coilovers. From my experience, both in installing lowering springs (pinks on the 2nd LGT) on stock struts, and pricing out springs with matching struts, which are highly recommended. The cost difference one might as well go with a coilover setup.
#6 |
Member#: 94836
AKIC
Vehicle:2oo5 STi Aspen 2o12 PiLoT CherrY |
Ive been rolling on jdm sti 05 springs for a while before I switched to RCE Tarmac 2s. Does fine in the winter. I also was thinking about switching back to the springs for winters.
That being said, I have a set of JDM pinks you might be able talk me out of. Not sure if they will work on a WRX though. |
#7 |
Member#: 217208
AKIC
I'm an advocate of a matched strut/spring combo. For the cost of a set of junk coilovers, you can get a strut/spring combo that will easily outperform the cheap coilovers.
My recommendations for Alaska? Feal revalved 04 STI struts with RCE Yellows if you want a progressive rate or Swift Spec-R if you want a straight rate spring. You'll notice that the RCEs include bump stops, and that Swift instructs you to modify the stockers, no one else addresses this crucial area. The WRX/STI already rides on the bump stop stock (even though it has more than enough strut travel), when you lower it, you're even further into it. A fully compressed bump stop has a spring rate of INFINITY, which certainly doesn't make for the best ride. Mild drop with both, that doesn't negatively affect the roll center and LCA position, and the revalves are an excellent addition to the already strong inverted STI strut setup. http://www.swiftsprings.com/file/ss.pdf http://www.fastwrx.com/rcesprings.html http://odib.web.officelive.com/Subar...leService.aspx Last edited by retrac; 01-12-2012 at 05:41 PM. Reason: Added links. |
#8 |
Member#: 132030
AKIC
Vehicle:2007 obp STI 95 impreza (rally beater) |
I had Cobb springs on my 07 wrx, got rid of them to run bc racing coilovers and still running them on my 07 sti, no complaints from the coils, better then the springs IMHO
#9 |
Member#: 127922
AKIC
Vehicle:2012 VW Golf Mk6 TSI Supercharged AND Turboed! |
I've got the Cobb springs designed for the stock struts, no problems and a great ride. I personally didn't think it was too much different from the feel of stock. As for durability, no problem there at all either. I have probably 25k miles on 'em now. I've been down the Alcan to California, then over to New Mexico driving Route 66 most of the way and back to Alaska, all of the way had some pretty rough roads and the Cobbs handled it perfect. I would have liked the back to be a bit higher, but I still think it looks great.
#10 |
Member#: 301431
AKIC
Thanks for all the recommendations and feed back. I really just wanted springs for temporary set up and go full coilovers down the road but it looks like im just going to have to start saving now. The only springs i would consider are the Cobb springs. Cant find any forsale though. Are they discontinued?
#11 | |
Member#: 217208
AKIC
Get RCEs or Swifts. If you give a damn at all about ride quality, you won't buy coilovers. |
#12 |
Member#: 285848
AKIC
Vehicle:1995 Impreza RaceCar 2007 Legacy SE OBP hers |
I have Tein S-Techs. I didnt cut the bump stops and they are pretty harsh. They were free and really the only reason I put them on. Otherwise, as Retrac stated, sruts and springs will most likely keep you happy. Coil overs, unless custom valved and custom spring rates are set correctly will be harsh enough to guarantee kidney failure within a few years. LOL.
#13 |
Member#: 94836
AKIC
http://www.iwsti.com/forums/gd-suspe...ers-guide.html
^^^^ Read and learn. Tons of research before purchasing my coilovers. If I were to start over, I would get RCE Yellows or Blacks, stock STi struts revalved by Feals. (which I may still do for a winter setup except with king springs) |
#14 |
Member#: 127922
AKIC
Didn't notice any change at all really, it's perfect for daily driving duties. My alignment and suspension was adjusted when installed and has been checked a few times since install and all is well. I don't race though, and the OP stated he was mostly for looks and daily driving too, so he probably doesn't care if they aren't "optimum" for the track.
Last edited by 07_BluRex; 01-12-2012 at 10:17 PM. Reason: edited to be less rude, lol |
#15 |
Member#: 94836
AKIC
Pm sent
#16 |
Member#: 117127
AKIC
Vehicle:2005 sti Obama Can't Gymkhana |
I had the feal revalved struts with rce black springs on a 2005 sti, the springs lowered the car the perfect amount I think. Especially if you plan on running the setup all year round on a dd. They stiffened the ride up a ton, the difference was night and day.
#17 |
Member#: 301431
AKIC
Going to do my research on these setups and see what fits the budget best. Thanks everyone
#18 | |
Member#: 253304
AKIC
Vehicle:2001 Impreza 2.5RS Plus MOAR |
#19 |
Member#: 241881
AKIC
Vehicle:2013 P3 Import Auto Custom Tunes, Mods. |
If you are really just going for looks and a decent ride get some BC coilovers. They are fully adjustable, height, stiffness, etc. Cheap as well. Send me a PM if you want a quote. You would be surprised how cheap you can get a full setup for. Yes they are not the best coilovers you can buy BUT for the price they are actually really nice and for your needs I would say they would fit quite well.
Going with something like this will let you raise it up and smooth it out for winter then drop it nice and low for summer. If your going to drop it a lot I would also look into skid plates to protect the critical parts under the car. |
#20 |
Member#: 6214
AKIC
I agree on at least the matched spring/strut combo's. Unfortunately on the German side of things, it wound up being (when I bought my suspensions at least) not too much more for going for a decent coilover system. A good spring/strut combo for the first S4 was ~900-1000, Stasis TrackSports were ~1500. similar with the Corrado. Perhaps some of that is cheaper on Subie's, or maybe I decided WTH, might as well. LOL.
#21 |
Member#: 160049
AKIC
Yo, I liked my Tein S-tech/oem strut never had an issue in the winter. Great ride to. And anyone who had a chance to actually drive my rig thought my setup was great........coming from people that have had a chance to drive many other modded subys.
#22 |
Member#: 296679
VIC
Vehicle:2007 STi White |
Got a pair of front sport spec mono flex teins forsale. Bought KW V3's so no longer need these. 02+imprezas/04 STi
http://vancouver.en.craigslist.ca/rd...837785291.html http://www.streettunedmotorsports.co..._coilovers.htm |
#23 |
Member#: 137569
AKIC
Vehicle:WRX Twinscroll Dez in yo mouth! |
wtf is he gonna do with JUST the fronts?.... you must be stupid AND dumb...
#24 |
Member#: 159474
AKIC
Vehicle:2013 BRZ Ltd 6MT CBS Counter-steer like a boss |
| Thread Tools | |
| Display Modes | |
| FS : Tein Lowering Springs & Original Wrx Springs | cyrus951 | Suspension/Brakes/Handling | 29 | 07-09-2011 04:26 PM |
| Slight lowering spring & damper setup for '97 Outback | ArtechnikA | Brakes, Steering & Suspension | 2 | 03-25-2006 09:51 AM |
| CA FS: lowering springs & Intake on eBay | dpflipstyle | Private 'For Sale' Classifieds | 2 | 12-12-2005 12:50 PM |
| New RS*R Lowering Springs & Progress Rear Sway Bar ! | wrxtreme2 | Private 'For Sale' Classifieds | 15 | 09-13-2005 07:34 PM |
| WTB/WTT STI lowering springs & Camber plates | GRNMTNRS | Private 'Wanted' Classifieds | 1 | 03-05-2005 04:09 AM |
