Alaskan Impreza Club
Old 01-12-2012, 05:05 PM   #1
insane_one
Member#: 301431
2010 Subaru WRX
OBP Hatch
Question Lowering Springs & Alaskan Roads
For the 02-07 WRX guys & gals ...
I am having a hard time finding/ deciding on lowering springs for my car. My main intention for getting lowering springs is for the look. Less wheel gap while still maintaining a comfy ride. Ive been hearing mixed reviews on many different springs, i.e. S-Techs are trash because they blow your shocks. Best way to find out is to ask you guys who have had experience with springs and how they ride on our Alaskan roads.
What springs are you guys running? How are they holding up in Alaska's roads? Springs you guys would recommend? Post pics if you have them.
Any help is appreciated.
insane_one is offline   Reply With Quote
Old 01-12-2012, 05:08 PM   #2
07_STi
Member#: 290953
'12 STi Ltd.
why not shoot for coilovers? just curious.
07_STi is online now   Reply With Quote
Old 01-12-2012, 05:11 PM   #3
aleutdude
Member#: 129089
06 Impreza2.5Bug-i
Stock '04 STI springs on the stock '06 2.5i struts. So far, so good. Not too low, no blood in my urine from bruised kidneys.
Old 01-12-2012, 05:20 PM   #4
akfmx
Member#: 226059
low and slow
forester
ISC N1 coilovers here. I wanted the ability to lower the car to my taste and not be limited to the height of springs. Overall very pleased with them. However, I have debated putting stock springs/struts back on for the winter, as the coilovers are very stiff and I didn't want them rusting up. However, I have kept them on so far, and get around just fine.
When you lower the vehicle, you WILL be plowing more snow in the winter (obviously). Whether you care about that or not is up to.
I'm not sure any other problems you would run into with lowering springs just because it's winter time in Alaska..? More prone to high centering if you're not careful?
akfmx is offline   Reply With Quote
Old 01-12-2012, 05:22 PM   #5
AKSubie
Member#: 6214
92 Corrado SLC
01.5 S4
Personally, I'd recommend splurging and going with a set of coilovers. From my experience, both in installing lowering springs (pinks on the 2nd LGT) on stock struts, and pricing out springs with matching struts, which are highly recommended. The cost difference one might as well go with a coilover setup.
AKSubie is offline   Reply With Quote
Old 01-12-2012, 05:29 PM   #6
LiLpNoY
Member#: 94836
2oo5 STi Aspen
2o12 PiLoT CherrY
Ive been rolling on jdm sti 05 springs for a while before I switched to RCE Tarmac 2s. Does fine in the winter. I also was thinking about switching back to the springs for winters.
That being said, I have a set of JDM pinks you might be able talk me out of. Not sure if they will work on a WRX though.
LiLpNoY is offline   Reply With Quote
Old 01-12-2012, 05:31 PM   #7
retrac
Member#: 217208
I'm an advocate of a matched strut/spring combo. For the cost of a set of junk coilovers, you can get a strut/spring combo that will easily outperform the cheap coilovers.
My recommendations for Alaska? Feal revalved 04 STI struts with RCE Yellows if you want a progressive rate or Swift Spec-R if you want a straight rate spring.
You'll notice that the RCEs include bump stops, and that Swift instructs you to modify the stockers, no one else addresses this crucial area. The WRX/STI already rides on the bump stop stock (even though it has more than enough strut travel), when you lower it, you're even further into it. A fully compressed bump stop has a spring rate of INFINITY, which certainly doesn't make for the best ride.
Mild drop with both, that doesn't negatively affect the roll center and LCA position, and the revalves are an excellent addition to the already strong inverted STI strut setup.
http://www.swiftsprings.com/file/ss.pdf
http://www.fastwrx.com/rcesprings.html
http://odib.web.officelive.com/Subar...leService.aspx
retrac is offline   Reply With Quote
Old 01-12-2012, 05:32 PM   #8
ridestreet84
Member#: 132030
2007 obp STI
95 impreza (rally beater)
I had Cobb springs on my 07 wrx, got rid of them to run bc racing coilovers and still running them on my 07 sti, no complaints from the coils, better then the springs IMHO
ridestreet84 is offline   Reply With Quote
Old 01-12-2012, 06:16 PM   #9
07_BluRex
Member#: 127922
2012 VW Golf Mk6 TSI
Supercharged AND Turboed!
I've got the Cobb springs designed for the stock struts, no problems and a great ride. I personally didn't think it was too much different from the feel of stock. As for durability, no problem there at all either. I have probably 25k miles on 'em now. I've been down the Alcan to California, then over to New Mexico driving Route 66 most of the way and back to Alaska, all of the way had some pretty rough roads and the Cobbs handled it perfect. I would have liked the back to be a bit higher, but I still think it looks great.
07_BluRex is offline   Reply With Quote
Old 01-12-2012, 07:52 PM   #10
insane_one
Member#: 301431
2010 Subaru WRX
OBP Hatch
Thanks for all the recommendations and feed back. I really just wanted springs for temporary set up and go full coilovers down the road but it looks like im just going to have to start saving now. The only springs i would consider are the Cobb springs. Cant find any forsale though. Are they discontinued?
Old 01-12-2012, 08:01 PM   #11
retrac
Member#: 217208
Yep, discontinued because they adversely changed the suspension angles and make the car understeer worse than stock, just like Tein S-Techs.
Get RCEs or Swifts. If you give a damn at all about ride quality, you won't buy coilovers.
Old 01-12-2012, 08:11 PM   #12
coldfiremx
Member#: 285848
1995 Impreza RaceCar
2007 Legacy SE OBP hers
I have Tein S-Techs. I didnt cut the bump stops and they are pretty harsh. They were free and really the only reason I put them on. Otherwise, as Retrac stated, sruts and springs will most likely keep you happy. Coil overs, unless custom valved and custom spring rates are set correctly will be harsh enough to guarantee kidney failure within a few years. LOL.
coldfiremx is offline   Reply With Quote
Old 01-12-2012, 08:28 PM   #13
LiLpNoY
Member#: 94836
2oo5 STi Aspen
2o12 PiLoT CherrY
http://www.iwsti.com/forums/gd-suspe...ers-guide.html
Read and learn. Tons of research before purchasing my coilovers.
If I were to start over, I would get RCE Yellows or Blacks, stock STi struts revalved by Feals. (which I may still do for a winter setup except with king springs)
Old 01-12-2012, 09:59 PM   #14
07_BluRex
Member#: 127922
Originally Posted by retrac View Post
Yep, discontinued because they adversely changed the suspension angles and make the car understeer worse than stock, just like Tein S-Techs..
Didn't notice any change at all really, it's perfect for daily driving duties. My alignment and suspension was adjusted when installed and has been checked a few times since install and all is well. I don't race though, and the OP stated he was mostly for looks and daily driving too, so he probably doesn't care if they aren't "optimum" for the track.
Last edited by 07_BluRex; 01-12-2012 at 10:17 PM. Reason: edited to be less rude, lol
Old 01-12-2012, 10:34 PM   #15
LiLpNoY
Member#: 94836
2oo5 STi Aspen
2o12 PiLoT CherrY
Pm sent
Old 01-13-2012, 12:29 AM   #16
907bob
Member#: 117127
2005 sti
Obama Can't Gymkhana
I had the feal revalved struts with rce black springs on a 2005 sti, the springs lowered the car the perfect amount I think. Especially if you plan on running the setup all year round on a dd. They stiffened the ride up a ton, the difference was night and day.
907bob is offline   Reply With Quote
Old 01-13-2012, 01:09 AM   #17
insane_one
Member#: 301431
2010 Subaru WRX
OBP Hatch
Going to do my research on these setups and see what fits the budget best. Thanks everyone
Old 01-13-2012, 03:08 AM   #18
kayetealynn
Member#: 253304
2001 Impreza 2.5RS
Plus MOAR
King springs ftw. On the pricy side but well worth the cost.
kayetealynn is offline   Reply With Quote
Old 01-13-2012, 03:13 PM   #19
P3Auto
Member#: 241881
2013 P3 Import Auto
Custom Tunes, Mods.
If you are really just going for looks and a decent ride get some BC coilovers. They are fully adjustable, height, stiffness, etc. Cheap as well. Send me a PM if you want a quote. You would be surprised how cheap you can get a full setup for. Yes they are not the best coilovers you can buy BUT for the price they are actually really nice and for your needs I would say they would fit quite well.
Going with something like this will let you raise it up and smooth it out for winter then drop it nice and low for summer.
If your going to drop it a lot I would also look into skid plates to protect the critical parts under the car.
P3Auto is offline   Reply With Quote
Old 01-13-2012, 04:14 PM   #20
AKSubie
Member#: 6214
92 Corrado SLC
01.5 S4
I agree on at least the matched spring/strut combo's. Unfortunately on the German side of things, it wound up being (when I bought my suspensions at least) not too much more for going for a decent coilover system. A good spring/strut combo for the first S4 was ~900-1000, Stasis TrackSports were ~1500. similar with the Corrado. Perhaps some of that is cheaper on Subie's, or maybe I decided WTH, might as well. LOL.
Old 01-14-2012, 02:27 AM   #21
White_Rice
Member#: 160049
Yo, I liked my Tein S-tech/oem strut never had an issue in the winter. Great ride to. And anyone who had a chance to actually drive my rig thought my setup was great........coming from people that have had a chance to drive many other modded subys.
White_Rice is offline   Reply With Quote
Old 02-06-2012, 03:56 PM   #22
Lamarre
Member#: 296679
2007 STi
Got a pair of front sport spec mono flex teins forsale. Bought KW V3's so no longer need these. 02+imprezas/04 STi
http://vancouver.en.craigslist.ca/rd...837785291.html
http://www.streettunedmotorsports.co..._coilovers.htm
Lamarre is offline   Reply With Quote
Old 02-07-2012, 03:28 PM   #23
Marlons101
Member#: 137569
WRX Twinscroll
Dez in yo mouth!
wtf is he gonna do with JUST the fronts?.... you must be stupid AND dumb...
Marlons101 is offline   Reply With Quote
Old 02-07-2012, 04:32 PM   #24
chanomatik
Member#: 159474
2013 BRZ Ltd 6MT CBS
Counter-steer like a boss
FS : Tein Lowering Springs & Original Wrx Springs cyrus951 Suspension/Brakes/Handling 29 07-09-2011 04:26 PM
Slight lowering spring & damper setup for '97 Outback ArtechnikA Brakes, Steering & Suspension 2 03-25-2006 09:51 AM
CA FS: lowering springs & Intake on eBay dpflipstyle Private 'For Sale' Classifieds 2 12-12-2005 12:50 PM
New RS*R Lowering Springs & Progress Rear Sway Bar ! wrxtreme2 Private 'For Sale' Classifieds 15 09-13-2005 07:34 PM
WTB/WTT STI lowering springs & Camber plates GRNMTNRS Private 'Wanted' Classifieds 1 03-05-2005 04:09 AM
Message Board Statistics All times are GMT -4. The time now is 02:22 AM.
