Old 01-12-2012, 03:07 AM   #1301
drift king
Member#: 26493
99 Impreza RSTI
Caddy were you at in vegas? i need some help like this.
drift king is offline   Reply With Quote
Old 01-13-2012, 12:00 AM   #1302
Str8Gone
Member#: 147972
2004 wrx hybrid 18g
[email protected] dd
^Cadillac I want your pullies I just removed my sunvisors, the small front interior lights and the metal pieces behind the oh **** handles. Then I redid the headliner in black to cover up the holes from deleted items, about 50$ in material for the headliner. I'd say a good 5lbs reduction from the roof area.
Str8Gone is offline   Reply With Quote
Old 01-13-2012, 07:34 AM   #1303
Hold_Fast
Member#: 175837
#61 9.5% FP
Speaking of Cadillac's pulley's, where the hell did you get those?
Hold_Fast is online now   Reply With Quote
Old 01-13-2012, 12:40 PM   #1304
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Judging by the name on the pulley, unorthodox racing
Splinter is offline   Reply With Quote
Old 01-13-2012, 01:17 PM   #1305
68Cadillac
Member#: 95901
Yep, My pulleys are Unorthodox Racing. Red Anodized, Under-driven, All Aluminum. I wrote a review.
Initially I didn't want the under-driven or even the red. UR found they couldnt sell them and had a blow out sale 4 years ago for all under-driven and/or color tinted products. Sold them at like 65% off so they could unload them from the warehouse.
Old 01-13-2012, 01:33 PM   #1306
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
you drive with your new bracket? does it slip or stay tight?
bue car is offline   Reply With Quote
Old 01-13-2012, 01:54 PM   #1307
ATDmotorsports
Member#: 304907
Do these things squeak like crazy on start up or when it's cold?
ATDmotorsports is offline   Reply With Quote
Old 01-13-2012, 02:05 PM   #1308
Hold_Fast
Member#: 175837
#61 9.5% FP
:facepalm: You guys are the best.
Old 01-13-2012, 03:20 PM   #1309
68Cadillac
Member#: 95901
Only had it on a few days. Stays right where I set it.
It doesn't get really cold where I live (<---see sidebar) but I haven't noticed any squealling when it gets super duper cold (~30 degrees F).
Here's how I tighten my belt now. When I first did it I actually did it too tight. Virtually no play at all. Backed it off to about 1/4" of play now.
Old 01-20-2012, 01:30 AM   #1310
68Cadillac
Member#: 95901
I bought a set of Tumble Generator Valves and an intake manifold from a salvage yard. I admit it's nice to have the spare set to work on so I don't feel rushed to get it back on the car and working.
Using JB Weld like a pro on the TGV deletes.
Green Brackets of Death will no longer work with my set up, plus new holes
The backside
They're still rough I wanted to show something mid way through.
Old 01-21-2012, 05:45 PM   #1311
gtasti
Member#: 152036
2004 Sti
how much u pay for those from the wreakers
looks like a good idea
gtasti is offline   Reply With Quote
Old 01-21-2012, 06:50 PM   #1312
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
I cheated and bought one of those one piece spec c manifolds
Yesterday I made a little in-tank anti fuel surge device whcih cost me nothing to make. Petrol weight is 1Litre = 0.711kg so for example if you were running the tank with only 20 Litres in it you are saving around 28.5kg in a wrx with a 60L tank which is very significant!
Here it is
I then added a few holes but only on the right hand side because wrx's suffer from fuel surge on long high G right hand turns. What happens is when you make a right hand turn all the fuel goes flying across the fuel tank to the left hand side and if the corner is long enough there won't be enough fuel at the pickup to power out of the corner. This starts happening on certain corners in my car at half a tank of fuel. So by having no holes on the left hand side of the anti surge tank the fuel can not escape in a right hand turn.
Right hand side
Front
Left hand side
The fuel pump assembly also has a little pump that bring fuel back over from the left hand side and drops it above the pickup sock. I have extended this so it drops the fuel into my anti surge tank
You can see I have a cable tie wrapped around the fuel pump to hold everything in place when I slide it back into the cars fuel tank
I was able to test it on some long right hand corners near my house and it worked a treat, no sign of fuel surge with bugger all petrol in the tank!
This is where my fuel was at during testing this afternoon.
JDwhiteWRX is offline   Reply With Quote
Old 01-22-2012, 12:08 PM   #1313
gtasti
Member#: 152036
2004 Sti
wow great idea jdwhite
what kinda bottle is that also your pick up location is on the passenger side of the car right
maybe I'll do something like this to mine
Old 01-22-2012, 12:59 PM   #1314
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
Buy a second fuel pump housing assembly and put it on the opposite side... With your home made piece like the other side.
u2_m4r1n3 is offline   Reply With Quote
Old 01-22-2012, 06:23 PM   #1315
JDwhiteWRX
Member#: 190502
2005 VF36 WRX
Its a diff oil bottle, you can use anything made from HDPE, most people use radio controlled aeroplane fuel tanks but my pickup sock was too big so I just looked for bottles in my garage and found the almost empty diff oil container.
I can't take the credit for the idea, my friend did one on his car and it worked really well, I found the details here http://www.rs25.com/forums/f128/t491...cing-help.html
My car is RHD, pickup is on the drivers side.
Old 01-23-2012, 12:24 AM   #1316
gtasti
Member#: 152036
2004 Sti
ok thanks for the clearfication of the pick-up wasnt sure if the right hand right drive had it on the left side or not thanks
Old 01-24-2012, 10:07 AM   #1317
A-man07
Member#: 271525
07 STi
424whp/382wtq GT3076
Originally Posted by JDwhiteWRX View Post
Loving the Vans. Memories of 25 years ago : )
Old 01-24-2012, 10:28 AM   #1318
Hold_Fast
Member#: 175837
#61 9.5% FP
Currently getting rid of mine too. Do you forsee any problems with mounting the upper coolant reservoir now that one of the mounting points will be gone?
Old 01-24-2012, 01:29 PM   #1319
68Cadillac
Member#: 95901
None whatsoever. I removed the upper coolant reservoir tab connecting to the GBoD long ago.
I bought my used parts from a salvage yard I found from Car-Part.com. Don't forget the Dash. Car DASH Part. Currently they have them listed from $95 - $300. I think I waited and bought mine for $70 plus shipping for both TGVs and the Manifold. Just depends on the stock the individual yards have the day you look. Neat thing is once I'm done and swap out I can sell the one that came with the car right here on NASIOC and get my money back.
Old 01-24-2012, 01:45 PM   #1320
Hold_Fast
Member#: 175837
#61 9.5% FP
:bowsinrespect: Thank you, King of weight reduction.
Old 01-26-2012, 04:35 AM   #1321
Rally Snow
Member#: 193614
02 Aspen WRX
need blinker fluid change
This is far outdated and forgive me for not reading every page but, the way to remove sound deadening from your car is with dry ice and a PLASTIC putty knife as metal one will scrape your car a lot. put the dry ice ont you stuff for about ten-fifteen mins and begin scraping. It shouldnt take much longer then 1-2 hours for your whole car. A vacuum or shop vac helps a lot when youre done
Rally Snow is offline   Reply With Quote
Old 01-26-2012, 11:52 AM   #1322
u2_m4r1n3
Member#: 189606
E46 M3
Ti Silver
That or a heat gun. Thats what I did, I already had the heat gun. Same concept, just a lot hotter! Lol.
Old 01-26-2012, 12:10 PM   #1323
Splinter
Member#: 106510
98 Widebody 3.4L
Smooth Safety Blue
Or do it in the winter :P (If you get winter)
Old 01-26-2012, 12:48 PM   #1324
bue car
Member#: 176134
07' Impreza STi wrb
95 L...
drye ice the whole thing, i did it in sections. i put a large amount in a small area, it broke it free in 2 minutes, then i slowly move it while take off whats done.
then heat gun the stubborn white glue over the metal caps.
metal works good, then re-paint nice.
Old 01-26-2012, 12:55 PM   #1325
gtasti
Member#: 152036
2004 Sti
good thing i got the 04 so i didnt have to do all that
Total weight reduction or F/R weight distribution more valuable? soslow General Community 17 12-11-2007 01:40 AM
('93-'01) Weight Reduction Questions subarumantoo Impreza Forum 5 05-01-2001 12:02 PM
Some interesting facts about weight reduction Imprezer WRX Forum Archive 5 02-25-2001 11:33 PM
2.5RS Weight Reduction info and questions. Frank General Forum Archive 21 02-16-2001 01:53 AM
