Welcome to the North American Subaru Impreza Owners Club Thursday January 29, 2015
Old 01-12-2012, 07:17 PM   #1
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 480whp 468wtq
Default Read from ECU with beta version on accident
So Im really new to this and I tried out my tactrix cable today for the first time was only going to read from the ecu. Well after I read from the ecu it worked but ecuflash couldnt read it. So i said ill go inside and check it out after I restart the car and make sure it works. Well it took like 10 seconds for the car to turn over and finally start and then it ran different. I runs fine but its more torque is how ill describe it. So i drove it for like 3 miles to make sure it was good and it was ok but just seemed to be a little more jerky. After going inside i realized i was using the beta version of the ecuflash so i got that fixed. But i was just wondering do you think i did something to the car? Sorry for the long thread just kind worried.
freddy121389 is offline   Reply With Quote
Old 01-13-2012, 05:31 AM   #2
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
After you what, you couldn't what? Did you mean that you did a write, but then could not read?
After a write, the ECU needs a few seconds to 'boot up' before the motor can start. It sounds like you ran into that, but it's no big deal.
9 out of 10 new tuners spend a few seconds thinking they've bricked their ECU after that first flash. Myself included.
Old 01-13-2012, 08:46 AM   #3
freddy121389
Member#: 294644
2011 WRX Agile Auto
DGM 480whp 468wtq
no i read the stock image, then ecuflash couldnt read it. I tried reopening it after i read the stock image to make sure it worked. i think i just reset the ecu
Old 01-13-2012, 06:47 PM   #4
Paidfor
Member#: 267815
Be in awe
dont hate .)
The ecuflash Beta version is the shizzle!!! I can actually read the bottom of the MAF table now lol Its a little improved as far as displaying tables. I didnt notice a whole lot of difference overall.
Old 01-13-2012, 07:26 PM   #5
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
the difference you're feeling is because you reset all of the AF trims and the fine learning knock correction table and the IAM.
The only reason ecuflash wont open a file is if you dont have the proper definition for it.....since you have a 2011 WRX you have to go to romraider and download your definition separately and add it to the rommetadata/subaru/impreza wrx folder manually.
http://www.romraider.com/forum/viewt...hp?f=34&t=6639
Old 01-13-2012, 09:32 PM   #6
TheGremlyn
Member#: 287161
2011 WRX 5dr
The last batch of 2011 WRXs apparently have a slightly different definition file, which is probably why ECUFlash can't read it. Unless you didn't add in the definitions to begin with. Did you get a window that gave three options (something like Cancel, Save anyway, or Create definition)? Same happened to me. I was instructed to just save the file, and there will be an updated definition for the new ECU version soon. All it means is I can't flash back to stock without it.
TheGremlyn is offline   Reply With Quote
ecuflash - stuck at read from ecu black thunder Open Source Reflashes 1 04-22-2010 05:16 PM
Cant Read from ECU Jakkim Engine Management & Tuning 6 03-08-2010 04:42 PM
2003 wrx cant read from ecu matthewhiggins118 Open Source Reflashes 16 05-15-2009 11:08 PM
Voltage readings from ecu? Onederer Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-25-2002 07:12 PM
