Welcome to the North American Subaru Impreza Owners Club Monday June 29, 2015
Old 01-14-2012, 09:41 PM   #1
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Default Prosport Gauges | 2008+ Dash Install
Hey Forum,
Today I tackled a nice mod to the interior. I ordered three Prosport gauges. One Boost, One Oil Pressure, and One Oil Temp in 60mm Amber.
If you are interested in more installs, check out my build thread!
The install was pretty straight forward. The trickiest part was the rear galley under the intercooler. The plug was nice and tight and in the worst location.
I used the stock oil pressure sender location to put a galley plug and new Prosport electronic pressure gauge. For the oil temp, I used the rear plug to put the second galley plug and sender. I also used the stock boost solenoid location to mount the electronic Prosport sender and tapped the "T" into the stock tubing.
Here are the pictures, if you have any questions please ask them in this thread. It'll help others in the future if they happen to have the same question.
Here's the NEW finished Picture
Start with removing the alternator...
Once you get the Alternator out the stock pressure sender is here. If you can't figure out how to take an alternator out, you probably shouldn't be doing this install...
Once you get the stock sensor and plug out, you can put in your new galley plug and sender. It should look like this.
Once you take the intercooler off, search under the intake manifold until you find a plug the size of a quarter with a 3/16 allen head in it. I used two extensions and got it out very easily...
Here is the oil temp sender with the galley plug installed. If you use a 17mm crowfoot it'll make your life so much better.
The new maze of boost lines...
Where to go through the firewall. Using a coat hanger, once you go through the padding make a hard right down towards the gas pedal, I was able to get it pretty easily. I made a 1/4" hole in the grommet and made it as factory as possible.
I removed the:
Radio
Instrument Cluster hood
Instrument Cluster
Clock
Dash Vent
Once removed I sent the gauge wires through the location where the clock was.
Since the daisy-chain together, I only had to wire one gauge. I grabbed Power, Ignition and ground from the radio harness below. You can also get the parking light wire there too if you need it for your gauges.
Once wired, I mounted the three gauges in the ATI center dash pod. If you would like to see how it was covered in Alcantara take a look (HERE)
I also did a relocation of the clock down to the lower dash pocket. I have added note on how to do this throughout the thread so please read through first.
Enjoy!!
Old 01-15-2012, 09:27 AM   #2
slimfit
Member#: 90597
2011 WRX Premium
CLEAN!! Wish this was around when I did my install. Can get a better pic of how you mounted the gauges?
slimfit is offline   Reply With Quote
Old 01-15-2012, 09:39 AM   #3
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Thanks for the kind words!
I have this picture here... I used the brackets that came with the gauges and the 3M double sided tape.
PLEASE remember that I did this because I am waiting for the new ATI center dash pod to come out... It should be soon but I was getting tired of waiting.
I finally got the ATI pod in so the mounting is different then when I just used the brackets they came with. The new pod is below.
Old 01-15-2012, 06:00 PM   #4
Psyk
Member#: 92203
2012 SWP WRX Hatch
RIP 05 WRX
Looks great, and awesome pics!
Psyk is offline   Reply With Quote
Old 01-15-2012, 06:06 PM   #5
yeos
Member#: 133855
2009 STi SparkSilver
Dom Tuned @ MPS
Those new prosport gauges look awesome! How accurate does the boost gauge read?
yeos is offline   Reply With Quote
Old 01-15-2012, 06:43 PM   #6
moonrider_99
Member#: 258628
2009 WRX stg2-SOLD
2012 MS3
I've seen first reports pertaining the ati pod two years ago and its still not available. I would forget about it, lol. I also don't trust a company that takes two years to come up with a mold and make it in large quantity.
Love your setup btw
moonrider_99 is offline   Reply With Quote
Old 01-15-2012, 06:58 PM   #7
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
So far peak for peak it's dead on with the Access Port. Under full boost for an extended period of time read 17.9psi on the AP and 17.5 on the gauge. I think it's pretty good, I'm happy with that plus I never used a Defi or anything so I really don't have anything to compare it too.
Thanks for checking it out!!
Old 01-15-2012, 07:00 PM   #8
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Love your setup btw
Time to break out the foam block, carving tools and fiberglass. It's custom pod time!!
It's something I want to make anyway but I will give it 2 more months to see if it finally comes out.
Old 01-16-2012, 10:38 AM   #9
Alternet
Member#: 290172
2015 WRX
WR Pearl
Also, I am assuming that's the limited WRX? I noticed the hand break and the shifter both has red stitching :O. My premium doesn't have that
I'll admit though that it is nice looking
Well done sir.
Alternet is offline   Reply With Quote
Old 01-16-2012, 11:39 AM   #10
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Well done sir.
I've relocated the clock/temp/airbag/seat warning thingy down in the lower pocket under the heater controls.
Here is a closeup of the move to the console.
Also, the shift boot and e-brake boots are from JPM Coachworks... I got the same pleather boots from the factory as you
Old 01-16-2012, 02:12 PM   #11
Akrexak
Member#: 100607
2015 DGM STI-His
'14 FXT Touring-Hers
, I was about to say you can't see how your gas milage is. I would keep mine off like your picture.
Akrexak is offline   Reply With Quote
Old 01-16-2012, 04:54 PM   #12
xluben
Member#: 261612
2002 WRX Sedan
9.9s @ 140mph
Very clean install and great photos.
Old 01-18-2012, 11:06 AM   #13
JPM Coachworks
Member#: 190108
2008 WRX STI
LR
Love your setup btw
We had the pleasure of working with one of their prototype pieces in late September for the RallySport Direct SEMA STI. They're close to a release, as I understand it. The part that we had in our hands was apparently an early prototype and there have been changes since. All in all, it will be a great addition and solution to those of us waiting on a dash mounted gauge cluster.
Best Regards,
Alex
JPM Coachworks is offline   Reply With Quote
Old 01-18-2012, 11:11 AM   #14
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
I can hardly contain myself when I see this picture, I can't take it!!!
Alex, you are a devil in disguise... I want it so bad especially so I can get my dash wrapped
Old 02-06-2012, 11:06 PM   #15
thaduke2003
Member#: 55038
2011 Impreza WRX 5dr
Dary Gray
Pardon me for being dumb on this, but where underhood is that boost gauge plumbed? Doing mine Wednesday! Thanks- Mark W.
thaduke2003 is offline   Reply With Quote
Old 02-28-2012, 11:56 AM   #16
A Fatal Ode
Member#: 243616
2010 WRX 336/384
2006 STI 550/475
sweet! thanks
A Fatal Ode is offline   Reply With Quote
Old 02-29-2012, 11:58 AM   #17
Speedster329
Member#: 214652
2004 STI !
JBP !
wow good work it all looks great
Speedster329 is offline   Reply With Quote
Old 03-06-2012, 06:06 PM   #18
philiec
Member#: 290147
Does your dimmer switch work on these gauges? I am planning to install my prosport boost and a/f gauges with the smy cluster, and kind of clueless on which wires to tap into.
philiec is offline   Reply With Quote
Old 03-06-2012, 06:42 PM   #19
spec.B - autox
Member#: 209699
2009 STI
Alex, I WANT your interior!!! Holy ISH that's clean!
spec.B - autox is offline   Reply With Quote
Old 03-06-2012, 07:43 PM   #20
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Hey Phil,
Unfortunately the ProSport gauges don't dim. The lights are either on or off. For the wiring there are a couple different choices depending on what color you want them to be and when. Since I only wanted mine to be red with a white dial all the time the wiring was easy. All you have to do is put black to ground, red and orange to ignition.
If you want to have the gauges switch from white in the day to red in the night, then you have to add in the white wire to the parking light switch.
All 4 wires are located in the radio harness if you are going to be near there otherwise the fuse box will have them also, you'll just need a clean way to top into it.
Let me know if you need any help further!
- Jason
Old 03-09-2012, 06:01 PM   #21
BigRob74
Member#: 305107
2012 wrx
360/386 E85
hey jason, putting the boost gauge in tomorrow. i am glad i dug this back up. i didnt know the gauge doesnt dim, but thats ok i guess. so yours is lit all the time? not a bad thing being the stock gauges are always on. do you have any better pics of where you went thru the firewall? its just the one set of wires from the boost sender right? and then the other set i plan to wire to the fuses, as i am mounting this on the steering column..
BigRob74 is online now   Reply With Quote
Old 03-09-2012, 06:20 PM   #22
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
Hey Rob,
Yeah it's a bummer that they don't dim but I have never thought I needed to. I have my brightness set at one click from the brightest setting for the OEM gauges. With that setting, the Prosport's match very well. During the day they are bright enough to see and at night they blend perfect with the dash still...
As far as the firewall, I still think that going through the drivers side wheel well is the easiest spot to go. The spot I used is easy to get to but almost impossible to get through. About a half inch behind that grommet I used is the heater box, so if you are to go through you have to make a sharp right turn down towards the gas pedal. The other kicker is that in between the back side of the grommet and the heater box is sound deadening material.
If you want to try that way it could be easy if you get a coat hanger through easily. After 10 minutes of struggling I would take the wheel well off and go through the grommet under there. That way you will have a straight shot to the under dash and fuse box for wiring.
With just the boost gauge, yes you will only have one small wire to go through the firewall. The rest of the wiring to the fuse .box will come from the back of the gauge
Here is another view of the hole before I went through with the group of wires.
Old 03-09-2012, 06:27 PM   #23
BigRob74
Member#: 305107
2012 wrx
360/386 E85
thanks man, thats just what i was looking for!
Old 03-09-2012, 07:47 PM   #24
dannyngnX
Member#: 303207
2012 Wrx
Pearl freakin white
Originally Posted by JPM Coachworks View Post
I WANT!!! That alcantara interior looks like sexyyy..
dannyngnX is offline   Reply With Quote
Old 03-09-2012, 07:57 PM   #25
Overland04
Member#: 293311
2011 Impreza WRX
Leguna Seca Blue
^^^ Hahah, yeah its sweet. I'm slowly working on my own conversion....
Prosport Evo Boost Gauge Wiring Help 2011 Wrx scoobnoob1103 Newbies & FAQs 2 01-02-2012 10:13 AM
WTB : someone to install a 3 gauge dash pod elias0930 NESIC Private Classifieds 4 01-13-2011 10:36 PM
FS/FT: Aftermarket Subaru 3 gauge dash pod [ATI] with Greddy gauges Saabaru25 Interior/Dressup/Audio & Security 18 06-25-2008 10:33 PM
FS/FT: Aftermarket Subaru 3 gauge dash pod [ATI] with Greddy gauges Saabaru25 MWSOC Private Classifieds 13 05-21-2008 11:11 PM
wrx 3 gauge dash SNAFU...a little help please... db97 Service & Maintenance 2 11-19-2001 03:47 PM
