Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 01-16-2012, 05:51 PM   #1
Smurftastic
Member#: 243697
02 | BLOD Founding
Member | TopScoob 031
Default How to: modify an 04/05 WRX scoop to fit and look proper on a Bugeye
Since I started working on this mod, I've received a number of PMs requesting a DIY. Having not planned to make one, there won't be a lot of pictures, just instructions. This is what worked for me, if you find a better solution for any portion of this then please share.
The end result is a scoop that sits approximately .2 inches shorter on the hood than the JDM Sti Bugeye scoop.
Tools:
Painters tape
A dremel
Cutting and sanding dremel bits
Superglue
Process:
1. Cutting the overhang: Choosing two points on each front corner of the scoop, lay down a solid line of painters tape to mark off where you'll be cutting. I took measurements after the tape was down to make sure everything was even. Exactly how far back you put the tape is up to you, but take a look at the Bugeye scoop you already have from the top-down to figure out what might look appropriate.
Take your time cutting. After you cut across, use the cutting bit and sanding bits to clear out the plastic support columns and round out the sides.
2. Rounding out the rear end: Mirroring the back end of the Bugeye scoop with the 04/05 WRX scoop will eliminate most of the gap people suffer from when just putting one on. Line up the two scoops and mark off with a sharpie what you need to cut. Once you think the rear end is close, go to some test fits on the car to see what else you'll need to cut.
3. Modifying the support:
Front: I discovered that the only way I could get the front end to sit flush with the hood was by removing everything from the front underside of the scoop. That means all slide-in bolt holders and the extra plastic lip they're attached to.
Based upon how much you remove from the rear of the scoop, you will have to figure out a subtle way to bolt down the front. I ended up drilling a very small hole and using a small black bolt and washer.
Rear: The Bugeye scoop has three slide-in bolt holders in the rear. The Peanut scoop has four. I dremeled off the Peanut bolt holders carefully and re-affixed them with superglue to match the Bugeye scoop. The only issue I Found here is because of the different angle of the rear, the slide in bolts actually won't reach all the way to the holes on the hood. I used one inch-long bolts.
After you complete all this work, it's not a bad idea to sand down and paint over portions of the scoop where you dremeled off columns or bolt holders.
Pictures:
04/05 Scoop with no modifications
Post-modifications:
Smurftastic is offline   Reply With Quote
Old 01-16-2012, 05:56 PM   #2
con10der8
Member#: 165107
thats good work right there......
con10der8 is offline   Reply With Quote
Old 01-16-2012, 05:57 PM   #3
mellott73
Member#: 202233
2005 WRX STi
Platinum Silver Metallic
Nice work! I like it
mellott73 is offline   Reply With Quote
Old 01-17-2012, 10:54 AM   #4
CWLTT
Member#: 239283
02 VF39'd WRX
yarp what con10der8 said...
CWLTT is offline   Reply With Quote
Old 01-17-2012, 11:15 AM   #5
alieus
Member#: 155634
2005 STi
Hey, im very curious on your lip setup. It looks like you have 2 of them. Care to elaborate?
alieus is offline   Reply With Quote
Old 01-17-2012, 11:45 AM   #6
BlackFly
Member#: 29795
2002 WRX/v7 STI 2.0
Blazin Yellow
Judging by his DIY ability I would guess that the black lower lip is the garage door seal DIY.
After a second look maybe not. Here is the DIY link for it though
http://forums.nasioc.com/forums/show...&highlight=DIY
BlackFly is offline   Reply With Quote
Old 01-17-2012, 12:03 PM   #7
ThaGriff
Member#: 306534
Nice write up. Also, thumbs up on the double lip.
ThaGriff is offline   Reply With Quote
Old 01-17-2012, 12:10 PM   #8
bbun
Member#: 184554
02 ghettoFABness
bugeye rolling.
alieus , lip = prodrive + 06/07 vlimited
bbun is offline   Reply With Quote
Old 01-17-2012, 05:11 PM   #9
Smurftastic
Member#: 243697
02 | BLOD Founding
Yes, it is a prodrive replica plus the JNA Bugeye lip (which is a replica of the 06/07 vlimited). I chose to go this route instead of the garage door lip simply because of how the vlimited looks on the sides... lines up... looks correct.
Old 01-17-2012, 06:39 PM   #10
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Scoop looks unfinished. Why bother with this instead of getting the right one?
Old 01-18-2012, 11:16 AM   #11
Daddy_Digital
Member#: 274205
2002 WRX Sport Wagon
ive alway thought 04-05 STI scoops were too big. good write up tho.
Daddy_Digital is offline   Reply With Quote
Old 01-18-2012, 01:09 PM   #12
alieus
Member#: 155634
2005 STi
Looks freaking fantastic! I am going to go the same route now.
Old 01-19-2012, 09:04 PM   #13
NOTanEVO
Member#: 210790
BLANCO
any pics from the side
NOTanEVO is offline   Reply With Quote
Old 01-19-2012, 10:05 PM   #14
Smurftastic
Member#: 243697
02 | BLOD Founding
I do have some side pics and will put them up over the next few days. I am beginning to feel that the scoop is only 90% done. I can make it better. I need to shave some more from the rear end, the front, smooth out, and apply paint to areas where I shaved down.
It can be better, but I've worked on this a lot lately and need some more motivation
To the question of why do this to begin with instead of buy the JDM STi scoop - simply because I received this in a trade and am curious enough just to see if I can get away with it
Old 01-19-2012, 10:31 PM   #15
DSRX2005
Member#: 271681
2013 WRB Subaru WRX
AJW Performance
Looks great, really. I hate seeing those hoodscoops on the bugeye's.
DSRX2005 is offline   Reply With Quote
Old 03-25-2012, 12:58 AM   #16
20blkndyellow02
Member#: 307855
2002 subaru wrx
black and yellow
Nice write up! Do the sides match up though?
20blkndyellow02 is offline   Reply With Quote
Old 03-25-2012, 12:57 PM   #17
arco
Member#: 57156
2007 V.8 207 STi
Mercedes Polar White
nice job. it's a clean fit both in looks and fitment (at least as far as I can tell)
arco is offline   Reply With Quote
Old 03-25-2012, 07:44 PM   #18
Smurftastic
Member#: 243697
02 | BLOD Founding
I actually took the thing off a while ago and haven't finished perfecting it yet. I need to take off about a millimeter in the rear and affix two points in the front substructure so the scoop attaches at all three points in the front instead of one - otherwise it's just not
stable enough at high speeds.
But, I don't really have the motivation right now - I just finished fixing fuel line and valve gasket issues. :\ It's just sitting next to me on the floor if anyone wants to pick it up and run with it.
The good thing is that if I ever get around to finalizing this thing, I have a bunch of WRB paint laying around to paint over parts where I cut
Old 10-08-2012, 12:20 PM   #19
ProJecTxPreLuDe
Member#: 268119
2002 WRX Wagon
ill take it off ur hands slong with the WRB paint lol
ProJecTxPreLuDe is offline   Reply With Quote
Old 10-08-2012, 12:59 PM   #20
Smurftastic
Member#: 243697
02 | BLOD Founding
I sooold it :/
will 04/05 WRX JDM headlights fit on a 2005 USDM STi with HID? dcgear Electrical & Lighting 5 11-29-2011 05:59 PM
Buying an 04/05 WRX Wagon ; What to look for?? jasonsraisins Newbies & FAQs 5 04-28-2010 08:24 PM
Will the 04/05 wrx suspension mods fit on an 06 wrx/tr? QWIKTRBOAWD Brakes, Steering & Suspension 2 09-25-2005 08:06 PM
Will 02/03 WRX struts fit an 04/05 WRX? GADGTGUY Brakes, Steering & Suspension 2 05-06-2005 10:30 AM
