Go Back   NASIOC > NASIOC Classifieds > Vendor 'Group Buy' Classifieds
Closed Thread
Old 01-08-2012, 06:07 PM   #176
bluA32
Member Sales Rating: (18)
Member#: 92038
05 STi
Originally Posted by BlackFighter View Post
Can we see the pics in case others run in the same prob.
This is as far in the metal sleeve would go (wider opening towards control arm). At this point it's already binding so the sleeve is unable to spin.
There's a washer that would go in between but the gap is still quite large from being fully seated (little less than 1/2"). Looks like if the sleeve's inner diameter was slightly larger it'd eliminate the problem though.
bluA32 is offline
Old 01-08-2012, 08:00 PM   #177
MSI
Vendor Sales Rating: (0)
Member#: 95419
I have seen this with a EURO 2002 STI that the pin was different than the USD / JDM cars ... but it was smaller ... the USDM pins are larger than those ones. Is there a burr, or a ding ' knick in the either part?
__________________
MSI is offline
Old 01-08-2012, 10:09 PM   #178
bluA32
Member#: 92038
05 STi
No dings, knicks, or burring on either of the bushing sleeves. I believe most of the aftermarket ALKs have sleeves that open up slightly wider than these do to fit more generically on 02-07 wrx and STI.
The smaller inner diameter where it tapers down to is ~20mm which looks to be the same for all models and is a good fit, but the wide end isn't large enough to slide all the way down the pin.
bluA32 is offline
Old 01-09-2012, 10:20 AM   #179
MSI
Member#: 95419
This is weird. I went and checked 20 pcs at random from our bin, and tried on 6 different pins I have her (no idea what they are from though) and they all worked ... I will check with TIC and someone will be back in touch with you.
__________________
MSI is offline
Old 01-09-2012, 02:42 PM   #180
bluA32
Member#: 92038
05 STi
Can you check what the width of the inner diameter is on the sleeves you guys have and let me know. Thanks. Appreciate you guys looking into this.
bluA32 is offline
Old 01-09-2012, 03:09 PM   #181
Turn in Concepts
Vendor Sales Rating: (159)
Member#: 93646
Many Track Records
Let us help you go fast!
I'm going to pull some sleeves off the shelf and random check them against a car with STi arms here to see what I find.
-Clint
__________________
__________________
Turn in Concepts is offline
Old 01-09-2012, 08:17 PM   #182
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Here's an idea- try putting the sleeves in boiling water and put a layer of oil on the control arm. Maybe that should be enough to get it in?
EtoS is offline
Old 01-09-2012, 09:42 PM   #183
Turn in Concepts
Member#: 93646
Many Track Records
Looking at things now and trying to figure out why you're having this problem. i've taken some measurements of a random sample of tubes and they are all pretty solid on repeatability.
I'm going to measure a pin from an STi arm tomorrow.
Don't lose faith I'll figure out what's going on.
__________________
__________________
Old 01-09-2012, 09:54 PM   #184
bluA32
Member#: 92038
05 STi
I have too many TIC parts to lose faith. I'm sure we'll figure it out, let's talk tomorrow
bluA32 is offline
Old 01-10-2012, 08:12 PM   #185
bluA32
Member#: 92038
05 STi
Hey Clint, how's the testing on the pin for the STi arm?
Update: TIC did find the same issue on an 07 STi control arm so they're working on getting measurements to remachine the sleeves for fitment.
bluA32 is offline
Old 01-14-2012, 01:30 PM   #186
mav1c
Hoodbridge!
Member Sales Rating: (52)
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Just sent payment. Sorry it took so long.No excuse other than I totally forgot about this.
mav1c is offline
Old 01-14-2012, 03:29 PM   #187
pheonix991
Member Sales Rating: (4)
Member#: 154173
2006 STI
So, what's the status of installing these on the STI Aluminum control arms? Are we going to have to send them back?
pheonix991 is offline
Old 01-15-2012, 12:32 AM   #188
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, FOR SALE!!!
Damn 07 STI FCAs...
SubieEngineer is offline
Old 01-16-2012, 11:07 AM   #189
MSI
Member#: 95419
I have installed on 4 different arms this past week without issues .. I don't understand on my end.....
__________________
MSI is offline
Old 01-16-2012, 11:20 AM   #190
subaru3169
Member Sales Rating: (47)
Member#: 55252
* pullup bar *
so.. should i have an issue with these??
usdm oem 2002 wrx arms
subaru3169 is offline
Old 01-16-2012, 11:35 AM   #191
MSI
Member#: 95419
NO out of 150 pcs so far, we have one issue ...
__________________
MSI is offline
Old 01-16-2012, 11:49 AM   #192
Turn in Concepts
Member#: 93646
Many Track Records
WRX arms seem to be just fine.
the STi arms we know of and have installed here seem to be just fine.
I checked and checked all the arms from cars I have here and they were just fine EXCEPT for one. Now, as for the rhyme or reason as to why that one is having trouble I don't know.
What i will be doing is machining a number of tubes here to account for it so if anybody else runs into the problem I have some here.
__________________
__________________
Old 01-16-2012, 06:24 PM   #193
bluA32
Member#: 92038
05 STi
How soon can we expect them?
bluA32 is offline
Old 01-17-2012, 11:07 AM   #194
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, FOR SALE!!!
Any 07 STI FCAs that you know of with this issue...?
Old 01-17-2012, 11:39 AM   #195
Turn in Concepts
Member#: 93646
Many Track Records
I do not know if this is a difference with all 07's or even what the pattern is. There's this one case in the wild I know of, and then there's the one here that I literally had to go through all the cars we have in the shop here to find.
__________________
__________________
Old 01-17-2012, 05:53 PM   #196
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, FOR SALE!!!
Gotcha, thanks! Suppose I'll find out when I finally get around to installing them.
Old 01-17-2012, 09:00 PM   #197
Turn in Concepts
Member#: 93646
Many Track Records
I'm going to get a number of the tubes modified just in case this become more common.
__________________
__________________
Old 01-18-2012, 09:00 PM   #198
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, FOR SALE!!!
Gotcha. Was just hoping for a more definite answer before I potentially strand my car in the air. Ah, well, 'tis the nature of the game. I'll find out when I get around to installing these.
Old 01-18-2012, 09:34 PM   #199
Turn in Concepts
Member#: 93646
Many Track Records
REAL easy to check.
Unbolt stock housing, slide back, and measure closest to the forward washer.
IF the pin is .9" stop there, and let me know.
If the pin is smaller you should be good to go.
FWIW, 128 crush tubes went out the door for rework this afternoon.
__________________
__________________
Old 01-20-2012, 08:15 PM   #200
-Nic-
Member Sales Rating: (2)
Member#: 291154
2004 STi
I sent payment today for the DSS + X-Brace. Sorry about the delay, some how the final payment link got marked as spam...
-Nic- is offline
Closed Thread
MSI & TiC Project - Trailing Links (GB coming soon) Big-E Brakes, Steering & Suspension 3 11-17-2010 01:50 PM
MSI & TiC Project - Trailing Links (DOUBLE POST - PLEASE DELETE) Big-E Brakes, Steering & Suspension 0 11-05-2010 04:56 PM
TiC driveline bushing group buy Turn in Concepts Vendor 'Group Buy' Classifieds 45 03-29-2007 06:03 PM
WTB: Tial BOV & FJO wideband - Group Buy? turbo6speed Private 'Wanted' Classifieds 0 05-24-2006 11:44 AM
STI LHD Headlights & Leveling Switch/harness Group Buy $950.00 Shipped xpressmotorworks Vendor 'Group Buy' Classifieds 683 05-05-2006 02:37 AM
