Old 05-20-2011, 01:27 PM   #1
bill hincher
Member#: 280288
Default custom built Sub/Toy bellhousing
a guy in Portland Oregon asked me about and we built a couple just to see how it all worked out
the two series of transmissions that are used are either the Toyota 'W' series trans ( from w 55 to 59 2wheel drive or 4 wheel drive)
OR the 'R' series Toyota transmission ( either the R 150 or the R 151 from the V-6 Toyota truck in either 4wheel drive OR 2wheel drive)
depending on how they are ordered is how they are machined
The R 154 was avoided because the trans is getting harder to find and more expensive, so these two common transmissions were chosen, the R 154 input shaft is 3/4 inch longer and can be used in the R design bellhousing if needed
these are designed to use all the stock Subaru components over with nothing more then adding a stock toyota clutch disc
bill hincher is offline   Reply With Quote
Old 05-20-2011, 01:51 PM   #2
bill hincher
Member#: 280288
Old 05-22-2011, 10:07 PM   #3
Storm
Member#: 5218
96L Most Over-
Developed Beater
That is a work of art!
If I decide to forgo the AWD system in the racecar, I will be knocking on your door to beg for one of these bellhousings (can I make it work with a falcon 2 speed circletrack box?)
Thanks for thinking outside the box and making a part that doesn't require a hackjob of the original drivetrain to achive desired results!!!
Jay Storm
Old 05-24-2011, 08:16 AM   #4
SiFlyBy
Member#: 250910
That is some pretty awesome work. I never caught the original intention of the project though. Was it for a 4 wheeling rig or because the toyota trans is beefier in some way? What is the application?
SiFlyBy is offline   Reply With Quote
Old 05-24-2011, 09:00 AM   #5
bill hincher
Member#: 280288
the original intent was to create a true 2wheel drive system, that blossomed into the most versitle system available, so the Toyota was chosen because it included the 4wd option and increased the vehicle ride hieght with a front drive shaft, then the second option of the 'R' series was added to accomidate an even stronger transmission
why do you ask? two dawgs?
Old 05-24-2011, 10:26 AM   #6
SiFlyBy
Member#: 250910
I was just curious. It looks like a TON of work and it looks very well done. I did not know there was a market for such things.
Old 05-24-2011, 04:29 PM   #7
bill hincher
Member#: 280288
can you imagine the rock crawler guys setting the engine back and low in a suzuki samari and using the Toyota 4wd system?
kwooooooooool
I dont know if there is any market, I just did to find out how its done
Old 05-24-2011, 07:09 PM   #8
olsen726
Member#: 154175
07 Impreza Wagon
2.5i???
I'm still interested in this for my corolla. But first I need to finish up a few loose ends on my subaru. And get a little bit of money in the bank
olsen726 is offline   Reply With Quote
Old 05-24-2011, 09:19 PM   #9
bill hincher
Member#: 280288
I ordered 10 at the casting shop last week , I should have the raw castings on hand after that
these are built from T356 aluminum and then treated to a T 5 hardness, by the way
thats aircraft standards
Old 05-27-2011, 06:32 AM   #10
bill hincher
Member#: 280288
this is the casting shop where I have the patterns casted
they build core boxes from sand and resien and then pour the aluminum
then they are treated in a beader/ furnace to build in the hardness
there is the first batch
then I machine out all the raw castings
Old 05-27-2011, 09:46 AM   #11
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
Wow nice I work, at a foundry and know the process but with ductile and grey iron mostly,hard process,also got a question some one told me once ,when you pour the aluminum and its full, if you just bump the mold when the aluminum still liquid it scrap right?Also just wondered if you can remake the 04sti bellhousing if your cheaper than oem I think there would some interest here but seem to be more machining,heck your pretty local I could drive up there and visit sometime with your permission.Whats the buisness name?Pm if so.Later man.
EROCS04SBRUSTI is offline   Reply With Quote
Old 05-27-2011, 11:15 AM   #12
bill hincher
Member#: 280288
yeah man, just give me a heads up and come on bye
Old 05-30-2011, 01:53 AM   #13
PARANOID56
Member#: 22035
2003 Brocoma DCab
71 FJ40, 13 DRZ400SM
man that would work great in my fj40 lol
PARANOID56 is offline   Reply With Quote
Old 05-30-2011, 11:35 PM   #14
EROCS04SBRUSTI
Member#: 234397
2004 WRX STI WRB
15 DGM FXT
This weekend if no work saturday or next!!pm your #/buisness name definitely like to see the process.need any housings??got r154 supra housings and a broken 04 sti housing.
Old 06-01-2011, 09:39 AM   #15
bill hincher
Member#: 280288
you are PM'd >;o)
Old 06-02-2011, 10:33 PM   #16
bill hincher
Member#: 280288
Old 06-03-2011, 12:16 AM   #17
pheonix991
Member#: 154173
2006 STI
Let me get this straight... You're building this so we can stick a suby engine in a toyota... BRILLIANT!
pheonix991 is offline   Reply With Quote
Old 06-03-2011, 08:25 AM   #18
bill hincher
Member#: 280288
well, kinda, its really a matter of flexability, it offers a way to use a strictly RWD conversion but at the same time the ability to mate an excellent low speed high torque engine with a low C/G to a very popular 4WD arriangement, depending on which transmission you choose to use
the only limits is your own imagination
I think the original design was for an Rx7 Mazda with a sub engine
Old 01-21-2012, 08:01 PM   #19
02wrxx
Member#: 307613
Default toyota bellhousing
hi i was wondering how much you charge for a bellhousing? i em very very interested in one please call or text me at 801-928-3646
02wrxx is offline   Reply With Quote
Old 01-31-2012, 01:00 PM   #20
bill hincher
Member#: 280288
sorry for the late reply, I have been focused on the V6 Mitsubishi RWD conversion with a reverse starter
I suppose I could built the r 154 bellhousing but its time consuming and I have about 4 more projects before I got to it
Old 01-31-2012, 08:18 PM   #21
Storm
Member#: 5218
96L Most Over-
Developed Beater
You sir, have my uttermost respect for fabrication skills. So, I must ask if you can make an adapter to mate a Hyundai 1.6 to a Mazda RX7 trans. (for a shopmate)
Jay
Old 02-01-2012, 08:57 AM   #22
bill hincher
Member#: 280288
as far as I know the Mazda doesnt have a detachable bellhousing
I have about a 1 year waiting list on all the adapters I build
Old 02-05-2012, 11:40 AM   #23
Sinister redlines
Member#: 120641
05 HTA3586,BB 2.5L
What is the cost of the bellhousing and such for the subie to yota 4x4 conversion?
Sinister redlines is offline   Reply With Quote
Old 02-10-2012, 08:33 PM   #24
Pacobeagle
Member#: 8775
2010 "Zed" 1000
Orange/White
My only question so far is shifter placement inside the car. I'm really considering doing a RWD swap for my Saabaru. I think this and an R180 would be sweet. My good friend just finished installing a W58 in his Hachi with a 1UZFE!!!
Pacobeagle is offline   Reply With Quote
Old 02-11-2012, 12:44 AM   #25
mellow65
Member#: 83350
Too Many
As I was the "some guy from Portland" I thought I would chime in here.
To start bill does beautiful work. It all bolts together as if it was meant to with no issues to speak of.
Also bill was right, I wanted this so I could cram it all in a first gen rx7.
As they say the proof is in the pictures.
It also runs quite nicely too.
Bill has been working on a remote cable style shifter to fit the w58s. But the man gets busy. I ended up making my own remote shifter, it's ghetto looking but works quite nicely.
There is someone on legacy central that has already swapped one into a Lego turbo and is working on his own version of remote shifter.
http://bbs.legacycentral.org/viewtop...44664&start=75
mellow65 is offline   Reply With Quote
FS IA- custom built sub w/kenwood amp sjd03pmswrx Interior/Dressup/Audio & Security 1 01-28-2007 03:34 AM
Custom built sub/speaker box for sale or trade wrex04 Interior/Dressup/Audio & Security 18 09-28-2006 08:27 AM
custom fiberglass sub box with sub (stealth install) PARANOID56 Private 'For Sale' Classifieds 8 04-13-2006 11:02 AM
Custom Fiberglass Sub Enclosure + Sub DLUX WRX Private 'For Sale' Classifieds 7 03-26-2006 07:02 PM
FS: custom Impreza sub box, 2-8" subs and Kenwood Amp Thug New England Impreza Club Forum -- NESIC 10 07-05-2000 08:10 PM
