#51 |
Member#: 291214
RMIC
Vehicle:2011 STI Sedan PBP |
#52 |
Member#: 190003
AKIC
Vehicle:2000 RSTi BW8375 Blue |
Also still curious about those super pistons
#53 |
Member#: 236017
South East
Vehicle:2005 OBP WRX Sedan 2.35L w/ GTX3071 |
And the results are....?
#54 | |
Member#: 26933
BAIC
Vehicle:2006 STI CGM |
-- Ed |
#55 |
Member#: 107179
Vehicle:2003 WRX, S400SX FMW MBP |
#56 |
Member#: 82398
Vehicle:2013 SXL 555 Motorsports |
The point would be, why have a powerband that starts at 6000rpm and goes to 9000 rpm when you can have a powerband with more tq that comes in sooner (say 5000rpm) and revs out to 8000-8500 rpm or even higher with a properly build 2.5
you would be achieving the same powerband without, with more tq and essentially faster response by not needing to be as high up in the RPM range to make power |
#57 |
Member#: 212509
Vehicle:unde your hood makin your **** go faster |
huge cams giant turbo and he doesnt even have avcs working. Id say not bad spool for that case. esp when that engine is gonna rev past 9k.
#58 | |
Member#: 212509
so more like 4500 with avcs and going to 9k equals a 4500 rpm powerband. show me a 2.5 with a solid 4.5k rpm powerband |
#59 |
Member#: 291214
RMIC
One of the benefits for the LR engines is the ability to rev and carry the gear longer....So basically any highway pull the LR engine is going to be much faster due to the mechanical advantage and the VE of the motor itself....As long as the heads and intake are massaged to be in the same rpm range....I believe Micah with 3MI racing is working on such an intake and both Micah 3MI and Dom with MPS have heads that will work in a 9000rpm engine....I am not sure of any other builder working towards this type of engine....
If you look at the small cubic inch engines that are trying to compete in the 60-130mph times it takes HIGH rpms and HIGH horsepower in order to run good times....(the captain obvious statement) When I build my block it is going to be an 11 to 1 LR 2.35 or 2.43 engine in hopes of spinning to 8500-9000 with two turbo selections.....A quick response turbo of a 35r and a high horsepower turbo of a 42r or so.....Granted the motor will only run on E85.... The bottom line is this....It is an individual choice in engine set up..... I don't think many builders are going to recommend this style of motor (LR) for someone looking for under 500whp or serious daily driving... The LR engines are going to shine in drag racing, mile racing, and road racing applications. I think the LR motor and a 35/37R would be an absolutely fantastic daily driver.... Last edited by jdpsearcher; 01-23-2012 at 09:43 PM. |
#60 |
Member#: 129231
Vehicle:2005 wrx cgm |
I love my long rod motor so far. Full boost by 4000 on a turbonetics gtk500, 280 cams with headwork. Great for drivability. I have not been able to wind out any gears higher than third yet on my 07 sti tranny.
#61 |
Member#: 291214
RMIC
What kind of power are you making....I bet that thing really pulls with the 07 gears....
#62 |
Member#: 129231
I have not even finished tuning it yet. I just switched to e85, and speed density.
#63 |
Member#: 291214
RMIC
No worries I was just curious.....
#64 | |
Member#: 26933
BAIC
Maybe I'm missing something though. -- Ed |
#65 |
Member#: 102238
Vehicle:08 DGM STi *RIP* 06 WRX TR |
It's not suppose to end at 7500rpm. It's suppose to keep going upto 9k rpm. From the mods for the 2.34, the powerband was shifted all the way to the right and then you are comparing it to a motor with the powerband not shifted to the right as much. You can even see the 2.5 starting to run out of breath by 7k rpm while the 2.34 looks like it wants to keep going.
I have been in Doms 07 STi with his 2.34l motor with practically nothing done to the heads. It's a seriously smooth motor that while it doesn't have massive power before 4k rpm, it has pep in that range. It just WANTS to rev. Aside from the poor gas milage it gets, it makes for a fantastic DD IMO. |
#66 | |
Member#: 26933
BAIC
-- Ed |
#67 |
Member#: 163648
Vehicle:2002 Wrx,2.5L,HTA86 E85,2007 6mt,No traction |
At 9000rpm in 4th w/2007 6mt and 26" tires how fast do you think I'll be going?
#68 | |
Member#: 37078
Vehicle:94 L Blue-ish |
#69 | |
Member#: 108089
Vehicle:2003 WRX NF Performance |
#70 | |
Member#: 25952
Vehicle:1995 Impreza Coupe w/ "Extras" :-) |
The 2.34 has larger lift cams, a bigger exhaust housing (0.95 vs 0.85), and adjustable exhaust cam gears. I did this engine because I wanted to try something new. It didn't cost me any extra to go this route than it would have cost me to go with a 2.5L setup. I do know of one local 2.5L engine that runs to 9k routinely at the drag strip, and he's been using the same engine for 2 seasons now I believe without any issues. He runs low to mid 9's pretty consistently with an almost identical setup to mine. Back in November I had the chance to get the car back on the dyno. I changed the ID1000's out for a set of ID2000's and E85. I made some adjustments to the exhaust cam timing. I spooled 700 rpms earlier and gained 20-30wheel hp and 20-50 ft lbs of tq at the same 7500 rpm redline (As welll as over the entire rev range) and the same boost. Hopefully on Feb 4th I will have it back on the dyno and run some real boost through it. ![]() Here's the video from the very first time with a 2.5L... The car spun a rod bearing on the dyno about 15 minutes after this which is the whole reason I had to build an entirely new engine. Last edited by wrx_driver_2002; 01-23-2012 at 11:58 PM. |
#71 | |
Member#: 291214
RMIC
I think it is just personal preference....The motor being better persay is upto the individual buying the motor....The 2.34 and 2.43L destroked LR motors have better volumetric effiency than the 2.5L.... It is really a moot point though....The bottom end is reliability....the power is in the breathing.... (Rant off topic) When is a company going to come out with a head/cam combo including upgrade/larger throttle body and a better intake manifold..... |
#72 |
Member#: 212509
I dont want people to think that all we build at MPS in destroked wonders (LOL). Every engine we build is custom tailored to that specific customers needs with their vehicle. We still build plenty of 2.5s, big bore 2.6s and big bore 2.34=2.5.
Driving both of them on a regular basis I must say I like the destroked engine. Its a whole lot smoother power and more controllable over the larger stroke 2.5. Some like torque down low and that large stroke engine. No problem with that. Plus the shorter stroke has better wear because of less sideloading. Thus maybe making it last longer in the long run. Ill never put one in my Forester with a spec B 6sp though, that will stay 2.5. |
#73 |
Member#: 291214
RMIC
Has anyone decided to spec a specific gear set for the long rod motors to really take advantage of their powerband....
#74 |
Member#: 129231
#75 | |||||
Member#: 200987
Turn up the boost and see the peaks in the tq curve come out even more. Quote:
To Ed, Put simply, a lot of guys don't understand the intricacies of the destroked setups (where large companies did EJ25 development) and probably why there have been so many shops trying to knock off what Dom and I came up with but without the engineering to make it work. There is a reason I literally spent a year doing the original engineering work on the engine before the first prototype was made. Since then, Dom and I still share experiences and ideas and further develop the package. Dom didn't step out with his publicly until early 09 IIRC. Mine are still largely behind closed doors...just a hint, there are some new puzzle pieces over 10k ![]() My largest gripe with the knock offs, other than trying to steal IP ( ), is that they suck at it and make the engine look bad when really it is just them and their research that sucks. ![]() -Micah 'Homemade WRX' |
| Thread Tools | |
| Display Modes | |
| Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band | Maxwell Power | Proven Power Bragging | 563 | 05-16-2012 08:28 PM |
| FS : Built sleeved 2.5 block and built 2.0 heads + more | sleepysubie | Engine/Power/Exhaust | 7 | 06-30-2011 12:50 PM |
| Maxwell Power Tuned, 2.6L Crawford HTA-GT3582R, 587 AWHP | leonbmx | Proven Power Bragging | 72 | 10-31-2010 09:16 PM |
| Maxwell Power Tuned, 2.5L Twinscroll T4 S300sx 574WHP | alcoolaid | Proven Power Bragging | 61 | 10-22-2010 08:49 PM |
| What were the results from the Tacoma show? | Subarutex | North West Impreza Club Forum -- NWIC | 6 | 09-02-2003 01:58 PM |
