Old 12-03-2011, 09:36 PM   #51
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
Agreed....Any results yet....
jdpsearcher is offline   Reply With Quote
Old 01-22-2012, 01:10 PM   #52
AKSubieDubie
Member#: 190003
2007 STI EFR 8374
Also still curious about those super pistons
AKSubieDubie is offline   Reply With Quote
Old 01-23-2012, 04:52 PM   #53
SubaruWrxNewb
Member#: 236017
And the results are....?
SubaruWrxNewb is offline   Reply With Quote
Old 01-23-2012, 08:51 PM   #54
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Originally Posted by wrx_driver_2002 View Post
GT4094 0.95 T4 Exhaust Housing with:
Stock ECU running Speed Density
2mm Longer Rods
Kelford R-199-C AVCS cams (272/272 with 11.5mm Lift intake and 11.2 Exh)
Benson Sleeved Case
Manley Billet 75mm Crank
JE Pistons 99.5mm
Chapman Racing CNC Ported Cylinder Heads
1mm oversized stainless intake and inconel exhaust valves
Full Race Header and Uppipe
Cosworth Intake Manifold
BC Adjustable exhaust cam gears
AVCS Intake gears (Not running any avcs currently due to wrong neutral sw)
Comparison Graph between the spool of a 2.5 and a 2.34 with a GT4094 wth a 0.95exh housing:
The Graph that runs to 7,000 rpms is a 2.5L with custom kelford cams (276 Intake 272 Exh)
Aem Series 1 EMS
2mm Longer Rods
Benson Sleeved Case
JE Pistons 99.5mm
Graph that runs to 7500 rpms is the same graph that's posted by itself above 2.34 with R-199-C Cams (272 Int and Exh 11.5mm lift intake and 11.2 exh)
Can anyone explain the benefit of the 2.34l in this comparison? It seems that the 2.5 is a clear winner here.
-- Ed
Old 01-23-2012, 08:56 PM   #55
RexFTW
Member#: 107179
S4, WRX
1.27 60', 9.37 1/4
-- Ed
I bet the 2.34 lays the smackdown on it when the car is dyno'd to 9-9.5 though.
RexFTW is offline   Reply With Quote
Old 01-23-2012, 09:02 PM   #56
mxturboracer86
Member#: 82398
2008 STi
555 Motorsports
The point would be, why have a powerband that starts at 6000rpm and goes to 9000 rpm when you can have a powerband with more tq that comes in sooner (say 5000rpm) and revs out to 8000-8500 rpm or even higher with a properly build 2.5
you would be achieving the same powerband without, with more tq and essentially faster response by not needing to be as high up in the RPM range to make power
mxturboracer86 is offline   Reply With Quote
Old 01-23-2012, 09:16 PM   #57
NW2TONE
Member#: 212509
unde your hood makin
your **** go faster
-- Ed
huge cams giant turbo and he doesnt even have avcs working. Id say not bad spool for that case. esp when that engine is gonna rev past 9k.
NW2TONE is offline   Reply With Quote
Old 01-23-2012, 09:21 PM   #58
NW2TONE
Member#: 212509
your **** go faster
that 40r is getting spool at 5300 without avcs working. thats good even for a 2.5
so more like 4500 with avcs and going to 9k equals a 4500 rpm powerband. show me a 2.5 with a solid 4.5k rpm powerband
Old 01-23-2012, 09:29 PM   #59
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
One of the benefits for the LR engines is the ability to rev and carry the gear longer....So basically any highway pull the LR engine is going to be much faster due to the mechanical advantage and the VE of the motor itself....As long as the heads and intake are massaged to be in the same rpm range....I believe Micah with 3MI racing is working on such an intake and both Micah 3MI and Dom with MPS have heads that will work in a 9000rpm engine....I am not sure of any other builder working towards this type of engine....
If you look at the small cubic inch engines that are trying to compete in the 60-130mph times it takes HIGH rpms and HIGH horsepower in order to run good times....(the captain obvious statement)
When I build my block it is going to be an 11 to 1 LR 2.35 or 2.43 engine in hopes of spinning to 8500-9000 with two turbo selections.....A quick response turbo of a 35r and a high horsepower turbo of a 42r or so.....Granted the motor will only run on E85....
The bottom line is this....It is an individual choice in engine set up.....
I don't think many builders are going to recommend this style of motor (LR) for someone looking for under 500whp or serious daily driving...
The LR engines are going to shine in drag racing, mile racing, and road racing applications. I think the LR motor and a 35/37R would be an absolutely fantastic daily driver....
Old 01-23-2012, 09:39 PM   #60
MrSlowbaru
Member#: 129231
2005 wrx
cgm
I love my long rod motor so far. Full boost by 4000 on a turbonetics gtk500, 280 cams with headwork. Great for drivability. I have not been able to wind out any gears higher than third yet on my 07 sti tranny.
MrSlowbaru is offline   Reply With Quote
Old 01-23-2012, 09:45 PM   #61
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
What kind of power are you making....I bet that thing really pulls with the 07 gears....
Old 01-23-2012, 10:04 PM   #62
MrSlowbaru
Member#: 129231
2005 wrx
cgm
I have not even finished tuning it yet. I just switched to e85, and speed density.
Old 01-23-2012, 10:06 PM   #63
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
No worries I was just curious.....
Old 01-23-2012, 10:09 PM   #64
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
This is exactly my view on the matter. The ONLY viable benefit I see from having to rev that high is to extend the gear range. Aside from that the larger displacement and less over square engine wins in every other category.
Maybe I'm missing something though.
-- Ed
Old 01-23-2012, 10:19 PM   #65
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
It's not suppose to end at 7500rpm. It's suppose to keep going upto 9k rpm. From the mods for the 2.34, the powerband was shifted all the way to the right and then you are comparing it to a motor with the powerband not shifted to the right as much. You can even see the 2.5 starting to run out of breath by 7k rpm while the 2.34 looks like it wants to keep going.
I have been in Doms 07 STi with his 2.34l motor with practically nothing done to the heads. It's a seriously smooth motor that while it doesn't have massive power before 4k rpm, it has pep in that range. It just WANTS to rev. Aside from the poor gas milage it gets, it makes for a fantastic DD IMO.
EtoS is offline   Reply With Quote
Old 01-23-2012, 10:27 PM   #66
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
That 2.5l setup could easily go to 8k+ RPM as well. Also notice its running less boost than the 2.34 and seems to be running out of fuel up top. I just don't understand why people think the 2.5's can't rev out. They're already fairly short stroke engines so piston speeds are not a big issue.
-- Ed
Old 01-23-2012, 10:42 PM   #67
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
At 9000rpm in 4th w/2007 6mt and 26" tires how fast do you think I'll be going?
Old 01-23-2012, 10:48 PM   #68
Big_DeWeY
Member#: 37078
95 L
Blue-ish
-- Ed
I think the purpose of the 2.34 is rod ratio more than anything. That's something I think we can all agree that the Subaru engines lack.
Big_DeWeY is offline   Reply With Quote
Old 01-23-2012, 10:59 PM   #69
Nuke209
Member#: 108089
2003 WRX
NF Performance
-- Ed
Thank you
Nuke209 is offline   Reply With Quote
Old 01-23-2012, 11:18 PM   #70
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
-- Ed
That first 2.34 Dyno graph was my break in tune. The engine essentially had about an hour of run time on it at this point, which is why It was only ran to 7500 rpms. It was utilizing the stock ECU and Speed Density via cobb AP. (This was done back in early august). However, the two graphs are not necessarily apples to apples comparison. I changed a number of things between the two engines.
The 2.34 has larger lift cams, a bigger exhaust housing (0.95 vs 0.85), and adjustable exhaust cam gears.
I did this engine because I wanted to try something new. It didn't cost me any extra to go this route than it would have cost me to go with a 2.5L setup. I do know of one local 2.5L engine that runs to 9k routinely at the drag strip, and he's been using the same engine for 2 seasons now I believe without any issues. He runs low to mid 9's pretty consistently with an almost identical setup to mine.
Back in November I had the chance to get the car back on the dyno. I changed the ID1000's out for a set of ID2000's and E85. I made some adjustments to the exhaust cam timing. I spooled 700 rpms earlier and gained 20-30wheel hp and 20-50 ft lbs of tq at the same 7500 rpm redline (As welll as over the entire rev range) and the same boost.
Hopefully on Feb 4th I will have it back on the dyno and run some real boost through it.
Here's the video from the very first time with a 2.5L... The car spun a rod bearing on the dyno about 15 minutes after this which is the whole reason I had to build an entirely new engine.
wrx_driver_2002 is offline   Reply With Quote
Old 01-24-2012, 12:45 AM   #71
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
-- Ed
Ed,
I think it is just personal preference....The motor being better persay is upto the individual buying the motor....The 2.34 and 2.43L destroked LR motors have better volumetric effiency than the 2.5L....
It is really a moot point though....The bottom end is reliability....the power is in the breathing....
(Rant off topic) When is a company going to come out with a head/cam combo including upgrade/larger throttle body and a better intake manifold.....
Old 01-24-2012, 01:03 AM   #72
NW2TONE
Member#: 212509
your **** go faster
I dont want people to think that all we build at MPS in destroked wonders (LOL). Every engine we build is custom tailored to that specific customers needs with their vehicle. We still build plenty of 2.5s, big bore 2.6s and big bore 2.34=2.5.
Driving both of them on a regular basis I must say I like the destroked engine. Its a whole lot smoother power and more controllable over the larger stroke 2.5. Some like torque down low and that large stroke engine. No problem with that. Plus the shorter stroke has better wear because of less sideloading. Thus maybe making it last longer in the long run.
Ill never put one in my Forester with a spec B 6sp though, that will stay 2.5.
Old 01-24-2012, 01:17 AM   #73
jdpsearcher
Member#: 291214
2011 STI Sedan
PBP
Has anyone decided to spec a specific gear set for the long rod motors to really take advantage of their powerband....
Old 01-24-2012, 11:59 AM   #74
MrSlowbaru
Member#: 129231
2005 wrx
cgm
~150mph
Old 01-24-2012, 06:09 PM   #75
3MI Racing
Member#: 200987
-- Ed
I think everyone already pointed out the vast differences in the setup. Also not that the EJ25 is peaked and the 2.34 is just at that plateau point.
Turn up the boost and see the peaks in the tq curve come out even more.
It was to broaden and flatten the tq curve, yielding better timing in gear and a higher rate of averaged acceleration.
-- Ed
Keep in mind that I originally designed the engine around a 4" bore, so now you have the EJ25 stomping ability of the 2.34 but with only a lack of 32cc. Now keep in mind the long rod bringing up the VE where you actually use your car...at RPM.
-- Ed
Yes, they can but it doesn't mean they're 'happy' and for the same RPM you have more stress on every component in the engine with the destroked engine...oh and your crank has more flex = loss of power
160 mph...just punched it into the spreadsheet.
To Ed,
Put simply, a lot of guys don't understand the intricacies of the destroked setups (where large companies did EJ25 development) and probably why there have been so many shops trying to knock off what Dom and I came up with but without the engineering to make it work. There is a reason I literally spent a year doing the original engineering work on the engine before the first prototype was made. Since then, Dom and I still share experiences and ideas and further develop the package. Dom didn't step out with his publicly until early 09 IIRC. Mine are still largely behind closed doors...just a hint, there are some new puzzle pieces over 10k
My largest gripe with the knock offs, other than trying to steal IP (), is that they suck at it and make the engine look bad when really it is just them and their research that sucks.
-Micah
'Homemade WRX'
3MI Racing is offline   Reply With Quote
Maxwell Power Tuned, 2.35L GT35R 537whp and 9k rpm, 4K rpm power band Maxwell Power Proven Power Bragging 618 05-13-2016 09:44 AM
Maxwell Power Tuned, 2.6L Crawford HTA-GT3582R, 587 AWHP leonbmx Proven Power Bragging 75 08-27-2015 03:59 PM
FS : Built sleeved 2.5 block and built 2.0 heads + more sleepysubie Engine/Power/Exhaust 7 06-30-2011 12:50 PM
Maxwell Power Tuned, 2.5L Twinscroll T4 S300sx 574WHP alcoolaid Proven Power Bragging 61 10-22-2010 08:49 PM
What were the results from the Tacoma show? Subarutex North West Impreza Club Forum -- NWIC 6 09-02-2003 01:58 PM
