#1301 |
Member#: 26493
SWIC
Vehicle:99 Impreza RSTI Silver |
Caddy were you at in vegas? i need some help like this.
#1302 |
Member#: 147972
MAIC
Vehicle:2004 wrx hybrid 18g jbp |
^Cadillac I want your pullies
I just removed my sunvisors, the small front interior lights and the metal pieces behind the oh **** handles. Then I redid the headliner in black to cover up the holes from deleted items, about 50$ in material for the headliner. I'd say a good 5lbs reduction from the roof area. |
#1303 |
Member#: 175837
Tri-State
Vehicle:#61 ESP |
Speaking of Cadillac's pulley's, where the hell did you get those?
#1304 |
Member#: 106510
VIC
Vehicle:98 Widebody 2.2 Smooth Safety Blue |
Judging by the name on the pulley, unorthodox racing
#1305 |
Member#: 95901
SWIC
Vehicle:2004 WRX Wagon White |
Yep, My pulleys are Unorthodox Racing. Red Anodized, Under-driven, All Aluminum. I wrote a review.
Initially I didn't want the under-driven or even the red. UR found they couldnt sell them and had a blow out sale 4 years ago for all under-driven and/or color tinted products. Sold them at like 65% off so they could unload them from the warehouse. |
#1306 |
Member#: 176134
SCIC
Vehicle:07' Impreza STi wrb 95 L... |
you drive with your new bracket? does it slip or stay tight?
#1307 | |
Member#: 304907
#1308 | |
Member#: 175837
Tri-State
Vehicle:#61 ESP |
#1309 | |
Member#: 95901
SWIC
Only had it on a few days. Stays right where I set it.
![]() Here's how I tighten my belt now. When I first did it I actually did it too tight. Virtually no play at all. Backed it off to about 1/4" of play now. |
#1310 |
Member#: 95901
SWIC
I bought a set of Tumble Generator Valves and an intake manifold from a salvage yard. I admit it's nice to have the spare set to work on so I don't feel rushed to get it back on the car and working.
![]() Using JB Weld like a pro on the TGV deletes. ![]() Green Brackets of Death will no longer work with my set up, plus new holes ![]() The backside ![]() They're still rough I wanted to show something mid way through. |
#1311 |
Member#: 152036
E. Canada
Vehicle:2004 Sti PSM |
how much u pay for those from the wreakers
looks like a good idea |
#1312 |
Member#: 190502
International
Vehicle:2005 VF36 WRX |
I cheated and bought one of those one piece spec c manifolds
![]() Yesterday I made a little in-tank anti fuel surge device whcih cost me nothing to make. Petrol weight is 1Litre = 0.711kg so for example if you were running the tank with only 20 Litres in it you are saving around 28.5kg in a wrx with a 60L tank which is very significant! Here it is ![]() I then added a few holes but only on the right hand side because wrx's suffer from fuel surge on long high G right hand turns. What happens is when you make a right hand turn all the fuel goes flying across the fuel tank to the left hand side and if the corner is long enough there won't be enough fuel at the pickup to power out of the corner. This starts happening on certain corners in my car at half a tank of fuel. So by having no holes on the left hand side of the anti surge tank the fuel can not escape in a right hand turn. Right hand side ![]() Front ![]() Left hand side ![]() The fuel pump assembly also has a little pump that bring fuel back over from the left hand side and drops it above the pickup sock. I have extended this so it drops the fuel into my anti surge tank ![]() You can see I have a cable tie wrapped around the fuel pump to hold everything in place when I slide it back into the cars fuel tank ![]() I was able to test it on some long right hand corners near my house and it worked a treat, no sign of fuel surge with bugger all petrol in the tank! This is where my fuel was at during testing this afternoon. ![]() |
#1313 |
Member#: 152036
E. Canada
wow great idea jdwhite
what kinda bottle is that also your pick up location is on the passenger side of the car right maybe I'll do something like this to mine |
#1314 |
Member#: 189606
SCIC
Vehicle:E46 M3 Ti Silver |
Buy a second fuel pump housing assembly and put it on the opposite side... With your home made piece like the other side.
#1315 | |
Member#: 190502
International
I can't take the credit for the idea, my friend did one on his car and it worked really well, I found the details here http://www.rs25.com/forums/f128/t491...cing-help.html My car is RHD, pickup is on the drivers side. |
#1316 |
Member#: 152036
E. Canada
ok thanks for the clearfication of the pick-up wasnt sure if the right hand right drive had it on the left side or not thanks
#1317 |
Member#: 271525
Vehicle:07 STi 424whp/382wtq GT3076 |
#1318 | |
Member#: 175837
Tri-State
Vehicle:#61 ESP |
#1319 | |
Member#: 95901
SWIC
I bought my used parts from a salvage yard I found from Car-Part.com. Don't forget the Dash. Car DASH Part. Currently they have them listed from $95 - $300. I think I waited and bought mine for $70 plus shipping for both TGVs and the Manifold. Just depends on the stock the individual yards have the day you look. Neat thing is once I'm done and swap out I can sell the one that came with the car right here on NASIOC and get my money back. Last edited by 68Cadillac; 01-24-2012 at 01:11 PM. Reason: clarification |
#1320 | |
Member#: 175837
Tri-State
Vehicle:#61 ESP |
#1321 |
Member#: 193614
NWIC
Vehicle:02 Aspen WRX need blinker fluid change |
This is far outdated and forgive me for not reading every page but, the way to remove sound deadening from your car is with dry ice and a PLASTIC putty knife as metal one will scrape your car a lot. put the dry ice ont you stuff for about ten-fifteen mins and begin scraping. It shouldnt take much longer then 1-2 hours for your whole car. A vacuum or shop vac helps a lot when youre done
#1322 | |
Member#: 189606
SCIC
#1323 |
Member#: 106510
VIC
Or do it in the winter :P (If you get winter)
#1324 |
Member#: 176134
SCIC
drye ice the whole thing, i did it in sections. i put a large amount in a small area, it broke it free in 2 minutes, then i slowly move it while take off whats done.
then heat gun the stubborn white glue over the metal caps. metal works good, then re-paint nice. |
#1325 |
Member#: 152036
E. Canada
good thing i got the 04 so i didnt have to do all that
| Thread Tools | |
| Display Modes | |
| Total weight reduction or F/R weight distribution more valuable? | soslow | General Community | 17 | 12-11-2007 12:40 AM |
| ('93-'01) Weight Reduction Questions | subarumantoo | Impreza Forum | 5 | 05-01-2001 11:02 AM |
| Some interesting facts about weight reduction | Imprezer | WRX Forum Archive | 5 | 02-25-2001 10:33 PM |
| 2.5RS Weight Reduction info and questions. | Frank | General Forum Archive | 21 | 02-16-2001 12:53 AM |
