Old 01-23-2012, 04:03 PM   #1
Ethereal Drain
Member#: 292456
Have a Nice Day? Beretta winter wheels, grinding caliper?
I got my flamesuit on, so feel free to unleash the Kraken.
I'm wondering if it will be safe to grind off a little bit of the caliper for clearance?
Cliff's: I'm running summer tires on my rpf1s, which are no longer going to cut it in the snowy/slushy world I live in right now.
I have no money for new wheels right now, and probably not for another 2 months.
Now here's the issue, the caliper very, very slightly rubs on the inside of the wheel. Its very slight, I've taken pictures of both the wheel and the caliper. It's worse under braking than regular driving (I drove it for less than 1/4 mile before removing).
Would I run into any issues if I ran a grinder of it to skim off a little metal in the areas its rubbing? I have Brembos for summer to show off behind my RPF1s. If I can make this work until summer I'll invest in some 17" winter wheels for next season..
Ethereal Drain is offline   Reply With Quote
Old 01-23-2012, 05:12 PM   #2
nhat
Member#: 140163
03 STi
hellaflunctional
buy 2 3mm spacers instead
those are some of the ugliest wheels i've ever seen
Old 01-23-2012, 10:32 PM   #3
Ethereal Drain
Member#: 292456
I thought of that after I left for work, I wonder if that will completely solve the issue, or if it will just rub further inside the wheel?
They are ugly, but finding an affordable set of 16" 5x100 wheels in the proper offset around here is hard! Plus, they're just winter wheels, so the appearance doesn't mean much to me
Old 01-23-2012, 11:19 PM   #4
grind 'em...skip the blembos...get 4pots instead
4pot/h6 rears is a great combo....blembos really **** up the already bad front bias
Old 01-23-2012, 11:38 PM   #5
Ethereal Drain
Member#: 292456
Found a local shop that has spacers for $4 a pop so I'll try that first.
I was gonna upgrade the rears to H6 when I did the brembos, but I might have to sell the brembos to buy a gun for work anyway
Old 01-24-2012, 12:10 AM   #6
sc00by4life
Member#: 97135
It looks like its rubbing on the barrel, not the spokes. spacers unfortunately wont help.
the best you could do is possibly shave the tops of the caliper a small amount and see if that helps, other than that - not much you can do.
Old 01-24-2012, 12:23 AM   #7
Ethereal Drain
Member#: 292456
It is rubbing on the barrel, but it is angled slighty (hard to see in pics) from the spokes towards the middle of the barrel. A spacer might help a little so I'll probably pick 2 up anyway.
Old 01-24-2012, 01:09 AM   #8
sc00by4life
Member#: 97135
From the looks of the wheel, it appears that you would need to move the wheel about half an inch. you wont be able to do that on stock studs.
just grind em and be done with it.
Old 01-24-2012, 02:15 AM   #9
grind 'em
Old 01-24-2012, 09:57 AM   #10
Ethereal Drain
Member#: 292456
ok thanks guys, gonna grind em tomorrow.
I'll report back with pics for future reference in case anyone else decides to pick up a set of ugly beretta wheels for their winter setup
Old 01-24-2012, 03:13 PM   #11
Tire Rack Moderator
Member#: 1215
ext. 4362
better hope you don't get to any fluid passages
Luke@tirerack is offline   Reply With Quote
Old 01-24-2012, 06:22 PM   #12
Power6
Member#: 72730
2001 Lexus ES300,
2005 Outback XT
^^Not on the outside of a sliding caliper
Power6 is offline   Reply With Quote
Old 01-24-2012, 10:27 PM   #13
Ethereal Drain
Member#: 292456
I was told by a friend that if I only have to shave off a little bit I wouldnt have to worry about any leaks, which I'm hoping to be true....
Old 01-24-2012, 11:28 PM   #14
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
there are no fluid passages on that part of the caliper.
A guy in NESIC ground down his calipers to oblivion to clear 15" steelies,
Old 01-25-2012, 01:08 AM   #15
'cmon Luke...you know there arent any fluid passages on that side of that style caliper
I've ground calipers like that a good 1/4" or more to make wheels fit
as long as you understand what you are doing and how to NOT do it...all good
the op could grind those calipers down enough to work in 10 minutes with just a dremel...****....you could do it with a ****ing file in about that long too
that little bit is NOTHINIG....the bloody wheels fit and turned...they only rubbed by a mm or so
i'da had that done in less time than it took to post about it
Old 01-25-2012, 04:18 PM   #16
Tire Rack Moderator
Member#: 1215
ext. 4362
good point ... admittedly I didn't even look at the pictures
Old 01-25-2012, 10:52 PM   #17
Ethereal Drain
Member#: 292456
I was pretty cautious today when I first started, the first caliper took me about an hour, the second took probably 10 minutes
Wheels now fit perfectly, and despite being hideous, I'm very pleased with my investment in this winter setup.
Doesn't look too bad from 140 yards away...
Old 01-28-2012, 12:55 PM   #18
stimanmark
Member#: 235859
2004 WRX STI
winter wheels/tires arent spost to be pretty lol steelies arent pretty either! at least you got some halfway light wheels
stimanmark is offline   Reply With Quote
(NY) WTB: 17" winter wheel/tire package or 17-18" winter tires tung en ace Tri-State Area Private Classifieds 6 10-18-2009 09:24 PM
WTB: Winter Wheels and Winter Tires ohm Private 'Wanted' Classifieds 2 01-16-2009 11:09 AM
FS in MA: Winter wheels & tires, brake calipers, oil filters, etc! KD7000 NESIC Private Classifieds 16 08-26-2008 04:26 PM
WTB: Winter Tires / Winter Wheel + Tire Setup 05 sti essteaeye Tri-State Area Forum 6 11-26-2005 12:36 PM
Winter Wheels with Dunlop M3 Winter Tires AVOID92x Private 'For Sale' Classifieds 15 10-27-2005 09:39 PM
