Welcome to the North American Subaru Impreza Owners Club Monday July 6, 2015
Old 01-26-2012, 08:05 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default DIY $10 Remote oil pressure sender kit (installed pictures)
Didn't want to spend almost $50 shipped for a remote kit from Prosport. Instead I bought 12" grease gun hose (rated for 4500 psi) with 1/8" NPT size and 1/8" NPT fitting to build my own remote oil pressure sender kit.
Pictured below:
1. Prosport oil pressure sender.
2. Prosport oil gallery plug
3. Grease gun hose purchased from Home depot (~$7)
4. 1/8" NPT fitting from Home depot (~$1.50)
Thanks to Vision.dynamix for the idea.
Installed pictures from today (used heat reflective tape on oil pressure sender and applied a lot of dielectric grease)
Most important:
Cold idle (Prosport EVO digital gauge)
Old 01-26-2012, 09:35 PM   #2
Ruvim555
Member#: 247724
2002 WRX WRB Stage 2
2007 CBR 600RR
Where did you buy it?
Ruvim555 is offline   Reply With Quote
Old 01-26-2012, 10:18 PM   #3
SubieMonte
Member#: 264803
2005 WRX Wagon
Harbor Frieght?
SubieMonte is offline   Reply With Quote
Old 01-26-2012, 11:06 PM   #4
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
all from Home depot.....
Old 01-26-2012, 11:11 PM   #5
SubieMonte
Member#: 264803
2005 WRX Wagon
did you get the galley plug there too?
Old 01-26-2012, 11:34 PM   #6
Serkan
Member#: 180514
2004 Sti White
No, they (prosport) sell the galley plug with 1/8 npt hole.
Serkan is offline   Reply With Quote
Old 01-27-2012, 09:11 AM   #7
Unabomber
Big Ron
Member#: 18062
on car parts so PM
me b4 j00 buy
That's gangsta! Be sure to follow up and let us know how it is holding up!
Old 01-27-2012, 09:19 AM   #8
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Ive got cars running these for years.
I had a kid show up to my house in a turbocharged S2000 with an aluminum T screwed directly into the head, and the Oil Pressure sender AND Turbo feed line directly on it. I noticed his car was leaking oil onto my garage floor. I poked around the engine bay, found out his T was cracked. He started the car and the T straight up snapped off.
T Grease gun hose got him back on the road.
Any Auto Parts store or even WalMart will have the hose. Theyre available 6-24"
Old 01-27-2012, 09:20 AM   #9
TPNORTH
Member#: 210741
hmm i like this! Im interested to see how it plays out!
TPNORTH is offline   Reply With Quote
Old 01-27-2012, 09:26 AM   #10
CZ03WRX
Member#: 286115
2003 WRX - sold
I had a $42 stainless 3' braided hose with all the AN fittings you can handle so I could remote mount my sensor from a sandwich plate. Wish I would have seen this before. lol
CZ03WRX is offline   Reply With Quote
Old 01-27-2012, 09:51 AM   #11
mikeyc
Member#: 32338
03 WRX Wagon
I'm upset nobody had thought of this before I purchased one of those kits last year for my oil pressure gauge.
Good thinking guys!
mikeyc is offline   Reply With Quote
Old 01-27-2012, 11:06 AM   #12
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
nice.
Old 01-28-2012, 03:15 PM   #13
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Updated with some pictures from today's install.
Old 01-30-2012, 04:41 PM   #14
ogboot
Member#: 170906
psm
I love it! Now... where to put the guage... *looks at AFR and EGT* Hmmm....
ogboot is offline   Reply With Quote
Old 01-30-2012, 05:05 PM   #15
spongerrich
Member#: 214736
2005 WRX wagon WRB
Cobb Stage 2 OTS
Nice idea! I have a sandwich plate with oil pressure / oil temp senders attached waiting for me to install, but I'm liking this plan better.
Are there 2 spare galley plugs I can use? Or mount 2 sender units on one?
Is it generally more accurate to use the sandwich adaptor or the galley plugs?
spongerrich is offline   Reply With Quote
Old 01-30-2012, 05:09 PM   #16
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Sandwich adapters are prone to leakage.
The oil galley under the alternator has the OEM Oil Pressure switch in it. There is no drawbacks to removing it, no CELs etc.
There is a second oil galley under the TMIC with nothing in it but a plug. That is the go-to spot for the first gauge.
You can use both these galleys without issue.
You can mount 2 senders in one with a T, however, remotely mounting an oil temp gauge isnt recommended, since it should be in flowing oil, and a T would put it at a dead end.
Old 01-30-2012, 05:42 PM   #17
spongerrich
Member#: 214736
2005 WRX wagon WRB
Cobb Stage 2 OTS
OK. So I can put in an oil pressure sender in the galley where the OEM pressure switch is, and an oil temp sender in the galley under the TMIC?
Sorry for the noob questions, but what is the dielectric grease for?
Old 01-30-2012, 05:48 PM   #18
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Sure, or the other way around. Doesnt matter.
Dielectric grease prevents corrosion of electrical contacts.
Old 01-30-2012, 11:14 PM   #19
shredboostnburn420
Member#: 277436
2005 Impreza WRX STI
would this work with a defi gauge?
shredboostnburn420 is offline   Reply With Quote
Old 01-31-2012, 06:07 AM   #20
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
gauge type/brand doesn't matter.
Old 01-31-2012, 06:51 AM   #21
ckswanecamp
Member#: 299861
2002 Impreza WRX
Metallic Silver
Great Idea!
You used the plug under the alternator, how is everything holding up?
ckswanecamp is offline   Reply With Quote
Old 01-31-2012, 07:18 AM   #22
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
This, kinda.
Most gauges use NPT fittings. However gauges do exist that use BSPT fittings. The thread pattern on these are close, not close only counts in horseshoes....so this wouldn't work for a BSPT gauge without adapters.
Old 01-31-2012, 07:51 AM   #23
20wrx09
Member#: 207417
2009 WRX
td06sl2-20gtx 413/423
so is the factory galley plug that the dummy sensor plugs into npt? or bspt? can i just reuse the factory galley plug under the alternator or should i buy a new one?
Edit: also i went to install my oil pressure gauge (AEM) and the aem sending unit was .5mm too wide to screw into the factory galley plug. so it only got about a thread into it and wouldnt go any farther. cleaned up the treads with a tap and die and still didnt fit. the thread pitch matched so im guessing that the factory is npt. or could it be a machining error on aem's part? i love this idea and will be stoppping by home depot as soon as i get my answer(s)
20wrx09 is offline   Reply With Quote
Old 01-31-2012, 07:55 AM   #24
vision.dynamix
Member#: 139955
2015 Subaru STI
Stage e
Pretty sure the factory sensor is indeed BSPT.
Old 01-31-2012, 08:20 AM   #25
340Duster
Member#: 52314
2002 PSM WRX 16G-XT
'13 500 Abarth
Why not just mount the sender to a modified plug/ right on the block instead of making extra steps?
340Duster is online now   Reply With Quote
WTB : Remote Oil Pressure Sender Installation Kit EROCS04SBRUSTI Private 'Wanted' Classifieds 0 12-23-2011 05:10 PM
WTB : Remote Oil Pressure Sending Kit Dborne Private 'Wanted' Classifieds 0 07-21-2011 02:49 PM
Prosport Premium Gauges 52mm Oil Pressure and Temp Remote Oil Pressure Sender Kit skribblez32 Interior/Dressup/Audio & Security 4 07-01-2009 03:50 PM
FS: Oil pressure sender relocation kit. bisonjr MAIC Private Classifieds 0 03-07-2009 06:04 PM
WRXtra Oil Pressure Sender Installation Kit drees Car Part Reviews 1 06-21-2004 08:09 PM
