Welcome to the North American Subaru Impreza Owners Club Saturday March 28, 2015
Alaskan Impreza Club
Old 02-05-2012, 06:31 AM   #1
granny
Member#: 283145
1997 LEGASTi Wagon
PowerflexUSA-@grannywagon
Legacy Granny's 1997 Legacy L Wagon
I decided to make a thread for Granny so you don't need to see an old wagon in all the other threads. When I first got Granny she was beaten up and dirty. Over the last three years I have tried to clean her up as nice as possible on my cheap budget. To save money I have done most of the work myself so here is my progress.
Sponsors:
PowerflexUSA - http://powerflexusa.com/
Whiteline - http://www.whiteline.com.au/
Moore Performance - https://mooreperformanceparts.com
SuperPro - http://www.superpro.com.au
WHP: Coming Soon...
Weight: 2,800lbs
Mod list:
Cosmetics:
Interior:
04 STi Front Seats
04 STi Steering Wheel
Custom Blue Suede STi Door Cards
Custom Blue Suede Shifter Skirt
Custom Black Carpet
Custom Gauge Cluster
Custom Boost Gauge Mount
Custom Control Panel
Sparco Lowering Shift Knob
STi Carpet Floor Mats
Sony Xplō XS-GT1627A Speakers
Sound Ordnance B-8Ps 8"
Pioneer Stereo
Rear Interior Stripped
Exterior:
RA Mud Flaps
96 LGT Front Bumper
BG5 JDM Zecter Grill Painted Java Black
Windshield Washer Nozzles Painted Java Black
Windshield Wipers Painted Java Black
Hella Supertone Horns
Pulled Fenders
20% Rear Tint
Rear 07 STi Defuser
JDM BG5 Tail Lights
Smoked Headlights
H1 Mini Projectors
6000k HID Bulbs
LED White Halos
JDM Projector Fog Lights
2004 STi Hood Scoop
Painted WRB
Color Matched Trim
Color Matched Center Tail Lights
Color Matched Rear License Plate
Custom LEGASTi Emblem
Engine Bay:
Shaved Engine Bay Painted WRB
Wire Tucked
Battery Relocated To Rear
Windshield Washer Tank Relocated To Rear
Performance:
Engine:
STi EJ257 Block
CP Forged Pistons and Rings
EJ251 SOHC Ported Heads
Techworks Engineering Stg. 2.5 Cams
Supertech Dual Valve Springs
Supertech Titanium Retainers
Garrett GTX30R External Wastegate Turbo Wrinkle Red Heat Coated
Tial MV-R 44mm External Wastegate
Hallman Pro Boost Controller
Custom WRX Fuel Rails
ID 1000cc Top Feed Injectors
Full Race 416lph E86 Fuel Pump
Tomei Timing Belt Guide
WRX Flipped Intake Manifold Wrinkle Red Heat Coated
GroupN STi Motor Mounts
GroupN STi Pitch Stop Mount
AEM Air Cleaner
Custom 4" Intake Wrinkle Red Heat Coated
Custom V-Mount intercooler
Custom Intercooler Pie Cut Piping Wrinkle Red Heat Coated
04 Forester XT Radiator
Crawford Heated Air/oil Separator
Mishimoto 19 Row Oil Cooler WRB
Mishimoto Oil Cooler Thermostat Sandwich Plate
Custom Top Mount Oil Cooler Brackets
Flipped Alternator
Custom Alternator Belt/Tensioner
02 Legacy Power Steering Pump
Blue Silicone Hoses
SMC2 Meth Injection Kit
Link Plus G2 Standalone
Exhaust:
3” Custom Fitted Cat Back Catless Exhaust
3" Perrin Rotated Catless Downpipe
Grimmspeed Ceramic Coated Crossover Pipe
Ceramic Coated Headers
Perrin 2" Rotated Up Pipe
Powertrain:
05 LGT 4:11 5Speed Transmission Polished
04 STi Axle Stubs
05 LGT Limited Slip Rear Diff
02 WRX Rear Axles
ACT Extreme Duty Pressure Plate
ACT 6Puck Clutch Disc
ACT Street Lite Flywheel
ACT Throwout Bearing
Whiteline Transmission Crossmember Bushings
Kartboy Short Shifter
Kartboy Front and Rear Shifter Bushings
Subaru Shifter Joint
Moore Performance Blast Plates
Suspension and Handling:
Megan Racing Track Coilovers
STi Pink Trailing Arms
Whiteline Adjustable Lateral Links
Whiteline 27mm Adjustable Front Sway Bar
Whiteline 24mm Adjustable Rear Sway Bar
Whiteline Rear Endlinks
Whiteline HD Rear Sway Bar Mount
Kartboy Rear Subframe Lockdown Bolts
02 WRX Rear Crossmember Powder Coated WRB
02 WRX Rear Diff Support Powder Coated WRB
02 WRX Engine Cradle Powder Coated WRB
Super Pro Front Lower Control Arms
Super Pro Front Endlink
Super Pro Anti Lift Kit
PowerflexUSA Race Rear Diff Bushing
PowerflexUSA Race Diff Support Outrigger Bushing
PowerflexUSA Race Front Trailing Arm Bushing
PowerflexUSA Race Rear Trailing Arm Bushing
PowerflexUSA Race Steering Rack Bushing
Group N Rear Crossmember Bushings
Whiteline Front Roll Center Adjustment Kit
WRX Rack and Pinion Assembly
L&E Quick Steering Column
L&E Steering Linkage
Kakumei STi Rear Strut Bar
Bolt-in Roll Cage
Brakes:
Front Stoptech 2-Piece 13" Cross-Drilled Vented Zinc Coated Full Floating Rotors.
Front Brembo GT2 Calipers (Powder Coated Cherry Blossom Red)
02 WRX Rear Calipers
H6 Caliper Brackets
H6 Cross-Drilled Zinc Coated Rotors
Goodridge Stainless Steel Braided Brake Lines
HPS Hawk Brake Pads
Lots of mods coming soon.
Granny's first detailing. I wish I had a before picture but I don't.
Granny gets her engine cleaned for probably the first time in her life.
Granny gets custom made (by me) blue suede STi door cars.
Before:
After:
Granny's first fishing trip.
Who says an old lady can't pack?!
Granny gets hearing aids.
granny is offline   Reply With Quote
Old 02-05-2012, 06:38 AM   #2
granny
Member#: 283145
1997 LEGASTi Wagon
Legacy
Granny gets a new grill.
Granny's first auto-x!
Granny gets some racing numbers.
Is it fast? It's got racing numbers on it doesn't it?
Granny with custom plate, and her new wheels and tires.
Boy that's a close fit!
Granny gets mudflaps (made by me).
Granny gets a scooby doll and a STi muffler! VVVVVVROOOOOOOOOOM!
Old 02-05-2012, 06:46 AM   #3
granny
Member#: 283145
1997 LEGASTi Wagon
Legacy
Granny gets an interior makeover.
Randome pictures.
I bet your car hasn't been here. Hehehehe....
Granny with a new grill.
Granny's engine bay goes WRB!
Granny gets a STi front sway bar.
Lots more to post I just ran out of pictures for now.
Old 02-05-2012, 07:03 AM   #4
crash907
Member#: 250938
Subscribed!
crash907 is offline   Reply With Quote
Old 02-05-2012, 08:38 AM   #5
kyletakahero
Member#: 185030
2008 FXT Sport
Aspen white
Definitely can't wait to see more from this.
It is still one of my fetishes to have a older LGT wagon and go crazy with it.
kyletakahero is offline   Reply With Quote
Old 02-05-2012, 10:48 AM   #6
Chandy69
Member#: 16087
02 WRX
Back seat with your mom
can you explain the sway bars... curious how you got them to fit?
Chandy69 is offline   Reply With Quote
Old 02-05-2012, 01:18 PM   #7
granny
Member#: 283145
1997 LEGASTi Wagon
I put my stock endlinks and mounts on the STi bar. The parts in my hand is what came off the STi bar.
Difference in size.
Mounted.
I started to size up the rear STi sway bar by replacing the Legacy torsion bars with the STi ones (these fit fine). I checked the length of the Sti sway bar and it also looked like it will fit (I will know for sure later today when I do the rest). For this to work you need STi torsion bars, STi rear sway bar (duh), STi rubber bushings, STi endlinks (these work with the STi torsion bars), and Legacy metal sway bar mounts.
To hang the STi sway bars I had to use the STi rubber bushings with the Legacy metal mounts (STi bushings fit the bar, Legacy mounts fit the car). The STi rubber bushings have a lip so to make them fit the Legacy mounts you need to grind the lips down like so.
From there I could mount ONE side (you will see why I said one in a second) of the sway bar and test fit it with the STi torsion bar.
Now the reason I could only mount one side is the spot where you put the spare tire is in the way. I started to cut at it tonight and I'll finish it today.
Size difference.
Hope this helps. I will update this when I get further along. Not sure how far I will get today with the Superbowl going on.
Old 02-05-2012, 02:09 PM   #8
insane_one
Member#: 301431
as always, nice work. looking forward to see more!
insane_one is offline   Reply With Quote
Old 02-05-2012, 02:23 PM   #9
Rookie J
Member#: 281747
2005 Legacy GT Wagon
Element Sponsored
I saw ALL of the pictures on my phone. Awesome job. I can't wait to see what she looks like when she's done.
Rookie J is offline   Reply With Quote
Old 02-05-2012, 02:30 PM   #10
granny
Member#: 283145
1997 LEGASTi Wagon
Glad the pictures are working for you.
Old 02-07-2012, 02:41 AM   #11
granny
Member#: 283145
1997 LEGASTi Wagon
Made spacers for my sway bar mounts. Hopefully this gives the sway bars enough clearance.
Old 02-08-2012, 02:19 AM   #12
granny
Member#: 283145
1997 LEGASTi Wagon
I put on my 2.5 heads today! Racer Dubya is coming over tomorrow to help put things together, so hopefully Team Swan will get a lot done.
Old 02-08-2012, 03:04 AM   #13
insane_one
Member#: 301431
almost there man! keep up the good work.
considered cleaning up the block befor it goes back in?
Old 02-08-2012, 03:24 AM   #14
granny
Member#: 283145
1997 LEGASTi Wagon
Oh don't worry this engine will be spotless.
Old 02-09-2012, 03:58 AM   #15
granny
Member#: 283145
1997 LEGASTi Wagon
Cams and oil pan on!
Old 02-09-2012, 04:23 AM   #16
insane_one
Member#: 301431
oh yea!
Old 02-11-2012, 12:57 AM   #17
granny
Member#: 283145
1997 LEGASTi Wagon
Header went on today! Doing a few special touches to the intake manifold and then we can finish up.
Old 02-11-2012, 01:07 AM   #18
ridestreet84
Member#: 132030
2007 obp STI
broken again
What header is that?
ridestreet84 is offline   Reply With Quote
Old 02-11-2012, 01:36 AM   #19
granny
Member#: 283145
1997 LEGASTi Wagon
Ummmm I think they are Borla 1P EJ25 stainless steel headers
Old 02-11-2012, 02:08 AM   #20
retrac
Member#: 217208
996 Porsche 911
Seal Gray
Perhaps I'm missing it, but I don't see any provisions for a turbo oil drain. Also, before you get too far, consider the location of your turbo inlet versus the accessories and SMJ connectors versus the turbo housing.
retrac is offline   Reply With Quote
Old 02-11-2012, 02:17 AM   #21
granny
Member#: 283145
1997 LEGASTi Wagon
Oil drain is going in the valve cover which is why they aren't on yet.
Old 02-11-2012, 04:33 AM   #22
granny
Member#: 283145
1997 LEGASTi Wagon
Test fitting the turbo. Mmmmmmmm.
Old 02-11-2012, 03:36 PM   #23
Racer Dubya
some old guy
Member#: 112225
1985 78 HP of Rage!
Not borla... It's a no name... UP is welded to the headers
Racer Dubya is offline   Reply With Quote
Old 02-13-2012, 02:50 AM   #24
granny
Member#: 283145
1997 LEGASTi Wagon
Finally got a chance to work on Granny. It's been awhile.
I put on the 2.2t water pump.
I put on and torqued one valve cover.
Tapped into the other valve cover for the turbo's oil drain. I am waiting for a cam bolt to come in before I can torque this valve cover.
I tapped into the heater core lines for the coolant lines.
I cut and grinded the unnecessary pieces on the intake manifold to clean it up a bit.
I will finish cleaning the dirt and grease off, and hopefully paint it tomorrow.
I wanted to take a quick peek at what I had to look forward to so I hung the belt cover on.
Old 02-13-2012, 03:11 AM   #25
insane_one
Member#: 301431
oooohhh man!
FS: 1997 Legacy GT Wagon (JDM Tails) - Beaverton, OR Diamond Dave Private Vehicle 'For Sale' Classifieds 0 07-13-2006 03:45 PM
FS: 1997 Legacy GT Wagon - Portland, OR eVoMotion Private Vehicle 'For Sale' Classifieds 3 10-22-2005 06:01 PM
FS - 1997 Legacy GT wagon - Portland, OR eVoMotion Private Vehicle 'For Sale' Classifieds 0 10-17-2005 11:24 PM
1997 Legacy L Wagon n00b brake questions DDB Legacy Forum 28 08-24-2005 02:25 AM
Parting out 1997 Legacy L Wagon sofferj04 Private 'For Sale' Classifieds 9 03-02-2004 01:15 PM
