Old 03-01-2011, 04:19 PM   #1
elsuicida
Member#: 189889
02 Bug-Eye Stroker
*Twin Scroll Equipped*
Default V7 JDM STI :Engine Wiring Harness
Ok, so Im in the process of buying a 2001 V7 STI motor. It comes with the 6sp tranny,TMIC, Harness,ECU, etc. My question is, which engine harness do I use? I know the V7 has AVCS but the wiring harness was set up for RHD not LHD. Can I re-use the stock V7 harness or do I have to modify my WRX harness to suit the AVCS? Anything else I might be missing please do tell.
elsuicida is offline   Reply With Quote
Old 03-01-2011, 04:27 PM   #2
fellstar
Member#: 205280
2012 Jeep Wrangler
Bright Silver
Originally Posted by elsuicida View Post
Ok, so Im in the process of buying a 2001 V7 STI motor. It comes with the 6sp tranny,TMIC, Harness etc. My question is, which engine harness do I use? I know the V7 has AVCS but the wiring harness was set up for RHD not LHD. Can I re-use the stock V7 harness or do I have to modify my WRX harness to suit the AVCS? Anything else I might be missing please do tell.
Someone will pipe in with the documentation... the motor is pretty much plug and play other than the AVCS. You can buy a kit from a vendor... I'm not sure whom, or you can add 4 wires and modify one of the connectors on the harness.
You definitely do NOT want to pull the V7 harness...
This is, of course, assuming you are swapping this in to your 2002.
fellstar is offline   Reply With Quote
Old 03-01-2011, 04:33 PM   #3
elsuicida
Member#: 189889
02 Bug-Eye Stroker
Yeah is going on an 02. Any idea where I can get more info on that kit. I didn't know they had one available.
Old 03-01-2011, 04:33 PM   #4
tobylazur
Member#: 150289
2002 WRX Wagon
is the V7 motor OBD-I or OBD-II?
tobylazur is offline   Reply With Quote
Old 03-01-2011, 04:36 PM   #5
elsuicida
Member#: 189889
02 Bug-Eye Stroker
I mean it is a 2001 Motor. So I am 100% sure its an OBD-2. Unless otherwise. I mean even If I have the ECU it would still not be a Plug-N-Play?
Old 03-01-2011, 08:02 PM   #6
elsuicida
Member#: 189889
02 Bug-Eye Stroker
Any gurus out here that can shine some light?
Old 03-01-2011, 10:55 PM   #7
Fierysun
Member#: 82745
2005 Subaru STI
2003 WRX Wagon
There's a write up on this. You can reuse your existing USDM harness, but you'll need to change the pins around and add an additional 4 wires to attach to the JDM ecu.
http://forums.nasioc.com/forums/show...t=ej207+wiring
http://www.importtuner.com/tech/0311...ion/index.html
Fierysun is offline   Reply With Quote
Old 03-01-2011, 11:31 PM   #8
elsuicida
Member#: 189889
02 Bug-Eye Stroker
Old 03-17-2011, 12:50 PM   #9
scoobie_snacks
Member#: 212744
2005 Ver8 EJ207 VF37
6 speed
Dude.. everything plugs in.. except for avcs.. its direct plug and play in your existing cabin harness.. but run the V7 ecu. get the IA avcs harness to make avcs work. very very easy swap.
scoobie_snacks is offline   Reply With Quote
Old 04-07-2011, 04:30 PM   #10
wrxgrumble
Member#: 276577
2013 Impreza WRX
Not to thread bomb or anything.
Im new to the site, I just purchased an 07 wrx tr for $8000. (It had a blown motor and was a friend of mine)
I have been doing some research but cannot find exact information on the swap im wanting to do. most jdm swaps i have came across in great detail are bugeyes or earlier models.
Im interested in doing a jdm V7 swap but keep it LHD. on ebay there is a few front clips for sale for $9500.
My question is, is there any link or info on doing a swap like im planning on doing. an older engine in a newer car. (Mainly wiring related)
Any and all info/help would be greatly appreciated!!!!
wrxgrumble is offline   Reply With Quote
Old 04-07-2011, 05:14 PM   #11
jjameson
Member#: 4986
2002 BlzYel JDMSTiv7
GRP 08 FXT
I went the rout of using the JDM ecu and harness.
OBD II, of course
Will it pass U.S. OBD II plug in inspection/emissions check, No.
Not all states require, check your local listings.
JDM ECU won't send 'ready bit' that US OBD II tests look for.
Keep your USDM ECU and flash with JDM map (No AVCS) to get thru US OBD II plug in inspection.
jjameson is offline   Reply With Quote
Old 05-05-2011, 01:03 AM   #12
johnpaul76
Member#: 71075
1998 Impreza RSTi
Faded Rally Blue
JDM ECU V7 passes NJ inspection. Mine definiately sets the ready bit. Shows the O2 sensor heaters are working properly.
johnpaul76 is offline   Reply With Quote
Old 05-06-2011, 11:21 AM   #13
Osgood30
Member#: 20437
1999 Impreza STI
Version 7
my JDM ECU V7 also passed PA inspection. I was told that newer engine in older car is ok, now if I had newer car with older engine then there could have been issues.
Osgood30 is offline   Reply With Quote
Old 10-18-2011, 10:32 PM   #14
1thumper
Member#: 248584
2002 wrx
i just got a v7 jdm that im dropping into my 02 rex but the passenger side connector has been cut....does anyone have the wiring diagram or a few pics so i can splice in a new connector.
thanking you in advance
1thumper is offline   Reply With Quote
Old 02-02-2012, 06:26 PM   #15
drummerdude
Member#: 255999
2002 Impreza RS 5MT
blue
I know this is an old thread, but will the cabin harness from an 02 rs plug into the jdm sti v7 ecu?
drummerdude is offline   Reply With Quote
Old 02-07-2012, 08:07 PM   #16
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
nothing to see, i'm stock
i'm pretty sure you have to merge the harnesses, a friend of mine has a v8 swapped in his GC, thats what he had to do
Old 02-08-2012, 09:18 AM   #17
Zephyr
Member#: 3362
1985 I've wired a
Few cars in my day
The 02 RS harness is more or less the same as any other year RS and will not plug into any WRX harness. You will need to have the harnesses merged. I've done quite a few of the 02+ RS'.
Zephyr is offline   Reply With Quote
Old 02-08-2012, 11:40 AM   #18
drummerdude
Member#: 255999
2002 Impreza RS 5MT
blue
will taking all of the pins out of my rs plugs, and placing them in the jdm plugs (obviously in the right spots) work?
Old 02-08-2012, 01:24 PM   #19
Zephyr
Member#: 3362
1985 I've wired a
Few cars in my day
Unfortunately you can not repin the plugs. They are a different shape and will not fit. The harness needs to be merged. The plugs in the engine compartment are also pinned differently and located in different positions on the turbo cars.
Old 02-08-2012, 01:32 PM   #20
drummerdude
Member#: 255999
2002 Impreza RS 5MT
blue
what is involved in a harness merge, I only see people recommended to take it to xxxx shop, I prefer to do everything myself.
Old 02-08-2012, 01:33 PM   #21
drummerdude
Member#: 255999
2002 Impreza RS 5MT
blue
I can probably get my hands on a wrx harness, but will it plug into my rs components (for the body) and I will still need the dccd, is that possible when using a wrx harness?
Old 02-09-2012, 12:07 PM   #22
drummerdude
Member#: 255999
2002 Impreza RS 5MT
blue
I found a guide for a gc to gd merge, so I have the general idea, but if the metal pins inside the plugs are the same from my rs to the wrx, I still can just repin them, otherwise I may try to find the wrx pins in bulk somwhere so I don't have any cut wires.
Old 02-10-2012, 08:18 AM   #23
fastnoypi
Member#: 6886
MY01 EJ207 HTA35r
Not anymore, I set the ready bit, no CELs...but still failed. The report and the inspector explained a handful of the emissions criteria showed up as "Unknown". This was through the month of December '11. I had it pass before in 03.
V7 JDM STi Wiring Harness (AVCS) Keenah Engine/Power/Exhaust 1 01-02-2009 09:07 PM
V7 JDM STi Wiring Harness Keenah Private Vehicle 'For Sale' Classifieds 1 01-02-2009 02:40 PM
V7 JDM STI Springs, V7 JDM STI rear tophats. Valhakar SWIC Private Classifieds 1 05-30-2007 12:36 PM
jdm 01 sti RA wiring harness w/ 02 udsm ECU? LegacyWRX Subaru Conversions 0 10-23-2006 07:00 PM
V7 JDM STi Front Seats & V8 JDM STi Rear Seats ! Gruppe-S Interior/Dressup/Audio & Security 10 02-22-2005 04:06 PM
Message Board Statistics All times are GMT -4. The time now is 03:57 AM.
