Old 02-08-2012, 11:46 AM   #1
CTSSM2011STI
Member#: 279512
2011 STI Limited 4dr
Default Any way of finding type of oil use in car?
So today I dropped off my 2011 STI Limited at the dealer for an oil change and some warranty work. When it came time for me to sign all the paperwork and as the service advisor was reading off the paperwork he said "the oil change will be $35.99; if you want you can put in synthetic next time". My immediate reply was "No No its a turbo car it needs to have synthetic put in it all the time". He then crossed out the $35.99 price and changed it to $65 but that was as far as I saw.
This has me kinda of worried now as to weather or not they have been putting in regular oil this entire time and just charging me more of if they are actually going to put in synthetic this time...
Does anyone know of a way to get the oil that is in my car tested to make sure that it is the correct oil being used and if so how to I go about doing it?
THANK YOU!!!!
CTSSM2011STI is offline   Reply With Quote
Old 02-08-2012, 12:12 PM   #2
grinch77
Member#: 198758
2004 STi
Just drain it and put new oil in.You will pay more for what ever test there is than what five quarts of oil will cost you.
grinch77 is offline   Reply With Quote
Old 02-08-2012, 01:35 PM   #3
Badler
Member#: 133597
Pro tip: Change your own oil and you will know what kind it is.
Badler is online now   Reply With Quote
Old 02-08-2012, 06:18 PM   #4
JamesWilson2
ForumWars Winner!
Member#: 196948
2003 Forester
And find a new dealership. Unacceptable.
JamesWilson2 is offline   Reply With Quote
Old 02-08-2012, 09:17 PM   #5
z
Member#: 41762
04 STi
CT-DE-FL rinse+repeat
That's definitely lame. What stealership was this?
z is offline   Reply With Quote
Old 02-08-2012, 10:22 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
I hate to break it to you guys but Synthetic is NOT REQUIRED only suggested. Read your owners manual closely
edit: For example, this is directly from the 2011 Forester Owners Manual
API classification SM or SN with the words “ENERGY CONSERVING” or “RESOURCE CONSERVING” or ILSAC GF-4 or GF-5
0W-20 synthetic oil is the required oil for optimum engine performance and protection. Conventional oil may be used if synthetic oil is unavailable.
If 0W-20 synthetic oil is not available, 5W-30 or 5W-40 conventional oil may be used if replenishment is needed but should be changed to 0W-20 synthetic oil at the next oil change.
In other words the only REQUIREMENT is API SM or SN with ILSAC GF-4 or GF-5. All the other "mays" and "shoulds" are not requirements at all.
You can run conventional oil all day long if it meets the requirements and you change it according to the interval specified. If you really want to know what is going on send your oil for analysis. Its only 20$ fricking dollars and you'll know for certain whether the conventional oil is damaging your engine.
ciper is offline   Reply With Quote
Old 02-08-2012, 11:46 PM   #7
CTSSM2011STI
Member#: 279512
Trust but I would rather not throw away $70 just to spend another $50 or w.e. it will be just to put new oil in... I think I am just going to make sure that when they hand me the paperwork back tomorrow that it states that synthetic oil was put in.
I am either going to learn how to change my own oil now or I am just going to buy the stuff ahead of time and have the dealer use what I bring to them.
I would rather not say exactly what dealership it was... Fact of the matter is that many Subaru dealerships in Connecticut don't seem to know anything in general about the cars sadly.
The Forester is a completely different car and as far as I know I am sure that they do not have a turbo model.
Here is the print in the 2011 STI Owners Manual directly off of Subarus My Vehicle Section:
SAE viscosity No. and applicable temperature
5W-30 synthetic oil is required for optimum engine performance and protection. Conventional oil may be used if synthetic oil is unavailable.
*: If 5W-30 synthetic oil is not available, 5W-30 or 5W-40 conventional oil may be used if replenishment is needed but should be changed to 5W-30 synthetic oil at the next oil change.
Old 02-09-2012, 06:37 AM   #8
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
You are worrying too much. Stop thinking that conventional motor oil shot Kennedy from the grassy knoll. Change it back to synthetic tomorrow, next oil change, or never as you see fit and go to another place for oil changes. Nice of you to ask, but you've already been given your answer, so accept it rather than to deflect it.
Old 02-09-2012, 07:58 AM   #9
bluesubie
Member#: 767
04 FXT
The Forester is not a completely different car and yes they have a turbo model. Every note that SoA puts out about synthetic is different than the last. Note that your manual says that synthetic is required for optimum engine performance, not that it's "required" full stop.
And who's definition of synthetic are they using? Not the API's because they don't have one. And replenishment with 5W-40 conventional is allowed? There's NO such thing! In an email newsletter, SoA said that the new Impreza requires 0W-30 conventional. No such thing as that either and the Impreza specs 0W-20 synthetic. The Outback's manual says synthetic may be used but you have to stick with it if you switch to it. 1980's logic. I'm not suggesting that you run only conventional, but a 3k mile run isn't going to hurt anything.
-Dennis
Old 02-09-2012, 12:01 PM   #10
CTSSM2011STI
Member#: 279512
The answers that were given were to "change my own oil", "tests are $5,000", and that "Synthetic is not required". I acknowledged all answers and challenged only the one that is directly below this reply (not knowing that there was in fact a turbo model Forester). IMO people learn by information and I was given that information challenged the opinion and got more information to which I now understand.
-Dennis
My apologies I don't know to much about Subarus other vehicle lineup. Thank you for your input...
Old 02-09-2012, 12:24 PM   #11
CTSSM2011STI
Member#: 279512
Here is a photo I took of my notes section of the invoice for the oil change that was done. NOTE: Comment at the bottom!
Looks like they are saying that Synthetic oil should NOT be used at all in the car now until the 15k.
Old 02-09-2012, 06:13 PM   #12
bluesubie
Member#: 767
04 FXT
Time to find a new dealer.
Old 02-09-2012, 07:20 PM   #13
ciper
Member#: 15543
90BJ Legacy LS ABS
BlueSubie Is that an endwrench article? If so you cannot trust it. It is published by a different part of subaru and they often get stuff wrong.
Originally Posted by CTSSM2011STI View Post
5W-30 synthetic oil is required for optimum engine performance and protection.[/color][/u] Conventional oil may be used if synthetic oil is unavailable.
I think you just proved my point that synthetic is not required
There are plenty of great conventional oils, and there are some crap synthetics. Either way if it meets the API ratings they specify and you are within the viscosity range it will work.
Old 02-09-2012, 08:19 PM   #14
CTSSM2011STI
Member#: 279512
Yes you can use conventional oil but not oil change after oil changed so in that case in being able to use conventional oil you are correct but that is only if synthetic is not available. At my 7.5k service conventional oil was used and if they were to have used it again this time like they were going to then it would have been against what Subaru states in the owners manual.
Old 02-09-2012, 08:54 PM   #15
ciper
Member#: 15543
90BJ Legacy LS ABS
CTSSM2011STI Read your manual more closely. It is not required to use synthetic. You could use generic conventional oil if it meets the actual requirements listed. Look for the circle logo.
Old 02-09-2012, 10:06 PM   #16
CosmoTheCat
Member#: 3409
98 My FMIC
Is bigger than yours.
In class they tell the techs that the correct weight synthetic is required - the FB motors have no oil coolers and are designed to run hotter to keep the oil as thin as possible, because the cam timing is adjusted by using valve spring tension to shuttle oil back and forth between chambers in the cam sprocket.
Thick sludged up oil doesn't move very fast, and if you start having cam timing issues the oil is the first place to look...
Having said that, a good conventional oil probably won't do you wrong.
CosmoTheCat is offline   Reply With Quote
What types of PS fluid can I use in my '08 Impreza? kenratboy Brakes, Steering & Suspension 4 12-10-2011 10:36 PM
Gary, IN police incapable of finding two kids who died in a car crash WRX300 Off-Topic 56 09-19-2007 01:39 PM
Any way to find out what websites someone owns??? -=C=- Off-Topic 6 04-21-2005 10:15 AM
('93-'01) Is there any way to find out if the WRX is the most crashed "new" car this year? Snoopy Impreza Forum 25 10-16-2002 01:53 AM
